Checking/Adding Transmission/Hydraulic Oil? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 07-04-2009, 12:34 AM   post #1 of 6
vern6973
MTF Junior Poster
MTF Member # 28130
Default Checking/Adding Transmission/Hydraulic Oil?
Hi:
I have an 1966 International 606 tractor, this tractor was manufactured with the same engine put in the 460 model ... 60 HP six cylinder gas engine:
Does anyone have answers to one, some or all of my questions?
Does the tractor use the same oil for the transmission and hydraulics?
Where and how do I check the oil levels?
Where do I add the oil(s)?
Is there any oil additives available to stop minor transmission oil leaks?
Vern
I am an Oil Disabled MTF Member
vern6973 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-04-2009, 08:19 PM   post #2 of 6
parts man
2000 Posts and climbing!!!
parts man's Avatar
MTF Member # 9
Default Re: Checking/Adding Transmission/Hydraulic Oil?
Vern, I'm sorry but I'm not familiar with the 606, never been around one, but I'm sure someone here will be able to help you out on specifics, but on the stopleak type stuff, I'd avoid it because it will also plug things that aren't supposed to be.
__________________
VP of TSA (takin stuff apart)
Need parts? Check out
parts man is offline   Reply With Quote Quick reply to this message
Old 07-04-2009, 10:46 PM   post #3 of 6
xdiver86
xdiver86's Avatar
MTF Member # 2228
Vern...Stop by your friendly Case-IH dealer. My 806 takes hytrans. The tran s and hyd run off same reservoir. Fill thru where dip stick for trans is. Be sure and change the trans filter, See your friendly Case-IH dealer for proper filter and gaskets.
__________________
Still looking at the green side of the grass Looked out the backdoor....My ain't it purtty out here!!
xdiver86 is offline   Reply With Quote Quick reply to this message
Old 07-05-2009, 12:16 PM   post #4 of 6
vern6973
MTF Junior Poster
MTF Member # 28130
Quote:
Do you know of anything on the market that can be applied (on the outside cast iron) to stop the oil from hoozing out ... I've zeroed in on the leak.
Vern From Illinois
Old 07-05-2009, 12:25 PM   post #5 of 6
vern6973
MTF Junior Poster
MTF Member # 28130
Quote:
The only place I see were I could add trans/hyrd oil is near the shifter ... the old style shifter ... not on the dash like your 806. There is an open ended "breather pipe" attached to the opening ... not sure why the pipe is there ... seems like it would let contaminates in. Anyhow there is no dipstick in this hole ... maybe you just eyeball the level. I have an owners manual but the dumb thing does tell you how to check or add oil. Any more thoughts?
Vern
Sponsored Links
Advertisement
Old 07-08-2009, 03:23 PM   post #6 of 6
Szrachnor
MTF Member
Szrachnor's Avatar
MTF Member # 29281
If you have a hydraulic pump inside the clutch housing, a torque amplifier, or a rear lift mechanism(like 3 point hitch) then you use HyTran or similar product. If all 3 of these things are not on the tractor then you can use gear oil.
The oil filler is the big square-indented pipe plug by the shifter.
The oil level check is on the rear end housing. I believe it is a 1/2" square-headed pipe plug on the left hand side near the running board. That machine takes about 12 gallons of oil, fill it up until the oil is just below the pipe plug opening.
Additives don't usually stop major leaks like on rear axles and brake shafts. Only way to fix it is to replace the seal and possible the worn out bearing behind the seal.
-Leon
Szrachnor is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
