white vinegar vs round up - Page 3 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 02-11-2010, 06:44 PM   post #31 of 55
Argee
Anything With Wheels
Argee's Avatar
MTF Member # 5
Images: 11
Default Re: white vinegar vs round up
I missed this when it was first posted. I saved this article a long time ago. I have no idea who the author is, but it is great eco friendly remedies.
Quote:
The 7 Deadly Homemade Weed Killers
  1. Boiling Water - Yep, thatís right. Plain old H2O can be used as an extremely effective weed killer. As a matter of fact, boiling water is more effective than many of your store bought weed killers in wiping out unwanted vegetation. Easy-peasy to do. Put a kettle of tap water on the stove and heat till boiling, then pour on the weeds you wish to kill.You are effectively cooking the plant in the ground. Boiling water is a great way to clear out vegetation on a wholesale basis, like driveways and sidewalks. But be warned, boiling water is not selective. It will cook and instantly kill any plant that it comes in contact with and this includes underground roots of nearby plants.
  2. Bleach - Not only is bleach a spot remover, it is a weed remover as well. Place some bleach in a spray bottle and spray on the weed you wish to remove. The bleach chemicals will evaporate or dissipate in about two days (or less but better safe than sorry), making the area safe for planting. Again, bleach will kill anything but if you do get some on a plant you want to keep, just wash the plant off.
  3. Vinegar - Vinegar is a great organic homemade weed killer. Either white or cider vinegar will work. The acetic acid in the vinegar works to kill the leaves on the plant but not the root. Vinegar will kill back (kill the leaves but not the root) any plant but works best on young plants because they do not have enough energy stored in the roots to regrow their leaves. If vinegar is applied to more established weeds enough times, the plant will eventually deplete its stored energy reserves and die.
  4. Salt - It was once a known war tactic to salt the fields of enemies. Salting the earth was also used as punishment for severe crimes in several countries throughout history. The reason is because salt will kill plants and will make the ground unsuitable for future plant growth. On a small scale, you can drop a small pinch of table salt at the base of the undesirable plants. It will kill the plant but will dilute down to harmless in the next few rainfalls. On a larger scale, you can cover your gravel driveway or your exís yard with a good amount of salt and nothing will grow there for months. (FYI, it is illegal to salt another personís property. Itís called vandalism.)
  5. Rubbing Alcohol - Rubbing alcohol is used around the house because it draws water out and helps to evaporate it quickly. Guess what? If you put it on a plant, it will do the same thing. You will be basically sucking the life blood out of the weed. Makes you want to run right out and try it, huh? But again, rubbing alcohol is non-selective. It will kill any vegetation it comes contact with.
  6. Corn Meal - Corn meal doesnít really kill weeds, it just stops the weed seeds from ever developing. Corn Gluten is a pre-emergent, which is a fancy way of saying that is it is a seed birth-control. Corn meal scattered around an area will keep any seed in that area from growing into a plant. This means a weed seed or a desirable seed. This method is a good option for areas that you plan on planting grown plants in.
  7. Newspaper - If murdering your weeds with chemicals is not your style, you can always smother them. Laying down a layer of newspaper at least 4 sheets thick (the more the better) will go a long way towards killing the weeds underneath. The weeds that are already there will die from lack of sun and the weed seeds will not be able to sprout because they are not getting any sun to start with.
__________________
Randy G
Argee is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-11-2010, 06:44 PM   post #32 of 55
Alan in Vermont
Senior MTF Member
Alan in Vermont's Avatar
MTF Member # 18320
Crop Production services has branches in all the lower 48 states and markets their Glyphosate herbicide as "Makaze". Quite a lot cheaper than the Monsanto original even though you need to mix it a little stronger to get the same burndown time. If you're tyring to do selective control you can rig an inverted funnel on your sprayer wand for a shield. Set the funnel firmly down on top of the target and give it a shot as quick as you can squeeze and release the valve. I was able to nuke crabgrass clumps growing tight to cornstalks with no crop damage.
