Steering adjustment in my 316 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 07-12-2009, 01:00 PM   post #1 of 4
JimC_Vt
Senior MTF Member
JimC_Vt's Avatar
MTF Member # 24069
Default Steering adjustment in my 316
Hello Folks, While I have the motor on the bench (Telescopic Cylinder gauges have been ordered) I was wondering if there is a procedure to tighten up the steering gearbox on my 316 ???? It has a little slop in the wheel,nothing major ,but it could use some adjusting! Thanks ,Jim
JimC_Vt is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-12-2009, 01:26 PM   post #2 of 4
saleen49
Super Duper Member
saleen49's Avatar
MTF Member # 21045
Images: 2
Default Re: Steering adjustment in my 316
Quote:
If the set up is similar to the steering box on a truck, you want to make 1/8 to 1/4 inch adjustments until the play is gone. The only tractor I that I had to adjust was the JD 100 that I restored. It threaded in from the bottom of the shaft. I used this method to tighten it up.
__________________
1983 318.
2009 X729 with 54" deck & 54" blade, oh and 45 loader
__________________________________________________ __
"I have not failed. I've just found 10,000 ways that won't work." Thomas A. Edison
saleen49 is offline   Reply With Quote Quick reply to this message
Old 07-12-2009, 01:35 PM   post #3 of 4
saleen49
Super Duper Member
saleen49's Avatar
MTF Member # 21045
Images: 2
I meant to say 1/8 to 1/4 turn adjustments on the jam screw.
__________________
1983 318.
Sponsored Links
Advertisement
Old 07-12-2009, 03:08 PM   post #4 of 4
GR8racingfool
JD Green all the way~!
GR8racingfool's Avatar
MTF Member # 22107
I played with mine on my 300. I had to remove a cotter pin from the bottom, and then turn the entire bottom plug/piece a little bit, then line the splines back up, and reinstall the pin. It helped some, not much.
So, read the manual, and it said there were adjustments on the sides of the steering column. Removed the battery, the battery tray, and played with that some, better, but not perfect.
I have slop where you can turn the wheel left or right, before it even moves the front wheels. But all the adjustment I did, made the steering firmer, but easier. The slop is what drives me kinda nuts. But I cant get it any better, unless I am doing everything wrong, or there are some severely worn parts inside the gear box that need to be replaced.
~F~
GR8racingfool is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
