What do you use to clean your tractor? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Backyard Round Table - L & G Tractor Related Topics Lawn and Garden Tractor Related Topics General Discussion Board
Reply
Thread Tools Display Modes
Old 05-06-2009, 01:13 PM   post #1 of 27
Chuck_050382
Senior MTF Member
Chuck_050382's Avatar
MTF Member # 19593
Images: 4
Default What do you use to clean your tractor?
My tractors are in need of some cleaning, and I don't have a crane to use like in the video Caseguytoo Posted
I have used Simple green for cleaning stuff on my truck before, and have had good results.
I just don't want to harm the tractor any by getting water where it shouldn't be.
So what method does everyone use? Pressure washer or just a garden hose?
__________________
Ford LGT 145, 2003 Craftsman GT 5000, 1977 MTD 990, 1983 Ford LGT 165, 1988 Cub Cadet 1210
Chuck_050382 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-06-2009, 01:25 PM   post #2 of 27
Sergeant
Tech Exchange Moderator
Sergeant's Avatar
MTF Member # 24
Default Re: What do you use to clean your tractor?
I have used a preesure washer but I use it on a low setting. or I use a terry cloth and a Bucket of water with car soap in it. The JD dealer where my younger brother works uses a pressure washer on all the machine they get in for service Before the mechanics even work on them. I use a blower on my machines after each uses. especally on My JD X485 to keep the vent's clean around the radiator
__________________
John Deere Models:X748,140H3,112,Sabre 1542
Cub Cadet Models:0riginal,70,106,2206 & Experimental Non Production Rear engine rider
Ingersoll Model:3016PS
Simplicity Models:Wonder Boy
White Model: GT2055
"The only thing necessary for the triumph of evil is for good men to do nothing." Edmund Burke
Sergeant is offline   Reply With Quote Quick reply to this message
Old 05-06-2009, 01:29 PM   post #3 of 27
D-Dogg
The Magnificent
D-Dogg's Avatar
MTF Member # 20164
Images: 2
Garage
I used the compressor, but then discovered the leaf blower is even better for the initial cleanup.
Use the pressure washer on the underside of the deck, and a little dish soap and water for washdown.
Leaf blower again for drying.
__________________
D-Dogg is offline   Reply With Quote Quick reply to this message
Old 05-06-2009, 01:29 PM   post #4 of 27
LLigetfa
standard issue neuralyzer
LLigetfa's Avatar
MTF Member # 15283
Images: 2
A small squirt of dish soap in a bucket of water and then dip the brush in it.
__________________
I don't suffer from insanity. I enjoy every minute of it!
LLigetfa is offline   Reply With Quote Quick reply to this message
Old 05-06-2009, 01:31 PM   post #5 of 27
Chuck_050382
Senior MTF Member
MTF Member # 19593
Images: 4
I typically use the leaf blower after mowing, but they are in need of a little more through degreasing.
__________________
Old 05-06-2009, 01:33 PM   post #6 of 27
D-Dogg
The Magnificent
D-Dogg's Avatar
MTF Member # 20164
Images: 2
Garage
In that case, simple green cuts grease pretty well if you mix it strong enough.
I'm only use it high strength exactly where you need it.
__________________
Old 05-06-2009, 01:34 PM   post #7 of 27
FrankMA
Proud Member of the 1K Club
FrankMA's Avatar
Location: Merrimack Valley in Northeastern Massachusetts
MTF Member # 10550
Leaf blower after most uses and when I wash I use a bucket of dish soap and a brush on a broom handle. I sometimes follow-up with a coat of wax.
__________________
2002 Toro Wheel Horse 522xi
Honda HS928TA Snowblower
Honda HS621AS Snowthrower
Honda HS520A Snowthrower
Honda HS624WA Snowblower (Sold 8/23/2010)
Honda EM6500SX Generator
Stihl BR550 Backpack Blower
McCulloch MS1635 Chainsaw
Weedeater SST25 Line Trimmer
"It is what it is!"
FrankMA is offline   Reply With Quote Quick reply to this message
Old 05-06-2009, 02:18 PM   post #8 of 27
GR8racingfool
JD Green all the way~!
GR8racingfool's Avatar
MTF Member # 22107
You all are making me want to go buy a leaf blower, thanks! LOL
Me, a damp rag, to clean up the dust from mowing on the out side.
