Shindaiwa Clutch Removal - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 07-07-2009, 04:02 PM   post #1 of 12
LB10247
Senior MTF Member
LB10247's Avatar
MTF Member # 29185
Default Shindaiwa Clutch Removal
New member here, I joined because of all the great Lawn Boy resources but I also have a chainsaw I need help with. I am trying to remove the clutch from my Shindaiwa 345. I assume there is a special tool needed, but does anyone have any do it yourself ways to get it off? I already have the piston locked, I just can't get a way to break the clutch loose. Attached is a pic of what it looks like. Thanks in advance for the help!
LB10247 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-07-2009, 05:58 PM   post #2 of 12
rscurtis
5000 Strong & Climbing
MTF Member # 25367
Default Re: Shindaiwa Clutch Removal
It is most likely screwed onto the crankshaft with a left-hand thread- turn clockwise to remove.
rscurtis is offline   Reply With Quote Quick reply to this message
Old 07-07-2009, 06:36 PM   post #3 of 12
FergusonTO35
Junk collector
FergusonTO35's Avatar
MTF Member # 27883
Images: 2
There is a video on Youtube showing how to remove the clutch on a Husky that has the same type of clutch.
__________________
1955 Harry Ferguson TO35
1990 Murray 12HP/38"
1996 Murray 8HP/30"
Lots of weedeaters, chainsaws, blowers
FergusonTO35 is offline   Reply With Quote Quick reply to this message
Old 07-07-2009, 09:31 PM   post #4 of 12
LB10247
Senior MTF Member
LB10247's Avatar
MTF Member # 29185
It is definitely a left hand thread, but there is no real way to get a wrench on it.
Ferguson - do you happen to have a link to that video, I checked Youtube and couldnt find anything under "husky chainsaw clutch". Thanks a lot for your help!
Old 07-07-2009, 10:03 PM   post #5 of 12
engine2quarters
MTF Member # 24003
Rubber strap wrench.
engine2quarters is online now   Reply With Quote Quick reply to this message
Old 07-08-2009, 12:49 AM   post #6 of 12
FergusonTO35
Junk collector
MTF Member # 27883
Images: 2
Here ya go:
http://www.youtube.com/watch?v=cdqkIuVNUQc
Type in "chainsaw clutch" and several other videos come up also.
__________________
1996 Murray 8HP/30"
Old 07-08-2009, 01:19 AM   post #7 of 12
amf1414
certified tractor nut
amf1414's Avatar
MTF Member # 26032
if you plan on replacing the clutch while its off you can remove it one of two ways. weld 2 bolts directly across from eachother and use a pry bar tu turn it. or method #2 drill 2 holes across from each other and insert 2 bolts in the holes and then use a pry bar to turn the clutch. hope this helps
amf1414 is offline   Reply With Quote Quick reply to this message
Old 07-08-2009, 03:18 AM   post #8 of 12
FergusonTO35
Junk collector
MTF Member # 27883
Images: 2
I don't know if this would work but maybe a blunt punch could be used to tap the edges of the clutch shoes in the correct direction. By the way, how old is that saw?
__________________
1996 Murray 8HP/30"
Old 07-08-2009, 09:45 AM   post #9 of 12
LB10247
Senior MTF Member
LB10247's Avatar
MTF Member # 29185
I thought of a rubber strap wrench but the clutch drum spins free so there is nothing to grab onto.
Ferguson - thanks for the link - Husky = Husqvarna, I shoulda guess that. I tried (very lightly) to knock on the clutch shoes, but I really didnt know if they are durable enough to be hitting on them. Are they usually solid enough to not risk breaking anything if I hit at them with a punch etc? I really dont know much about chainsaws in general, or this saw. Its a Shindaiwa 342, I got it from a friend who tried to get it going but to no avail. I always have a need for a small chain saw and as a freebie this one seems pretty nice. Its in really solid shape, but has been neglected. I took the entire saw apart to clean it out since it was full of greasy sawdust, and the entire fuel system had turned to rubber goo! I will attempt again to knock on the clutch shoes with a little more force this time. Thanks again for the help, I will report back later.
Old 07-08-2009, 06:32 PM   post #10 of 12
FergusonTO35
Junk collector
MTF Member # 27883
Images: 2
I would try knocking the clutch shoes with a punch, I would bet thats how most Shindaiwa techs do it. That said, I can't guarantee the results as I've never removed this type of clutch before, all my saws use a nut. I would advise you to locate a new clutch and drum and be willing to buy it if necessary. The saw appears old enough to where replacement would be a good idea.
__________________
1996 Murray 8HP/30"
Old 07-08-2009, 10:37 PM   post #11 of 12
LB10247
Senior MTF Member
LB10247's Avatar
MTF Member # 29185
Ferguson - Thanks for all the help. I tried a punch, and it just didnt feel right, I could get a good enough hit on it. So I made up a small "jig" in my vise to lock the clutch shoes and I was able to twist the clutch right off. It looks to all be in good shape but I will definately double check everything out before it goes back together. Thanks again for all the help and advice!
Sponsored Links
Advertisement
Old 07-09-2009, 01:24 AM   post #12 of 12
FergusonTO35
Junk collector
MTF Member # 27883
Images: 2
Good job, bro.
__________________
1996 Murray 8HP/30"
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
