Poulan Wild Thing, can you adjust the idle??? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 05-23-2009, 07:31 PM   post #1 of 8
Jeff T
Senior MTF Member
Jeff T's Avatar
MTF Member # 11616
Default Poulan Wild Thing, can you adjust the idle???
After all the schooling I've recieved I spent several hours cleaning, sharpening the chain, new spark plug and air filter, filed and reversed the bar and on and on.
It still is an absolute bear to start, won't idle... Any tips???
__________________
2004 John Deere LX280
Stihl FS 55, Stihl MS270
Off to greener pastures:
1994 John Deere STX38
Ryobi 767r, Poulan 2375 "Wild Thing"
Jeff T is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-23-2009, 07:40 PM   post #2 of 8
frank st amand
aceman
frank st amand's Avatar
MTF Member # 21592
Default Re: Poulan Wild Thing, can you adjust the idle???
yes carb has seals chain saw shop can adjusted the carb special tool to adjust the carb after the saw will be great to used it will not be the same saw and be easy to start and you will gain power too there a great saw when ajusted properly and not expencive to do it just finding one that can
factory setting is too lean there is two jets to adjust also saw will last longer
don't forget to used only weed eater oil it syntectic no snoke it the only oil to used
__________________
if you fail once that ok but twice get a beer
before you lose it
gt 235 repower vanguard 24hp 54 deck 46 plow
445 John deere the projet has started wish list loader snowblower,cab, heat, rear 3pt getting the hydro oil stop
2 yard carts
20 ton splitter
yes i french get confuse in spelling at times
frank st amand is offline   Reply With Quote Quick reply to this message
Old 05-25-2009, 05:59 AM   post #3 of 8
Ironmower
Senior MTF Member
Ironmower's Avatar
MTF Member # 25539
Most likely it's your high/low RPM mixture screws, needs some tweakin' good luck!
Ironmower is offline   Reply With Quote Quick reply to this message
Old 05-25-2009, 08:50 AM   post #4 of 8
Jeff T
Senior MTF Member
Jeff T's Avatar
MTF Member # 11616
Quote:
I'll assume they are the two next to each other, what is the one screw above them for?
__________________
Old 06-11-2009, 01:31 AM   post #5 of 8
FergusonTO35
Junk collector
FergusonTO35's Avatar
MTF Member # 27883
Images: 2
If it simply idles too low you can easily adjust the throttle stop to open the butterfly a bit more. I've owned a bunch of Poulans and they tend to idle way too low from the factory. Heres how I do it. Start the saw and cut a few logs to get it good and warmed up. Using the appropriate size screwdriver, turn the idle stop screw in until the engine speeds up enough to just start turning the chain. Then back it off some so that you have a smooth idle with no chain movement.
__________________
1955 Harry Ferguson TO35
1990 Murray 12HP/38"
1996 Murray 8HP/30"
Lots of weedeaters, chainsaws, blowers
FergusonTO35 is offline   Reply With Quote Quick reply to this message
Old 06-12-2009, 02:08 PM   post #6 of 8
Jeff T
Senior MTF Member
Jeff T's Avatar
MTF Member # 11616
Quote:
Looking at the saw there are 3 screws I could adjust. One on top marked "T" or the two side by side marked "L" and "H".
Which one are you referring to??
Thanks!!
__________________
Old 06-12-2009, 08:46 PM   post #7 of 8
Lawnboy7229
MTF Member
Lawnboy7229's Avatar
MTF Member # 26243
He is referring to the "T" screw, it adjusts the base rpm speed ot the saw. The low speed and high speed screws are to adjust the air/fuel mixture of the saws varying rpms.
So, to adjust your "T" screw, assuming you high speed is running ok and your low speed is ok, run the saw about half throttle, gently ease off the throttle, wait for it to come close to dying out then start adjusting your "T" screw to get the base speed. note set it low enough that it won't engage the clutch and move the chain.
Lawnboy7229 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 06-12-2009, 10:21 PM   post #8 of 8
Jeff T
Senior MTF Member
Jeff T's Avatar
MTF Member # 11616
Thanks Lawnboy! I'll be on it in the AM!
__________________
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
