1086 International Clutch - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 07-15-2009, 10:09 PM   post #1 of 6
rangerss2
MTF Junior Poster
MTF Member # 29602
Help 1086 International Clutch
I am A displaced Hog farmer that has worked at our local hospital in engineering for past 15 years. I am getting back into ag in a small way. I used to have a 1066 international that used to be a very dependable workhorse. I am looking at a 1086 with 7500hrs on. It has a few issues I can repair myself. No water in oil and little blow-by. Clutch & TA seem to work OK, but I noticed that the transmission Lite comes on when clutch is engaged. The guy selling says thats Normal on a 1086. I plan to put a loader on it and will use it quite a bit that way. Am I going to have a problem. All feedback welcome. thks Old Wore Out Pig Farmer
rangerss2 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-15-2009, 10:12 PM   post #2 of 6
Bolens 1000
3K Poster!!!!
Bolens 1000's Avatar
MTF Member # 28563
Images: 14
Default Re: 1086 International Clutch
Welcome to the forum! I'm shure someone will be along to help shortly
__________________
Bolens Collection: 800, 850, 2 900's,1000 and 2 1050's
Bolens 1000 is offline   Reply With Quote Quick reply to this message
Old 07-15-2009, 11:04 PM   post #3 of 6
johndeere
3K Poster!!!!
johndeere's Avatar
MTF Member # 207
Images: 7
Yes it is normal for the trans light to come on when you push in on the clutch.We have a 3788 and the clutch is harder to push down when tractor is not running and you feel the pressure release after is starts and is running that is normal atleast on the 3788.
I am not sure if you would loose lifting capability with the clutch depressed or not on a 1086?I think it is still a live pump if it has the hydraulic flow controls for each remote I would think it would be?There located down near the floor on the right side on the hydrauilic console.
The biggest thing I do not like with the 86 and 88 series tractors is the shifting is hard.You really have to get mean with the selectors.We added a slick shift to ours.It a device the shifter makes contact with and presses a button and it takes away some of the grind you get.Shifting forward to reverse on unlevel ground can be agrivating.
The 1086 was a reliable tractor and there are still a lot of them around.
johndeere is offline   Reply With Quote Quick reply to this message
Old 07-15-2009, 11:53 PM   post #4 of 6
CowboyJoe
MTF Junior Poster
MTF Member # 29596
Yep, johndeere told you just about like it is. My 1486 did the same thing, and had the same knuckle busting shifters. The old 86 was a power house! It also liked diesel pretty well too, lots of it.
Joe
CowboyJoe is offline   Reply With Quote Quick reply to this message
Old 07-16-2009, 07:26 AM   post #5 of 6
dp in nd
MTF Junior Poster
MTF Member # 22678
Yes the trans light is susposed to come on when you depress the clutch pedal. As you are releasing the clutch pedal you want the light to go out just before the tractor starts to move when in gear. Then that part is adjusted correctly.
dp in nd is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-19-2009, 09:42 PM   post #6 of 6
Cowman67
MTF Junior Poster
MTF Member # 26028
The hydraulics will work fine with the clutch pedal depressed. You should be able to run a loader with no trouble. Yes shifting is a bear!!!!!
Cowman67 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
