Make your own Lawn mower Snow plow? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 08-03-2009, 06:45 PM   post #1 of 16
guinelle1
MTF Member
guinelle1's Avatar
MTF Member # 30446
Default Make your own Lawn mower Snow plow?
im thinking about getting a plow for my mower. but i had an idea. what if i cut a 55 gallon oil drum in half and welded some angle iron to it to make my own plow? anyone ever done this before?
guinelle1 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-04-2009, 12:29 AM   post #2 of 16
simplicityguy92
Senior MTF Member
MTF Member # 11189
Default Re: Make your own Lawn mower Snow plow?
id double the 2 halfs up oil barrels are pritty thin
simplicityguy92 is offline   Reply With Quote Quick reply to this message
Old 08-04-2009, 01:20 PM   post #3 of 16
Tractor-Holic
10,000 +posts!
Tractor-Holic's Avatar
MTF Member # 8867
Better off using an old hot water heater tank,air compressor tank,or a propane tank (but be careful cutting it,do NOT use a torch!--drill a starter hole and use a sawsall or sabre saw)..
The 35-55 gallon drums will work, but ARE very thin & flimsy and will need a beefy frame to surround it completely,its only good to "skin" the blade with--while the other tanks I mentioned are 1/8" to 3/16" thick and only need angle iron on the top,bottom and sides,the 55 gallon will need "ribs" in between too...you CAN make ribs from cut up car rims,but why go through all that work if you dont have too??..a section of a 275 gallon home heating oil tank is a good choice too,they are 3/16" thick..I have seen some nice plows made from large diameter pipe cut in half too..thick and heavy enough to need no reinforcing at all,just a push frame..
Tractor-Holic is online now   Reply With Quote Quick reply to this message
Old 12-19-2009, 03:47 AM   post #4 of 16
Saratoga
MTF Junior Poster
MTF Member # 22088
Using a saw or drill is putting you in danger as they have arcing at the brushes
To cut a tank first fill it with water and drain it then it is safe to cut
I did gulp the first time that I cut into a 500 gal tank with a cutting torch
Saratoga is offline   Reply With Quote Quick reply to this message
Old 12-19-2009, 07:02 AM   post #5 of 16
jayvee43
Proud Member of the 1K Club
jayvee43's Avatar
MTF Member # 18522
guinell1, you can make a blade out of a 60 gallons hot water tank, just like the one I made...
see attached picture.
jayvee43 is offline   Reply With Quote Quick reply to this message
Old 01-05-2010, 07:25 PM   post #6 of 16
orangekubota
MTF Junior Poster
MTF Member # 37033
any links to a step by step?
orangekubota is offline   Reply With Quote Quick reply to this message
Old 01-05-2010, 07:32 PM   post #7 of 16
stladrill
Run ahead of the pack
stladrill's Avatar
MTF Member # 31914
Images: 4
Garage
Quote:
Check that.
http://www.mytractorforum.com/showthread.php?t=101475
__________________
Forum Rules
Welcome Canadians Sign in!!
(Click on the image to get there)
The information provided is without warranty of any kind. In no event shall I be liable for any direct, indirect, incidental or consequential loss, damage, liability or expense incurred or suffered, claimed to have resulted from use of this information.
stladrill is online now   Reply With Quote Quick reply to this message
Old 01-05-2010, 08:12 PM   post #8 of 16
david doyle
MTF Member # 8803
xxxxxxxxxxxxxxxxxxxx
david doyle is offline   Reply With Quote Quick reply to this message
Old 01-06-2010, 12:21 AM   post #9 of 16
zack d
MTF Member
zack d's Avatar
MTF Member # 36547
buy a blower..
__________________
16g
165 massey
10 commercial
zack d is offline   Reply With Quote Quick reply to this message
Old 01-06-2010, 10:43 AM   post #10 of 16
orangekubota
MTF Junior Poster
MTF Member # 37033
Quote:
well being a noob to tractor implement construction I figured some pictures would help. I'm no stranger to fabrication but I was hoping for a little more. possibly angles, bracing, means of raising, lowering, etc.
Old 01-06-2010, 10:51 AM   post #11 of 16
stladrill
stladrill's Avatar
MTF Member # 31914
Images: 4
Garage
Did you go see post #7? you have a link to an other thread with picture
__________________
Forum Rules
Old 01-06-2010, 11:12 AM   post #12 of 16
orangekubota
MTF Junior Poster
MTF Member # 37033
Quote:
no I missed that. thank you.
Old 01-08-2010, 02:21 PM   post #13 of 16
GT_80
Cranky Motorsports
GT_80's Avatar
MTF Member # 35886
Images: 32
Garage
too bad you don't live in mass-I have an old 60 gallon air compressor tank i would give you !
__________________
MTF Addict #35886
Hugh-SS/16 fan #0001
Tractors:
1968 Super12 "Miss Emma Lee"
1967 Suburban 12 "The 679"
1973 SS16/ 18/6 hybrid "Mighty Mongrel"
1976 SS18 "Trusty"
1978 GT18 with Hard cab - home again!
Attachments:As many as I can get
My YouTubeMy Ebay
Sears Manuals
GT_80 is offline   Reply With Quote Quick reply to this message
Old 01-08-2010, 03:06 PM   post #14 of 16
orangekubota
MTF Junior Poster
MTF Member # 37033
Quote:
just push it and it'll roll downhill it should get here by next week
__________________
B6100 Kubota
Sponsored Links
Advertisement
Old 01-30-2010, 01:42 PM   post #15 of 16
Tonto
MTF Junior Poster
MTF Member # 37672
Getting past the shovel method- any ideas for a dirt/snow mover my 19.5 Craftman can handle ? Saw a movable blade with hand adjustments but lost the picture
Tonto is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
