Farmall 560 with TA issues - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 07-09-2009, 09:26 PM   post #1 of 5
keevel
MTF Junior Poster
keevel's Avatar
MTF Member # 21745
Default Farmall 560 with TA issues
Greetings all,
I found a Farmall 560 with a loader about 100 miles away.
I haven't looked at it yet, but the owner says it starts and runs well. He also says "The TA works on the high side but not the low side." I'm a bit confused in that I thought the TA was the low side of each gear- the high side being direct drive. What could I be missing here? Anyplace you could recommend to me to learn all about Torque Amplifiers?
Thanks for your comments!
-Keevel
__________________
"My father kept me busy from dawn to dusk when I was a kid. When I wasn't pitching hay, hauling corn or running a tractor, I was heaving a baseball into his mitt behind the barn... If all the parents in the country followed his rule, juvenile delinquency would be cut in half in a year's time."
- Bob Feller Van Meter, Iowa - Pitcher Cleveland Indians; Baseball Hall of Fame Induction 1962
keevel is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-09-2009, 09:57 PM   post #2 of 5
xdiver86
2000 Posts and climbing!!!
xdiver86's Avatar
MTF Member # 2228
Default Re: Farmall 560 with TA issues
Keevel You are right. The high side is direct. For a better explaination see your friendly Case-IH dealer. At least this will let you know where you stand.
Aaron
__________________
Still looking at the green side of the grass Looked out the backdoor....My ain't it purtty out here!!
xdiver86 is offline   Reply With Quote Quick reply to this message
Old 07-09-2009, 10:55 PM   post #3 of 5
Grateful11
Grateful11's Avatar
MTF Member # 5025
Try here:
http://www.redpowermagazine.com/forums/
__________________
'11 John Deere 5065M /cab
'10 Kubota L3940 w/FEL
'09 JD X720
'91 CaseIH 5140 Maxxum w/cab
'78 IH 686 w/M&W Turbo 106 PTO hp w/canopy
Grateful11 is offline   Reply With Quote Quick reply to this message
Old 07-09-2009, 10:56 PM   post #4 of 5
Szrachnor
MTF Member
Szrachnor's Avatar
MTF Member # 29281
When the Torque Amplifier is in direct drive(or the handle is forward) you get the normal 5 speeds of the tractor. When the T/A clutch is disengaged(handle pulled back) then you go into low gear. In the attached picture when you are in direct drive item numbers 1, 16, 31, 32, 35, and 36 all spin at the same time, speed and direction as the engine. When you engage the T/A, you are releasing the clutch disk #35 so that pressure plate #36 and flywheel #32 stop spinning along with the planet carrier #16. The power then goes from clutch disk #35 through the shaft #31 into the planet gears #22, gets reduced by 1.482 to 1 and then comes out the shaft #1. At this point what is supposed to happen is that over-running coupler #11 is supposed to keep planet carrier #16 from spinning opposite of engine rotation. If the planet carrier #16 spins in the opposite direction then no power gets to shaft #1 and the tractor stops.
So the problem that the seller is describing is typical of over-running coupler(#11) failure. Although it's an easy fix, the amount of time to get to it usually makes most people either live with it or replace/rebuild the entire T/A while they have it apart. The tractor will continue to function as a normal 5 speed as long as you don't pull the handle back.
-Leon
Szrachnor is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-10-2009, 12:17 AM   post #5 of 5
keevel
MTF Junior Poster
keevel's Avatar
MTF Member # 21745
Thanks for the replies- love the attached exploded view Szrachnor- and the explanation. If the rest of the tractor is pretty sound, I'll probably pick it up and do a rebuild over the winter. The other tractor I was looking at was an IH 330 with minimal issues. I'll nose around the redpowermagazine forums and see what else I can learn.
-Keevel
__________________
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