Alan in Vermont is offline   Reply With Quote Quick reply to this message
Old 02-11-2010, 09:36 PM   post #33 of 55
david doyle
MTF Member # 8803
Quote:
I use approx 10 liters of any brand a year mixed in a 62 gallon 3pt sprayer to cover 10 acres
Your right on the prescription for annual weeds! Nice to see someone measuring!
Bet your nieghbours appreciate not having to run you out of the county for being a weed source LOL.
david doyle is offline   Reply With Quote Quick reply to this message
Old 02-21-2010, 02:23 PM   post #34 of 55
captndan
Senior MTF Member
captndan's Avatar
MTF Member # 38861
This year glyphosate was selling for $41.00 for 2.5 gal. It's a good product if used properly. The best you can buy is 41% without a license. Anything less 41% may have undesirable results.
captndan is offline   Reply With Quote Quick reply to this message
Old 02-23-2010, 12:06 PM   post #35 of 55
BanjoBob
MTF Junior Poster
MTF Member # 37779
There is evidence that plants will adapt to most chemcials like glyphosate. Look at the fields of roundup ready beans and corn. Lots of weeds out there, more every year. For 55 years I have hoed in gardens and small fields, used cultivators and wheel hoes all the while keeping my eyes on the garden for pest, malnutrition in the plants. The old proverb, there is no better fertilizer for a garden than the footsteps of the gardener is still true.
Bob
BanjoBob is offline   Reply With Quote Quick reply to this message
Old 02-23-2010, 11:23 PM   post #36 of 55
Tencubed
3K Poster!!!!
MTF Member # 31735
Quote:
Originally Posted by papa smurf View Post
will that stuff kill locust trees?
There are a few different kinds of locust around but the black locust we had in our front yard were very difficult to kill. I would cut them down and back they would come. Sprayed them, mowed them, ground the stumps, burned stumps, drilled holes in stumps and filled them with oil all to no avail. Then I tried roundup at half strength, idea from a neighbor, and let them get sick for a couple of weeks. Came back and hit them with the weak solution again and that killed them. No re-growth at all. Apparently the half strength mix allows the poison to be drawn deep into the root system and eventually kills the tree.
Since I started doing this, and now I spray the full size tree and kill it prior to cutting it down, I've had way less problems with any brush or tree I want to murder.
Not an instant knock down and turn brown system but it seems to work well.
Mike
Tencubed is online now   Reply With Quote Quick reply to this message
Old 04-10-2010, 04:56 AM   post #37 of 55
Kiwi Will
MTF Junior Poster
MTF Member # 29164
25 yrs back, I used to spray about 5 x 20 litre containers of Roundup per 6 months at half strength on a large sub tropical orchard here in NZ. If timing it right, I used to spray twice a year (before grasses/weeds flowered) and use only drip irrigation. 3 times per yr if I was slow getting to it. If knocking down fresh pasture, I'd increase strength to 75%.
I found calibration of the tractor spraying system well worth the effort. Over spraying gets so costly and also is not good environmentally.
Now I'm off the orchard and practice organic methods for virtually every thing around the yards I care for. What BanjoBob (2 above) wrote, 'is dead on the nail' in any land based farming or care because we are only here on our little patches of dirt for such a short time. It absolutely horrifies me to read about those who practice salting of the soils. I learnt the problems that drip irrigation has on the soils when orcharding, especially when over watering.
If wanting to kill grasses/weeds, like one chap wanted around a vehicle stored for a long period of time, I'd suggest laying down black plastic or old woolen carpet down then. (or a goat) When black polythene plastic is used, & the soil is wanted to be used for growing again, its simple and VERY cost effective. Newspaper is ok & certainly works wonderfully but generally I find it rots down pretty quick and unless a mulch is placed on top, such as pine bark chips which is commonly used here in NZ. Another product used is sea shells (usually crushed) or a layer or small (>half inch) peebles.
Up my drive way, I've taken to hot water for areas where paving stones and concrete is and a push hoe for broader spaces of gravel & peebles.
Will
Kiwi Will is offline   Reply With Quote Quick reply to this message
Old 04-10-2010, 09:22 AM   post #38 of 55
grnspot110
3K Poster!!!!
grnspot110's Avatar
MTF Member # 4515
Images: 21
Garage
Quote:
Originally Posted by Chuck_050382 View Post
chainsaws?
