propane conversion - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 04-22-2009, 11:31 AM   post #1 of 11
Q'man
MTF Member
Q'man's Avatar
MTF Member # 548
Images: 2
Default propane conversion
Has anyone tried a propane conversion on a garden tractor?
Q'man is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-22-2009, 11:40 AM   post #2 of 11
Tractor-Holic
10,000 +posts!
Tractor-Holic's Avatar
MTF Member # 8867
Default Re: propane conversion
I have not,but I saw the plans to convert a Walbro carb to propane useage is listed on the www.theepicenter.com website ..they used it on generator engines,but a Tecumseh or Kohler with a Walbro on a tractor would likely be the same..
Tractor-Holic is online now   Reply With Quote Quick reply to this message
Old 04-22-2009, 01:18 PM   post #3 of 11
js5020d
2000 Posts and climbing!!!
MTF Member # 3908
It is doable and the proper equipment is out there for a conversion but Im not seeing an advantage in the running of propane. Propane has less BTUs per gallon than gas and would take more fuel to do the same amount of work. Unless you need to run it inside or have a real cheap source of fuel I dont see the advanage myself. But it can be done.
js5020d is offline   Reply With Quote Quick reply to this message
Old 04-22-2009, 01:26 PM   post #4 of 11
davidg
The Travelin' Mod
davidg's Avatar
MTF Member # 807
Images: 2
the way fuel prices have been, i don't even see a cost savings. LP cost almost as much as gas, so unless you are using a lot you won't save enough to even pay for the conversion.
several farmers here run LP in their trucks. they had them converted when LP was around 1.00 a gallon here and gas was around 1.50. currently LP is within 10-15 cents of gas per gallon and they say it ain't worth it to them if they had to buy now. most of them have a huge bulk tanks at their shops though, and purchase several thousand gallons when the price is low so that it will carry them thru the year. then they fill teh 50-75 gallon tanks on teh trucks.
__________________
Check out our new HOMEPAGE
davidg is offline   Reply With Quote Quick reply to this message
Old 04-22-2009, 01:52 PM   post #5 of 11
Q'man
MTF Member
Q'man's Avatar
MTF Member # 548
Images: 2
Gas is cheaper right now, so this wouldn't be an advantage at the present...
I'm looking more for the advantages of cleaner burning etc. Just wondering for future use and would the engine last longer on propane is the big question. I know the amount of oil changes are less when burning propane. You don't have to worry about ethanol gum up when sitting for a period of time and not being used (like gas engines).
Any other advantages? Or is earth day just going to my head?
Old 04-22-2009, 06:11 PM   post #6 of 11
js5020d
MTF Member # 3908
I was in the industrial lift truck biz for many years,, to my knowledge none of the engine manfacturers recomended a different maintenence schedule for a propane powered engine compared to a gasoline powered one, and there was no noted advantage to propane when it came to wear on internal components. Leave a propane powered engine sit around for any length of time and you will need maintenence on the fuel system due to the additives put in the propane also. Sorry still no advantages using propane.
Old 05-25-2009, 01:29 AM   post #7 of 11
Marty
Senior MTF Member
MTF Member # 21065
the biggest advantage to lp is that it is very clean burning. I've heard of engines with ten years old being torn down to rebuild that were as clean as new. They seen to not be prone to the carbon build up as with a gas engine. Thus less wear.
Bob
Marty is offline   Reply With Quote Quick reply to this message
Old 05-26-2009, 05:20 PM   post #8 of 11
draddogs
draddogs's Avatar
MTF Member # 4
Images: 6
Quote:
Originally Posted by js5020d View Post
I was in the industrial lift truck biz and there was no noted advantage to propane when it came to wear on internal components. Leave a propane powered engine sit around for any length of time and you will need maintenence on the fuel system due to the additives put in the propane also. Sorry still no advantages using propane.
I will have to disagree to your staemnt that there was no advantage to wear of LPG to Gasoline. I was an industral mechanic for years for Clark Equipment and the LPG powered engines ran longer and less mechanical engine repair due to wear compaired to those run strictly on gasoline. Tjhe biggest benefits are less wear and cleaner air..
__________________
Handle every Stressful situation like a dog.
If you can't eat it or play with it,
Pee on it and walk away.
draddogs is offline   Reply With Quote Quick reply to this message
Old 05-26-2009, 08:31 PM   post #9 of 11
mrnu
MTF Member
MTF Member # 24365
Hey I think it is worth considering the SW, esp as we Know GAS will go up ! and The Cleaner engine from what I have read on it.. My Area it is 30 cents Cheaper a Gal difference today..In 1 Year I can see It being paid for ,Plus The Benies..NU
mrnu is offline   Reply With Quote Quick reply to this message
Old 05-26-2009, 08:38 PM   post #10 of 11
Kbeitz
Collector of many tractors
Kbeitz's Avatar
MTF Member # 86
Images: 4
One advantage with LP is you can let the tractor sit for a few years and it will start right up...
__________________
Kbeitz is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-26-2009, 10:57 PM   post #11 of 11
Walt 2002
Senior MTF Poster
MTF Member # 1229
I'll bet it doesn't leak into the oil contaminating it and causing thrown rods either.
Walt Conner
Walt 2002 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
