Homelite super 2 gas mix? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 07-30-2009, 08:55 AM   post #1 of 33
Fireman993
Collector Of Junk!
Fireman993's Avatar
MTF Member # 30307
Default Homelite super 2 gas mix?
I recently "acquired" a home lite super 2 from a friends friend that passed away. I tuned it up and it runs good. But I cant find the gas mix anywhere for this saw. I've been using 40:1. Is this the right mix?
Fireman993 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-30-2009, 11:11 AM   post #2 of 33
DLF_IN
2000 Posts and climbing!!!
MTF Member # 1844
Default Re: Homelite super 2 gas mix?
The Super 2 I have calls for 32:1,but I have been running it on 40:1 with no bad side effects.
Dave
DLF_IN is offline   Reply With Quote Quick reply to this message
Old 07-30-2009, 01:07 PM   post #3 of 33
Fireman993
Collector Of Junk!
Fireman993's Avatar
MTF Member # 30307
Thanks A lot I was just worried that I might blow it up or something.
Old 07-30-2009, 04:45 PM   post #4 of 33
echoman
2 stroke enthusiast
echoman's Avatar
MTF Member # 6344
Images: 1
Todays higher quality oils will carry and support proper lubrication @ 40:1, but the saw was designed for 32:1 mix. You won't kill it on 40:1.
echoman is offline   Reply With Quote Quick reply to this message
Old 07-30-2009, 09:57 PM   post #5 of 33
cadman56
Senior MTF Member
cadman56's Avatar
MTF Member # 4627
I have an old Super 2 and a Super E-Z and I've been using Opti-2 in them for about a year now with no problems. In fact, I use this for all my two-stroke equipment with no problems. Here is the site if you want more info. What I like about it is one mix is good for all ratios.
http://www.opti2-4.com/html/opti-2.html
__________________
Grandpa Cadman56
1981 4211 11 hp / 36" deck
2003 Prestige 23 hp / 54" deck
2008 JD X728 27 hp / 62" deck / 45 FEL
JD JS60 Walkbehind
Echo SRM-2100
Echo ES-210 Shred-'N'-Vac
cadman56 is offline   Reply With Quote Quick reply to this message
Old 07-31-2009, 09:46 PM   post #6 of 33
M21BMR
Senior MTF Member
M21BMR's Avatar
MTF Member # 1964
I have a Super 2 also. I believe that the manual states something like 32:1 with Homelite "Premium" or 16:1 with anything else.
In mine, all I have used is Mobil 1 2T or Amsoil Saber mixed at 50:1. Mine hasn't had any issues running on this mix. As a matter of fact, I have a Homelite trimmer that recommends 32:1 also, and it is about 17 years old now and I have run it for years at 50:1 with synthetic. So, as the others have said, with any quality oil 40 or 50:1 should be fine for you.
M21BMR is offline   Reply With Quote Quick reply to this message
Old 08-01-2009, 09:52 PM   post #7 of 33
Fireman993
Collector Of Junk!
Fireman993's Avatar
MTF Member # 30307
Thanks For the advice guys. I was just worried I would mess it up. Thanks for reassuring me!
__________________
Some Of My Lawn-Boys (and others)
1972 8229B (D-448)
1979 R7268 (F-100)(Restored)
1985 7350 (F) (needs some work=
1986 7035 (F) (Daily Mower)
1987 Lawn-Boy 7073 (F) (parts)
1997 Toro 20481
10 Other 4 cycle mowers in pieces
Other Equipment
1992 Bolens Suburban ST 160 hydro w/ 16 HP B&S Vanguard w/42 inch Mower Deck
19?? White L-8 no engine ATM 32 in deck with bagger
Old 08-01-2009, 09:54 PM   post #8 of 33
Fireman993
Collector Of Junk!
Fireman993's Avatar
MTF Member # 30307
By the way any idea what year this saw is? I can't find too much info on it.
__________________
1972 8229B (D-448)
1997 Toro 20481
Other Equipment
Old 08-02-2009, 09:02 AM   post #9 of 33
Ironmower
Senior MTF Member
Ironmower's Avatar
MTF Member # 25539
First generation was built from '76 to 82
second generation was born in '91.
Ironmower is offline   Reply With Quote Quick reply to this message
Old 08-03-2009, 11:28 AM   post #10 of 33
Fireman993
Collector Of Junk!
Fireman993's Avatar
MTF Member # 30307
How do you tell which generation it is from?
__________________
1972 8229B (D-448)
1997 Toro 20481
Other Equipment
Old 08-03-2009, 10:42 PM   post #11 of 33
FergusonTO35
Junk collector
FergusonTO35's Avatar
MTF Member # 27883
Images: 2
Since yours is still running it is almost certainly a first generation!!
In all seriousness, the original 2 is my favorite saw of all time. My dad bought his new around 1980 and used it until 2004 when the part of the housing that holds the front handle broke off. The saw still ran, but was sans front handle. I don't know how many gigantic trees fell to that little bugger. Dad was never really careful about what fuel/oil mix he used in it, he usually just bought a little one gallon mix bottle and added that to the gas can. At any given time it could have been running from 12:1 to 50:1.
People go on and on about Stihl and Husky, but there was a time when Homelite ran with the best of 'em. I would love to see Homelite start making good products again. Not holding my breath, tho'.
__________________
1955 Harry Ferguson TO35
1990 Murray 12HP/38"
1996 Murray 8HP/30"
Lots of weedeaters, chainsaws, blowers
FergusonTO35 is offline   Reply With Quote Quick reply to this message
Old 08-04-2009, 12:28 PM   post #12 of 33
Fireman993
Collector Of Junk!
Fireman993's Avatar
MTF Member # 30307
So would I, They did make some good products.
__________________
1972 8229B (D-448)
1997 Toro 20481
Other Equipment
Old 08-04-2009, 05:20 PM   post #13 of 33
Ironmower
Senior MTF Member
Ironmower's Avatar
MTF Member # 25539
It would be nice.
Who did that song, I'm turning japenese, I'm turning japenese, I really think so. It was in the '80s also.
I'm startin' too think this also!
Old 08-04-2009, 06:43 PM   post #14 of 33
FergusonTO35
Junk collector
MTF Member # 27883
Images: 2
American saws started to go downhill in the 80's when they discovered they could make more money by designing out the quality and adding cheapness so they could sell machines en masse at department stores. One by one the American saws have fallen. McCulloch is now only a name applied to rebranded Poulans and some imported saws, Poulan itself is an ugly stepchild of Husky, and Homelite is only making a small product line for a single retailer.
__________________
1996 Murray 8HP/30"
Sponsored Links
Advertisement
Old 08-05-2009, 09:25 AM   post #15 of 33
M21BMR
Senior MTF Member
M21BMR's Avatar
MTF Member # 1964
Quote:
One major difference:
The older generation Super 2 saws have a magnesium case. The newer ones are plastic.
Mine is a UT-10521A. Several years ago when I got it, a Homelite dealer told me it was from 1981 based on the Serial number.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
