Kohler K301A engine running hot - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 08-08-2009, 06:06 PM   post #1 of 8
ptplumer
MTF Member
ptplumer's Avatar
MTF Member # 25611
Default Kohler K301A engine running hot
My Kohler engine on my Cub Cadet 129 runs very hot. I rebuilt the engine two years ago and it has lots of power, but it runs very hot. I have the carb set where factory specs suggest, and it runs well, but carbons up and backfires when I shut it down. I have made some minor adjustments to the carb, but maybe I am just being too conservative. I am trying to find some good suggestions, anyone?
ptplumer is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-08-2009, 07:04 PM   post #2 of 8
Kbeitz
Collector of many tractors
Kbeitz's Avatar
MTF Member # 86
Images: 4
Default Re: Kohler K301A engine running hot
Running lean or a timming problem or no air flow...
__________________
Kbeitz is online now   Reply With Quote Quick reply to this message
Old 08-09-2009, 12:48 AM   post #3 of 8
amf1414
certified tractor nut
amf1414's Avatar
MTF Member # 26032
have you pulled the shrouds to make sure that no furry little critters have made youe engine into a new critter condo
amf1414 is offline   Reply With Quote Quick reply to this message
Old 08-09-2009, 09:30 AM   post #4 of 8
ptplumer
MTF Member
ptplumer's Avatar
MTF Member # 25611
No furry creatures inhabiting the shrouds. I did the top end overhaul myself, all timing marks are aligned per procedure. I am going to play with mixture later today. Make it richer. Thanks.
Old 08-09-2009, 09:41 AM   post #5 of 8
Ingersoll444
ex spelling bee champ
Ingersoll444's Avatar
MTF Member # 16
Images: 14
What makes you think its overheating?
pretty much all the old K's backfire when shutting down. That big flywheel keeps the engine turning after shutdown, and pulls raw gas into and out of the engine into the hot muffler and POW!!! Before shutoff, let it idel down for a min or so, then shut off. that normaly helps.
__________________
Paul B
Visit The Case Ingersoll Colt Forum.
SUPER Of The Month 10/2011
Ingersoll444 is online now   Reply With Quote Quick reply to this message
Old 08-09-2009, 03:34 PM   post #6 of 8
rscurtis
5000 Strong & Climbing
MTF Member # 25367
I 444 is right. As long as the cooling fins have paint on them (except around the exhaust port) its temperature is probably OK.
rscurtis is online now   Reply With Quote Quick reply to this message
Old 08-09-2009, 09:46 PM   post #7 of 8
ptplumer
MTF Member
ptplumer's Avatar
MTF Member # 25611
I went through the tuneup process based on Kohler's specs as best I could wihtout a tach. Seems like ti may have helped. I'll have to mow with it this week and see how it does. I will try the cool down recommendation. Thanks a bunch!
Sponsored Links
Advertisement
Old 08-09-2009, 09:47 PM   post #8 of 8
ptplumer
MTF Member
ptplumer's Avatar
MTF Member # 25611
One other thing, how do you tell the difference between the Walbro and Kohler carbs on these?
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
