Best riding mower under $1500? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Backyard Round Table - L & G Tractor Related Topics Lawn and Garden Tractor Related Topics General Discussion Board
Reply
Thread Tools Display Modes
Old 07-08-2009, 01:39 AM   post #1 of 28
frozenpenguin
MTF Junior Poster
MTF Member # 29233
Default Best riding mower under $1500?
Hello all -
I'm a total newbie when it comes to tractors/riding mowers. I've used push mowers forever. But I've been thinking about getting a rider lately.
My yard is not big. Slightly under 1/2 acre. It does have a few failrly steep slopes though. My backyard is sort of shaped like a 3 sided bowl.
I've been doing some online research and found the Husqvarna YTH20K46 at Lowes. With a 10% coupon, this puts me right at where I want to be spending wise. Things I like about this one are the hydo transimssion, larger deck and the ability to easily mow in reverse, as I think I may end up needing that quite a bit.
Is this the best I can get for my money (under $1500)? Any better options out there? I'm pretty much clueless on this. Really I just want something that's going to do the job and last me a long time, with minimal problems.
frozenpenguin is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-08-2009, 02:05 AM   post #2 of 28
ohiocowboy1277
Senior MTF Member
MTF Member # 26703
Default Re: Best riding mower under $1500?
Im not sure what transmission that one has but alot of the lower end tractors might have a prob when it comes to hills most are meant for flat ground and mowing only my only concern would be the hydro going bad because of the hills . unless you are one of those people that cant even use a screwdriver without hurting yourself you would do alot better by buying used as you will get alot more tractor for the same or less as what you would spend on a new one then you wouldnt have to worry about those slopes so much . this is just my opinion but i would stay away from the hydro tractors in that price range as nice as it is to have i prefer gears because i have never had a problem with them and the craftsman i currently use is over 10 years old and has mowed almost 2 acres the whole time including the slopes i have in my yard
ohiocowboy1277 is offline   Reply With Quote Quick reply to this message
Old 07-08-2009, 06:52 AM   post #3 of 28
slkpk
USMC
slkpk's Avatar
MTF Member # 37
Images: 21
I would look for a good used GT just because of the steep slopes your talking about. Something like a JDGT, older Simplicity, Cub Cadet, Wheel Horse Case. slkpk
__________________
1964 JD RF110 Restored
2004 Ingersoll 318LGT @ the church doing the Lord's work
2007 JD 2305
It's too late to worry about it now!
slkpk is offline   Reply With Quote Quick reply to this message
Old 07-08-2009, 07:09 AM   post #4 of 28
munderhill
5000 Strong & Climbing
munderhill's Avatar
MTF Member # 3901
Images: 7
Depending on cut width needed and If your set on new and want a tough built machine, look at a Snapper rer. Once you get past the quirks, they are one tough/well built machine. The baggers perform excellent and cut is nice and even.
I think an electric start 28" model starts at $1500.00.
MU
munderhill is offline   Reply With Quote Quick reply to this message
Old 07-08-2009, 07:29 AM   post #5 of 28
Kbeitz
Collector of many tractors
Kbeitz's Avatar
MTF Member # 86
Images: 4
The best for your money is something used....
__________________
Kbeitz is offline   Reply With Quote Quick reply to this message
Old 07-08-2009, 07:53 AM   post #6 of 28
WVdeerehunter
____________________
MTF Member # 5688
Here's a great example.
http://philadelphia.craigslist.org/grd/1253884573.html
Good luck on your search.:
WVdeerehunter is offline   Reply With Quote Quick reply to this message
Old 07-08-2009, 08:03 AM   post #7 of 28
FrankMA
Proud Member of the 1K Club
FrankMA's Avatar
Location: Merrimack Valley in Northeastern Massachusetts
MTF Member # 10550
If it has to be new, the biggest bang for your buck is a Craftsman GT. Any of the used one's suggested by slkpk are going to be much better than anything new in that price range. You can get a real good, used GT for $ 1,500.00.
__________________
2002 Toro Wheel Horse 522xi
Honda HS928TA Snowblower
Honda HS621AS Snowthrower
Honda HS520A Snowthrower
Honda HS624WA Snowblower (Sold 8/23/2010)
Honda EM6500SX Generator
Stihl BR550 Backpack Blower
McCulloch MS1635 Chainsaw
Weedeater SST25 Line Trimmer
"It is what it is!"
FrankMA is offline   Reply With Quote Quick reply to this message
Old 07-08-2009, 08:15 AM   post #8 of 28
jeepersmitty
Retired Aug.31 2007
jeepersmitty's Avatar
MTF Member # 6130
Images: 2
I will go against the grain and tell you that for your size of yard, I thank the tractor will do fine.The hydro transmissions are not as delicate as everyone likes to put on. As long as you use it for what it was designed for it will do fine.
__________________
I always know...
God won't give me more than I can handle
There are times I just wish He didn't trust me quite so much.
jeepersmitty is offline   Reply With Quote Quick reply to this message
Old 07-08-2009, 08:59 AM   post #9 of 28
2tractors
Senior MTF Member
2tractors's Avatar
MTF Member # 4606
Images: 2
Now why can't I find something like that,
__________________
" From my cold dead hands" Charlton Heston 2003
2tractors is offline   Reply With Quote Quick reply to this message
Old 07-08-2009, 09:05 AM   post #10 of 28
ggsteve
ggsteve's Avatar
MTF Member # 9436
Garage
Welcome to the forum. There is a lot of value in buying the RIGHT used garden tractor but there are often things that will have to be fixed on a used machine, often minor but sometimes major. Assuming as a newbie you don't want to deal with that, then lets think new for a minute.
