Jd 2030 Pto - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 08-05-2009, 09:37 AM   post #1 of 13
gaz
MTF Junior Poster
MTF Member # 30517
Default Jd 2030 Pto
Hi all have noticed a few members have this model. I have brought my dads 1975 JD 2030 back to life lately but have noticed that the PTO turns constantly i seem to remember when it was going years ago that when you attached an implement if the pto was not engaged with the lever. the weight of the attachement would stop the shaft turning.Now it turns all the time. Any body any ideas what could be wrong.
gaz is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-05-2009, 09:45 AM   post #2 of 13
John Deere Addict
Member
John Deere Addict's Avatar
MTF Member # 633
Default Re: Jd 2030 Pto
We had 2 JD 2030's. Nice tractors!
Here is what I'd try..... since the tractor has sat (presumably by your mention of bringing it back to life) idle for some time, perhaps the disks have bonded together. Try running a piece of equiptment with the PTO lever in the off position and see if it will eventually break themselves loose.
__________________
Nothing runs like a Deere!
Where The Big Boys play..
John Deere Addict is offline   Reply With Quote Quick reply to this message
Old 08-05-2009, 02:24 PM   post #3 of 13
Team_Green
Banned!
MTF Member # 7124
Images: 2
Gaz, i have nothing to add to JDA's reply. BUT i am sure others would love this too. Some pictures of your part of the world. Can you snap a picture or two of your place? BTW come back to chat any time. It was nice talking with you.
Team_Green is offline   Reply With Quote Quick reply to this message
Old 08-05-2009, 09:23 PM   post #4 of 13
jd110
Senior MTF Member
jd110's Avatar
MTF Member # 6718
There were a couple of options on types of PTO. Do you have the lever that you pull up in between the gearshift levers? That is the independent pto. With that type, there is a brake band inside the transmission that stops the pto. It is applied using transmission oil pressure. Chances are that you have a broken band or a brooken oil line that sends pressure to activate it. Either pproblem requires splitting the tractor between the transmission and clutch housings. If you don't want to split tractor, there should be a disconnect lever by your left heel you can disegage to stop from turning.
Some of the 2030's had a two stage clutch, that requires pushing clutch all the way to the floor to disconnect the clutch and it used the same lever by your left heel to engage and disengage the gears. If this is the type you have, then either the clutch is stuck or out of adjustment.
jd110 is offline   Reply With Quote Quick reply to this message
Old 08-06-2009, 06:30 PM   post #5 of 13
gaz
MTF Junior Poster
MTF Member # 30517
Thanks, my tractor has not got a lever at my left heel. I think i am going to eventually split the tractor, have discovered a more worring problem there is a big crack in the head! I have stripped the head off and am leaving it with someone to weld it hopefully it works.
Old 08-06-2009, 09:22 PM   post #6 of 13
jd110
Senior MTF Member
jd110's Avatar
MTF Member # 6718
That's a little unusual for these to crack. Do you think it froze? Is it gas or diesel? Where is the crack?
Old 08-07-2009, 04:23 AM   post #7 of 13
gaz
MTF Junior Poster
MTF Member # 30517
I dont think there was enough antifreeze! I have included a few photos hopefully the crack isnt in a difficult place.
Old 08-07-2009, 04:27 AM   post #8 of 13
gaz
MTF Junior Poster
MTF Member # 30517
Dont think the photos worked by the way the tractors diesel petrol is way too expensive over here.
Old 08-09-2009, 02:44 PM   post #9 of 13
gaz
MTF Junior Poster
MTF Member # 30517
I have cleaned the crack up and grooved it to take the weld hopefully it holds.Attached a photo hopefully it works.
Old 08-09-2009, 08:55 PM   post #10 of 13
jd110
Senior MTF Member
jd110's Avatar
MTF Member # 6718
Be sure to replace the freeze plug that is visible in the photo. It looks like it is pushed half-way out. I assume you are going to use nickel welding rod?
Old 08-10-2009, 02:28 PM   post #11 of 13
gaz
MTF Junior Poster
MTF Member # 30517
I have left it with a neighbour hes a mechanic he says he'll use special cast rods. I spoke to a breaker he has a head but hes looking 150! another breaker has a head off a 2140 he said it should fit hes looking 80. Will try the welded head and see how it works first.
Old 08-10-2009, 04:33 PM   post #12 of 13
JD1010
MTF Junior Poster
JD1010's Avatar
MTF Member # 27034
Keep us posted, I hope it works. I spent some time in Europe, and know how expensive fuel was back then (about 15 years ago). Can't imagine it got cheaper.
Phil
JD1010 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 10-13-2009, 01:54 AM   post #13 of 13
BLUEPAINT
MTF Member
BLUEPAINT's Avatar
MTF Member # 4183
Images: 4
We had 5 2030's and 2130's over the years including a OPU cab with the pto on the dashboard and i think we did the pto brakes in all of them at some point.......Nice to see a duncan cab we still have a 2030 with this cab..!
BLUEPAINT is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
