Home made wasp spray - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
My Place Pics and stories about your home and property
Reply
Thread Tools Display Modes
Old 05-24-2009, 02:18 PM   post #1 of 30
danbike
Bikes/Tractors what else
danbike's Avatar
MTF Member # 1530
Default Home made wasp spray
I had read that a solution of liquid soap in water could be used for wasps. If this is correct it would be better for all than some other sprays, but ONLY if it works. Anyone else ever try it?
__________________
2005 JD X585
2011 Triumph T100
1967 Triumph TR6R-all original and gone to a new home
19XX VESPA PX200EFL
1964 Vespa GL(oldest original owner Vespa in the US)
danbike is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-24-2009, 02:22 PM   post #2 of 30
JD2030
Senior MTF Member
JD2030's Avatar
MTF Member # 7533
Images: 2
Default Re: Home made wasp spray
I have never tried soap and water but I know Starting Fluid, and gas works real well!
JD2030 is offline   Reply With Quote Quick reply to this message
Old 05-24-2009, 02:38 PM   post #3 of 30
Justin
Father to Triplets + 1
Justin's Avatar
MTF Member # 19622
I think soapy water is only good for the traps. It makes them sticky and makes it harder to get out. I think if you spray them with it you will only make them mad. I could be wrong though.
__________________
74 Sears ST 16 with automotive ignition conversion, 10" moldboard plow, cultivator, hiller, single disk with 2 cinder blocks, 42" MMM, middlebuster, manual 3pt hitch, Ag tires with wheel weights and tri ribs on the front
Justin is offline   Reply With Quote Quick reply to this message
Old 05-24-2009, 02:41 PM   post #4 of 30
LLigetfa
standard issue neuralyzer
LLigetfa's Avatar
MTF Member # 15283
Images: 2
I use a bit of Sunlight dish soap and water in a garden sprayer. It works very well but for obvious reasons, you have to get close enough to the buggers to douse them with it.
When we had an infestation of Forest Tent Caterpillars of biblical proportions, we put Sunlight soap into an applicator that went on the end of the garden hose and we hosed the buildings down with it. It killed them by the millions. So many that I was raking them out of the flower beds and carting them off by the wheelbarrow loads. None of the plants or pets were affected and the house was never so clean before or since.
__________________
I don't suffer from insanity. I enjoy every minute of it!
LLigetfa is offline   Reply With Quote Quick reply to this message
Old 05-24-2009, 03:46 PM   post #5 of 30
ggsteve
5000 Strong & Climbing
ggsteve's Avatar
MTF Member # 9436
Garage
Apparently the soap forms a film over their exoskelton and suffocates them (they breathe through pores in their abdomen). I've not been brave enough to try it. When I find a yellow jacket nest I unload a whole can of wasp spray down the hole to make sure I get every last one of them.
__________________
ggsteve
08 Craftsman Professional 24hp B&S ELS 42" deck 3 bin bagger Berco 44" blower & 48" blade OTC cab
68 JD 112H 47 deck 43 blade
69 JD 110H 37A blower 50 cart
71 JD 140H3 integral hitch 54" 4-way blade 46" deck cozy cab
71 JD 140H1
72 JD 110 parts
78 JD 316K 49 blower
81 JD 317 Onan JB Sr. 46" deck 80 Cart
84 JD 214 39 deck 43 blade
86 JD 318 3pt
Toro 212-5 36" blower
74 Concord (MTD) 990
12 cu. ft. poly cart, JD front dethatcher, plug aerator, drop spreader, box blade, 10" bottom plow, sweeper
ggsteve is online now   Reply With Quote Quick reply to this message
Old 05-24-2009, 03:53 PM   post #6 of 30
Justin
Justin's Avatar
MTF Member # 19622
Well what do you know!
__________________
Old 05-24-2009, 04:14 PM   post #7 of 30
HydroHarold
10,000 +posts!
MTF Member # 82
Images: 1
Quote:
I have to agree. I only feel safe approaching stingy things behind a 10' plume of roaring flame. Save the soap and water to wash their little charred bodies away with the pressure washer.
HydroHarold is offline   Reply With Quote Quick reply to this message
Old 05-24-2009, 04:20 PM   post #8 of 30
jeepersmitty
Retired Aug.31 2007
jeepersmitty's Avatar
MTF Member # 6130
Images: 2
When you spray the soap and water be sure and put some tiny wash cloths out so they can get real clean.
__________________
I always know...
God won't give me more than I can handle
There are times I just wish He didn't trust me quite so much.
jeepersmitty is offline   Reply With Quote Quick reply to this message
Old 05-24-2009, 04:23 PM   post #9 of 30
danbike
danbike's Avatar
MTF Member # 1530
I didn't know that they had BO problems. Bug Odor
Quote:
__________________
2005 JD X585
2011 Triumph T100
19XX VESPA PX200EFL
Old 05-24-2009, 05:42 PM   post #10 of 30
Ken in NJ
Ken in NJ's Avatar
MTF Member # 284
I use the 2.99 cans of wasp sray from HD .. I go through 2 cases a year .. between home and work
Ken in NJ is offline   Reply With Quote Quick reply to this message
Old 05-24-2009, 06:02 PM   post #11 of 30
Kbeitz
Collector of many tractors
Kbeitz's Avatar
MTF Member # 86
Images: 4
Gas and a oil can works gor me... Squart squart...
__________________
Kbeitz is online now   Reply With Quote Quick reply to this message
Old 05-24-2009, 06:09 PM   post #12 of 30
freebird
Camaniac
MTF Member # 63
Spray starch works too. It makes them stiff, they fall to the ground and you can crunch them with your foot. Look out for "escapees" though.
__________________
1956 Cub Lo-Boy
JD LA175
JD LT133
JD RX73
Sears 16/6
If you can't fix it with a hammer, it must be an electrical problem!
freebird is offline   Reply With Quote Quick reply to this message
Old 05-24-2009, 08:50 PM   post #13 of 30
ar2stp48
Senior MTF Member
MTF Member # 6095
I have heard the soap and water mix works, but have never tried it.
I keep a can of carb cleaner handy; it works great. Have also used pump oil can with gas.
ar2stp48 is offline   Reply With Quote Quick reply to this message
Old 05-24-2009, 09:45 PM   post #14 of 30
HydroHarold
10,000 +posts!
MTF Member # 82
Images: 1
Anyone up for "Silly String" and a butane lighter? Man, that sure used to liven up parties!
Sponsored Links
Advertisement
Old 05-24-2009, 10:06 PM   post #15 of 30
junkie
MTF Member
junkie's Avatar
MTF Member # 25533
im dealing with those carpenter bees right now , they think they own my greenhouse.
junkie is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