The Husqvarna you speak of is made in the same factory as the Craftsmans, so look and see which has better specifications or features you like at that price point and buy which ever model it is. They share many components and will share attachments, baggers, etc as well. The new John Deeres in this price range aren't going to be better than anything else in quality, and I think you will spend $100-200 for the paint, although you'll get more of that back if you sell it later.
I am a little concerned about the hydro and your hills, but not enough to recommend against it. My hydro transmission is one of the best things about my Craftsman Pro, I would never go back to gear drive after using the hydro, it's way too convenient. I like the foot pedal drive, but many others like the fender control, that's personal preference. I like having my hands free for dealing with attachments.
In this price range you should be able to get:
42-50" deck, maybe even 54" but that takes more hp to run
15-24hp engine (probably a B&S Intek or ELS, or Kohler Courage or Command)
a LAWN tractor hydro transmission (NO ground engagement, light towing)
a lightweight frame, but look for one that's welded
cast iron front axle, don't buy the stamped steel axle Ariens or Troy-built
3+ gallon gas tank
a nice, cushy, sliding seat
Cruise control (useless feature)
Headlights
Things you probably/definitely won't get at $1500
Electric PTO (I would pay $100 more for this feature, some don't like it)
Power deck lift
Ground engaging transmission
A zero turn mower of any type
Shaft drive (thousands more)
One more thing. If you buy a member of the Husqvarna/Craftsman/Poulan/Ariens group, or a JD, there will be lots of used attachments out there to buy for them. Other brands will have less stuff on the used market. Buying used attachments is relatively safe because most of them don't have motors that could be trashed.
Good luck in your search. You can make your second tractor purchase a used one (once you start there's no turning back). Remember when your done!
__________________
ggsteve
08 Craftsman Professional 24hp B&S ELS 42" deck 3 bin bagger Berco 44" blower & 48" blade OTC cab
68 JD 112H 47 deck 43 blade
69 JD 110H 37A blower 50 cart
71 JD 140H3 integral hitch 54" 4-way blade 46" deck cozy cab
71 JD 140H1
72 JD 110 parts
78 JD 316K 49 blower
81 JD 317 Onan JB Sr. 46" deck 80 Cart
84 JD 214 39 deck 43 blade
86 JD 318 3pt
Toro 212-5 36" blower
74 Concord (MTD) 990
12 cu. ft. poly cart, JD front dethatcher, plug aerator, drop spreader, box blade, 10" bottom plow, sweeper
ggsteve is offline   Reply With Quote Quick reply to this message
Old 07-08-2009, 09:06 AM   post #11 of 28
Glenn M
Glenn M's Avatar
MTF Member # 9020
Images: 14
http://southbend.craigslist.org/grd/1257309897.html
OR
http://southbend.craigslist.org/grd/1253335515.html
__________________
Glenn
It's never over untill your pockets are empty.
My GT pic's
07 DGS 6500
74 MTD 990
71 MTD 760
91 Craftsman GT6000
JD "80" cart
Glenn M is offline   Reply With Quote Quick reply to this message
Old 07-08-2009, 09:40 AM   post #12 of 28
*chris*
Senior MTF Member
MTF Member # 25549
Do you have some pictures of your yard?
Do you want an appliance to mow your lawn, or do you like to tinker?
Can you do, do you want to do your own repairs?
If you want to mow it and forget it, the new Husqvarna is the way to go. If you don't mind working on equipment or making minor repairs one of the used JDs listed above would be much better for the money.
Chris
__________________
John Deere 7 5 0
Bobcat 36" Walk Behind
Scag 52" ZTR
John Deere (Bunton) 52" Walk Behind
*chris* is offline   Reply With Quote Quick reply to this message
Old 07-08-2009, 11:54 AM   post #13 of 28
tcanthonyii
Snapper Lover
MTF Member # 23497
Craftsman. I think you can get better discounts on them over the Huquavarna's and they are basically the same. Tons of attachments and they will last for a very long time so long as you take care of it. That's the key to the cheaper mowers.
T.C.
tcanthonyii is offline   Reply With Quote Quick reply to this message
Old 07-08-2009, 12:06 PM   post #14 of 28
c1tobor
Senior MTF Member
c1tobor's Avatar
MTF Member # 24002
Yikes Re: Best riding mower under $1500?
While there is no doubt you will get more tractor used, If you want to go new I'll defend the Quality of the entry level Deere's. While all the low-end LT's are "about the same" I think Deere does have better quality overall.
I suggest making a list of all Models/Makes and searching Consumer Affairs, paying close attention to the Dates associated with the complaints.
I drove myself half crazy trying to decide on a mower with pretty much the same criteria as yourself.
I myself think that JD does edge out the others in quality and design in this entry level tractor market....JMHO....
c1tobor is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-08-2009, 12:42 PM   post #15 of 28
Wizard99
Wizard99's Avatar
MTF Member # 13982
Images: 12
Does John Deere even have a mower under $1500, maybe a RER. My Sabre 17 HP 42" hydro was over $2000. Maybe if you go with a junk cheap standard transmission.
__________________
remember kids, just say no to scrappin tractors
Wizard99 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