Under the deck, i just scrape it with a putty knife, and maybe once or twice a year, it will be scrubbed with dish soap and fully cleaned when I am done with it for the season.
For the engine, I removed all the metal trim, bought some spray on degreaser (simple green works wonders too, even better if the engine is warm) and then just washed off with the garden hose.
When I first started on the tractor, the entire diff. /rear end was covered in dust, and grease from the transmission seeping. Brake cleaner in a spray can, letting that soak in, and a garden hose wash off, did wonders in this case.
~F~
GR8racingfool is offline   Reply With Quote Quick reply to this message
Old 05-06-2009, 04:18 PM   post #9 of 27
Grateful11
2000 Posts and climbing!!!
Grateful11's Avatar
MTF Member # 5025
We use an electric leaf blower or air compressor on about all our farm and
lawn equipment as a quick blow down. Then when they're cooled down we
usually wash if needed.
__________________
'11 John Deere 5065M /cab
'10 Kubota L3940 w/FEL
'09 JD X720
'91 CaseIH 5140 Maxxum w/cab
'78 IH 686 w/M&W Turbo 106 PTO hp w/canopy
Grateful11 is offline   Reply With Quote Quick reply to this message
Old 05-06-2009, 04:29 PM   post #10 of 27
diesel_nut
diesel_nut's Avatar
MTF Member # 23678
Leaf blower when dry.
When wet/muddy: Just water
Every now and then: Purple cleaner and pressure washer.
Purple cleans gobs better than Simple Green.
__________________
Cub 1872....sold
Cub GT2554: '07(sold) and '08
..."yyup"
diesel_nut is offline   Reply With Quote Quick reply to this message
Old 05-06-2009, 04:49 PM   post #11 of 27
JimC_Vt
Senior MTF Member
JimC_Vt's Avatar
MTF Member # 24069
To "De Grease" use "Greez-off" much better than simple green ,and a garden hose ......remove extra h2o with air hose ,or bake in the sun ! Jim
JimC_Vt is offline   Reply With Quote Quick reply to this message
Old 05-06-2009, 05:56 PM   post #12 of 27
draddogs
draddogs's Avatar
MTF Member # 4
Images: 6
Pressure washer and Purple Power for the oily and greasy stuff.
__________________
Handle every Stressful situation like a dog.
If you can't eat it or play with it,
Pee on it and walk away.
draddogs is offline   Reply With Quote Quick reply to this message
Old 05-06-2009, 06:32 PM   post #13 of 27
saleen49
Super Duper Member
saleen49's Avatar
MTF Member # 21045
Images: 2
I use the air compressor first to remove anything that is loose. Then I wash my tractor the same way I wash my car. I use a quality wash mitt, and car washing soap on anything that is painted. Citric acid cleaner in a spray bottle, works well at removing grease and grass stains; but it can be hard on paint and bare aluminum parts, so don't let it sit for long. I use citric acid cleaner with an old paint brush, to clean the rims, tires, and any frame sections that are visible.
I wipe it dry with a soft towel. I run the deck for a minute to dry the belt and pulleys off.
__________________
1983 318.
2009 X729 with 54" deck & 54" blade, oh and 45 loader
__________________________________________________ __
"I have not failed. I've just found 10,000 ways that won't work." Thomas A. Edison
saleen49 is offline   Reply With Quote Quick reply to this message
Old 05-06-2009, 07:36 PM   post #14 of 27
stonykill
stonykill's Avatar
MTF Member # 7096
Images: 2
most often, rain on my own. I have no problem with a coating of grease or a light film of oil. It's a better rust preventer than paint. Besides, a pretty gt means nothing to me.
If I'm cleaning one up to sell (never one of my gt's, just a lt I picked up with the intent to sell) I'll use the pressurewasher.
__________________
................ Gravelys and Jakes................
stonykill is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-06-2009, 07:37 PM   post #15 of 27
GR8racingfool
MTF Member # 22107
Quote:
Originally Posted by Grateful11 View Post
We use an electric leaf blower or air compressor on about all our farm and lawn equipment as a quick blow down..
Thank you for not saying job, but you made me laugh anyway cause I was thinking it, and I am immature.
~F~
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