Better put a little Tordon on the stumps!
__________________
Home of the JD L/60 "Custom" & the 70 I!
grnspot110 is online now   Reply With Quote Quick reply to this message
Old 05-05-2010, 04:32 AM   post #39 of 55
tea4me
MTF Member
MTF Member # 40146
Quote:
Originally Posted by oldtimer View Post
I used straight vinegar on weeds in the driveway and poison ivy in back of the garden and it worked great.only took afew days to work,too. Maybe it depends on the weeds ??
It might depend on the type and brand if vinegar one uses. What did you use? I use bleach in a sparay bottle on the weeds in the seems in the cement and street. Cheap and it realy works. It kills the seeds that have not sprouted. We don't use anything else. We have city landscaping and no fence rows or barn yards.
Speeking of organic which is a huge joke in may ways. A friend of mine is a CPA. He has a client that owns a chicken ranch. The organic chickens are always sick and deseased. They have one heck of a time getting them to market. They are a loss leader and they are going to stopp selling them. They cost over twice what the regular chickens cost to produce. Organic is a gimmick. Just another way to part you from your Green Backs.
tea4me is offline   Reply With Quote Quick reply to this message
Old 05-06-2010, 02:39 PM   post #40 of 55
chvymn99
Senior MTF Member
chvymn99's Avatar
MTF Member # 18386
Quote:
Yea, that stuff is awesome. A little bit goes a long ways.
chvymn99 is offline   Reply With Quote Quick reply to this message
Old 05-06-2010, 03:56 PM   post #41 of 55
captndan
Senior MTF Member
captndan's Avatar
MTF Member # 38861
Unfortunately there is a lot of fraud surrounding organic. If the word " organic" is used on a product the grower or producer must have an "organic" license issued by the FDA. If you are suspecting something funny ask for the organic license number. If they can't give a number threaten to call the Feds. Actually reporting the producer is a waste of time because that department is very understaffed. `The best way around this problem is to buy locally grown or raised products. Eat healthy live longer.
Old 05-07-2010, 06:23 PM   post #42 of 55
Kiwi Will
MTF Junior Poster
MTF Member # 29164
Care is definitely needed if you consider using Tordon. I used to use it years ago but now shy away from all industrial chemicals after learning about them and the long term effects.
Sure it works but I suggest you do a search on its active ingredients.
If you have young ones around or want to enhance the soils near where you use it, I'd be surprised if you chose to use it after doing a 'search'.
Old 05-08-2010, 12:44 PM   post #43 of 55
smokey831831
MTF Junior Poster
MTF Member # 40531
Vinegar, salt and a little soap for surface adhension will do the trick but multiple applications are neccessary. The bleach thing works too but can be deadly to animals as well.
smokey831831 is offline   Reply With Quote Quick reply to this message
Old 05-09-2010, 04:17 PM   post #44 of 55
MontyJ
Senior MTF Member
MontyJ's Avatar
MTF Member # 28383
The only real difference between Round-up and the generic varieties is the addition of a spreader/sticker. A small amount of dish soap works wonders. As far as bleach goes, do you really want that in the soil where you may grow grass later? In any event, neither Glyphosate nor bleach are "organic". Vinegar and salt will usually kill most weeds, but the salt will remain in the soil as a chloride and do a lot of damage to grass later.
__________________
2010 Cub Cadet LTX1046VT
1985 Troy Bilt Horse II Tiller
<---Yeah, it's a real pumpkin. Weight...1095 pounds
MontyJ is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-09-2010, 05:02 PM   post #45 of 55
building the dream
MTF Member
building the dream's Avatar
MTF Member # 36453
there are some chemicals out there that with just a mist on the leaves of up 6" tree will kill it or at least stunt its growth for a few years. i have worked in areas where 20-80 acres looked like there was a fire on the forest floor. pretty awesome stuff if used correctly!
__________________
bolens 1050 (for sale not running)
two 1453 bolens g14's, blower, tiller, mower and plow
building the dream is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
