Towing and Pulling Capacities Cub Cadets - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 04-23-2009, 12:45 PM   #1
Ray2
Senior MTF Member
Ray2's Avatar
MTF Member # 24609
Default Towing and Pulling Capacities Cub Cadets
If anybody would be interested, I found the following on a Cub Cadet Website........I thought I had seen this question posted here , if not....... disregard.......
that is all....lol
Cub Cadet Home
Cub Cadet Home
Buy Parts Online
Owner's Manuals
Service Locator
Find A Dealer
Product Registration
Answers
Ask a Question
My Stuff
show accessible links
Login
Help
Search by Product View Product Hierarchy
Search by Category View Category Hierarchy
Search by Keyword Search Tips
Powered by RightNow Technologies
ID
444
Release Date
05/31/2006
Printer Friendly Version of This Answer Print Answer
Email This Answer Email Answer
How much weight can my Cub Cadet tractor tow?
Question
What is the towing capacity of my Cub Cadet tractor?
Answer
This is a more complicated issue than it might appear, because "towing capacity" is more of a sales specification than a technical specification. If you picture yourself pushing a wheelbarrow full of dirt, weighing about 300 pounds, you would say that your pushing capacity was 300 lbs, but I doubt you would be able to push 300 pounds if it were on a flat sled with no wheels on rough ground. That is a simple analogy explaining why we don't use towing capacity as a technical specification.
Everyone likes to relate axle torque to draw bar force, but draw bar force cannot so easily be related to "towing capacity" due to all the variables involved. There is also a difference between a maximum axle torque (or draw bar force) short duration spike compared with what can be sustained over a long distance such as in towing. On most surfaces, unless you significantly weight down the tractor, you will generate tire slippage before you reach the transmission's ability to create maximum axle torque.
The 1000 Series & LT1500 Series can handle a typical lawn cart with a 750 lb. capacity and a lawn roller of 650 lbs.
The iSeries can handle a lawn cart with a 1500 lb. capacity and a lawn roller of 950 lbs.
The GT1500 Series can handle a lawn cart with a 1500 lb. capacity and a lawn roller of 950 lbs.
The 2500 and 3000 Series can handle a lawn cart with a 1500 lb. capacity and a lawn roller of 950 lbs.
CAUTION: You should also be cautious of "braking ability". These tractors have a single disc brake designed to stop the weight of the tractor on slight grades. When you are towing downhill your braking distance will significantly increase. As a general rule of thumb, using a single-axle wheeled trailer you should be able to pull half the weight of the tractor safely over level ground and slopes less than 5 degrees.
Ray2 is online now   Reply With Quote
Sponsored Links
Advertisement
Old 04-23-2009, 12:53 PM   #2
Wid LT1000
Senior MTF Member
Wid LT1000's Avatar
MTF Member # 15471
Default Re: Towing and Pulling Capacities Cub Cadets
Ray,
Thanks, that's actually interesting info, and a good reference. Keep in mind that those numbers will drop dramatically when pulling on an incline.
And let me extend a "Welcome to MTF" if I didn't already do that!
__________________
Chad
2001 Craftsman LT1000 16HP Kohler Command
2008 CC SLT1554 27HP Kohler Courage
Wid LT1000 is offline   Reply With Quote
Old 04-23-2009, 02:45 PM   #3
diesel_nut
Proud Member of the 1K Club
diesel_nut's Avatar
MTF Member # 23678
At first I read the response and went.........BS BS BS BS and then they actually stated numbers. Those are some pretty high numbers when it comes down to it. 1500 lbs for my tractor?? I doubt I'll ever do that to it but I guess it's nice to have a number. Fortunately I live in flat land country.
Now just how much does that boat weigh..................
__________________
Cub 1872....sold
Cub GT2554: '07(sold) and '08
..."yyup"
diesel_nut is offline   Reply With Quote
Old 04-23-2009, 05:16 PM   #4
slkpk
USMC
slkpk's Avatar
MTF Member # 37
Images: 21
Your boat will weigh in at 1501 lbs with fuel and all the accessories so it looks like your out of luck no tow for you. slkpk
__________________
1964 JD RF110 Restored
2004 Ingersoll 318LGT @ the church doing the Lord's work
2007 JD 2305
It's too late to worry about it now!
slkpk is offline   Reply With Quote
Old 04-23-2009, 06:37 PM   #5
attorney_barnabas_collins
MTF Junior Poster Esq.
attorney_barnabas_collins's Avatar
MTF Member # 7575
Images: 16
I guess they could include "all the way to the bottom" a significant increase.
attorney_barnabas_collins is offline   Reply With Quote
Old 04-24-2009, 01:12 AM   #6
diesel_nut
diesel_nut's Avatar
MTF Member # 23678
Like the submarine Captain responded to the question "how far down will this sub go?"
"All the way to the bottom if we let it".
____________________________________________
"1501 lbs"........very funny.
__________________
Cub 1872....sold
..."yyup"
Old 04-24-2009, 07:57 AM   #7
savageactor7
Senior MTF Member
savageactor7's Avatar
MTF Member # 18371
Good skinny to towing weights, thanks...
...being on level ground I've always taken brakes for granted. In 30 years you could count on one hand how many times I've used the breaks and still have fingers left over.
__________________
Kubota B1750 chains on all 4 turf tires, CC1440, CC2550
savageactor7 is offline   Reply With Quote
Old 04-24-2009, 02:09 PM   #8
Gary in NJ
Gary in NJ's Avatar
MTF Member # 3765
Images: 6
On my 3206, the brake lever is something I have to press to engage the starter. The hydro tranny does 100% of the stopping.
__________________
Gary
Cub Cadet 3206
Johnny Bucket Sr, 54" Dozer Blade, 45" Snow Thrower
Lots of motorcycles, an experimental airplane and a '72 240Z. Toys are great.
Gary in NJ is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-24-2009, 06:31 PM   #9
DMAC
MTF Member
DMAC's Avatar
MTF Member # 21642
Images: 39
Little story about pulling power with our 3204...It pulled my truck up a 200' drive way, 10' rise in the 200 feet, when the fuel pump quit on RT66 as I was pulling into my parents driveway, "the farm". Although it could have died on RT66.
Now to fix the problem I needed to get my truck up the driveway into the barn so I could work on it and not block the driveway. We hooked up the 3204 to the truck, and amazingly it pulled it up the slope, the truck weighs 8000lbs and of course the tank was 7/8 full . We drove the tractor into the barn as far as it would go, which put the truck at the edge of the barn. We then drove the tractor out of the barn, and rehooked up the chain to finish pulling the truck into the barn, then the fun started. Here is the truck that was pulled. That's Snap200's 1855a snapper in the front of it with the Troy-Built Tiller loaded up to go and till his gardens. A good friend borrows your stuff keeping it alive and running, and returns it perfect.
__________________
Cub Cadet 3204 with:
54" Dozer Blade w/carryall sides
45" Snow Thrower, Snow Cover, lights+weights
3 Point Hitch w/2" receiver
23" Rear Ag Tires, 18" Front, 4-Ply
Dual Lift front hitch w/Angle
Homemade: front bucket, dirt scoop, boom pole, york rake.
3 point ripper, winch, battering ram, hyd press, crane, etc. Front or Rear hookup
DMAC
DMAC is online now   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
