Repair hour meter/tachometer? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 07-05-2009, 07:40 AM   post #1 of 5
sy308
JD 430, 855, 650
MTF Member # 29077
Default Repair hour meter/tachometer?
My JD 650 suddenly had the tachometer fail. Not that you really need it, but the hour meter was frozen and I keep track of that for maintenance purposes. I obtained a replacement from JD, had no problem replacing the cable but discovered the cause of the problem was the meter itself. The cable broke at the takeoff for the motor, but the meter would no longer turn. I thought about disassembly as I have watch repair experience, but it looked like no obvious way to get at the insides. The glass appeared to be glued on. My solution was to let it set with JD penetrating oil, crank the meter by hand with vice grips attached to the new cable. I oiled it and it now works fine. Questions from me, how does one remove the glass from the meter and should the meter need attention again is it possible to clean the unit or is it permanently sealed? Thanks. We are now back to cutting with my favorite tractor, 24 years old and still going strong!
sy308 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-05-2009, 08:21 AM   post #2 of 5
mark777
Administrator
mark777's Avatar
MTF Member # 252
Default Re: Repair hour meter/tachometer?
Welcome sy308!
I've had two in six years, that froze and broke the tach cable.
It's been my experience, and after working on a few of the meter 'heads' the entire clock is built, glued, and then pressed together. The bezel, glass and thin gasket is pressed and crimped on to the can. Even low heat gently applied around the face front have given me zero results.
IMO, they are tamper proof and once they fail you have little option but to replace the entire meter assembly.
Mark
mark777 is offline   Reply With Quote Quick reply to this message
Old 07-05-2009, 08:41 AM   post #3 of 5
JDFANATIC
9K+ Poster
JDFANATIC's Avatar
MTF Member # 41
Images: 1
Garage
sy,
Welcome to the forum!
__________________
Cheers
JDFANATIC
JD2210, loaded tires, 62C MMM, 210 Loader, 47" Snowblower, York Rake, PTO Spreader, Heated Cab, JD Plug Aerator, FIMCO Sprayer, Wheel Spacers, FEMCO Folding ROPS, JD Cart, Stihl MS170 and HT101, Wallenstein BX32 PTO Chipper
JDFANATIC is online now   Reply With Quote Quick reply to this message
Old 07-05-2009, 09:10 AM   post #4 of 5
danbike
Bikes/Tractors what else
danbike's Avatar
MTF Member # 1530
Some of the tachs/speedos on Brit bikes use a roll on type of retaining ring on the glass bezel. If you can find a shop that fixes Brit Bike gauges, they might be able to help.
__________________
2005 JD X585
2011 Triumph T100
1967 Triumph TR6R-all original and gone to a new home
19XX VESPA PX200EFL
1964 Vespa GL(oldest original owner Vespa in the US)
danbike is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-06-2009, 07:54 AM   post #5 of 5
sy308
JD 430, 855, 650
MTF Member # 29077
Thanks for the replies guys!
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
