My Simplicity LTH 12.5 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 04-18-2009, 10:07 PM   post #1 of 18
mlayman27
MTF Member
MTF Member # 24643
Default My Simplicity LTH 12.5
Hey everyone! My names Marc. I have a Simplicity LTH 12.5 with a 38" deck. Its most likely a 1990 model. How many people are still running ones this old everyday? I will be using it some for a little lawn business this year. I had seen a leaf mulch kit for this model. Does anyone know if it is effective? Also did they make a grass mulching cover for this tractor? The model # is 1691886 if that helps. Thanks in advance! I can't wait to read more about our tractors!
mlayman27 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-18-2009, 11:10 PM   post #2 of 18
professor
2000 Posts and climbing!!!
professor's Avatar
MTF Member # 90
Images: 11
Default Re: My Simplicity LTH 12.5
Marc- you got a spring chicken- this one is from around 67 I think-
__________________
Every day is a victory.
'64 Simplicity Broadmoor
'66 Simplicity Broadmoor 707
'68 Sears Xl 10
? Dynamark 11/42
'71 Wheel Horse Special
'71 Wheel Horse Gt14
'72 Cub 127
? Bolens 10H
professor is offline   Reply With Quote Quick reply to this message
Old 04-18-2009, 11:46 PM   post #3 of 18
Vangellis
Senior MTF Member
Vangellis's Avatar
MTF Member # 442
Hi Marc.
I have a 1990 12.5 LTH with the Vanguard V-twin. I also have a 1991 12.5 LTH with a blown engine for parts. I picked it up used in 1994 and it still runs like a top.
I've used it for cutting my acre, snow plowing, and hauling firewood and yard waste. I bought a Conquest in 2005, so the 12.5 LTH is my back up, but still gets a lot of use.
I use it mostly for cutting my neighbors field,
(2 1/2 acres )and mini brush hogging. LOL
All I can tell you is I've beat the crap out of this thing and it still runs great.
A few pics.
Cutting the field. Mindless mowing.
Loaded up with firewood for the trip back home.
Pushing some snow.
Nice back up mower to have.
Kevin
Vangellis is offline   Reply With Quote Quick reply to this message
Old 04-19-2009, 05:03 PM   post #4 of 18
mlayman27
MTF Member
MTF Member # 24643
Kevin, nice mower! Looks just like ours! It still cuts great, its in the shop getting the carb adjusted but the dealer said he hasn't seen one that nice in quite sometime. Do you know if they make a mulch plug for it?
Old 04-19-2009, 06:52 PM   post #5 of 18
Vangellis
Senior MTF Member
Vangellis's Avatar
MTF Member # 442
Quote:
Hi Marc.
I have no idea if they have a mulch kit for it. Never seen one mentioned.
Kevin
Old 04-27-2009, 08:50 AM   post #6 of 18
Tonyx
MTF Member
MTF Member # 25163
Hi! First time poster but long time lurker
I have the same tractor and I would like to do some maintanence myself. I've changed the engine oil, air filter, adjusted valves and sharpened the blades past weekend. I'd like to change the transmission oil now.
Can someone guide me where the drain is? Is there something to watch out for?
I understand the fill oil is straight 30W non-detergent oil. Thanks for any help, I'd like to have this tractor for long time to come.
Tonyx is offline   Reply With Quote Quick reply to this message
Old 05-04-2009, 01:46 PM   post #7 of 18
Tonyx
MTF Member
MTF Member # 25163
Hmmm, no reply on the transmission oil change. I wonder if anyone even has done this on this model.
I decided to look into the valve clearances on my tractor a few weekends ago. I was looking for gap of 0.005 inch on cold engine but found almost no gap on both valves on one cylinder and similar on one valve on the other cyclinder.
Got out the 13mm wrench with allen wrench and got 4 adjusted to 0.0045 inch. Verdict? I mowed my lawn and the tractor felt stronger with less hesitation between throttle changes. And when PTO is engaged there is less rpm drop(by listening) and it seems less fuel thirsty. All in all 1 hour well spent!
The hood was a bugger to get back on by myself, it would have helped to have a helper put in the plastic washer while another person is holding the hood off of the metal spindle. But is was managed : )
Old 05-09-2009, 10:58 AM   post #8 of 18
Tonyx
MTF Member
MTF Member # 25163
I know Kevin above still uses his plus my self and mlayman27. But this may be the exception? Have others from this vintage gone to pasture? We need to generate some momentum behind the LTH owners : )
Old 05-10-2009, 06:35 PM   post #9 of 18
Vangellis
Senior MTF Member
Vangellis's Avatar
MTF Member # 442
Hi Tonyx.
I can't help with the tranny oil change...because I've never changed mine or know how to.
Mine works well, but I did have a problem once. I thought it was the tranny, but it was because the brake pedal did not retract all the way. After some oiling of the linkages and areas around the pedal, it worked fine.
Kevin
Old 05-17-2009, 07:57 AM   post #10 of 18
Tonyx
MTF Member
MTF Member # 25163
Hi Kevin,
Thanks for the reply. I noticed that after mowing the oil I can see in the transmission reservoir is not all clean - quick swipe on clean paper towel show greyness. I picked up several quarts of non-detergent oil and will tackle the fluid change. There has to be simple method as there is reservoir and a return tube. Hmmm..,
Old 05-18-2009, 08:51 PM   post #11 of 18
cadman56
Senior MTF Member
cadman56's Avatar
MTF Member # 4627
Marc and Tonyx . I can't help you out with the hydro oil change. I have a 1981 4211 that is still running strong, but it is a 5 speed. Sometimes I wish it was a hydro. Keep those machines maintained and they will run a long, long time.
__________________
Grandpa Cadman56
1981 4211 11 hp / 36" deck
2003 Prestige 23 hp / 54" deck
2008 JD X728 27 hp / 62" deck / 45 FEL
JD JS60 Walkbehind
Echo SRM-2100
Echo ES-210 Shred-'N'-Vac
cadman56 is offline   Reply With Quote Quick reply to this message
Old 05-18-2009, 10:51 PM   post #12 of 18
simplelife
Senior MTF Member
simplelife's Avatar
MTF Member # 1233
Images: 2
Not familiar with this model nor where the drain plug is for the tranny. You can download the operators manual and illistrated parts list here. http://www.simplicitymfg.com/manuals/index.cfm?rd=1
The illustrated parts list should have a picture of the drain plug. The op manual calls for SAE 30W premium oil for the hydro.
Good luck. You will really like it if it is anything like my older Simplicities.
__________________
Mike
The irony of life is that, by the time you're old enough to know your way around, your not going anywhere!
simplelife is offline   Reply With Quote Quick reply to this message
Old 05-19-2009, 09:17 PM   post #13 of 18
Prestigious1
Senior MTF Member
Prestigious1's Avatar
MTF Member # 19319
If the hydro unit is still sealed properly and hasn't been terribly overheated, there's likely little need to change the fluid. I've seen hydro's last nearly forever with the oil that they were shipped with. I've seen others that's been changed destroyed in a year because they introduced contaminants when they changed the oil out.
Prestigious1 is offline   Reply With Quote Quick reply to this message
Old 05-31-2009, 11:18 PM   post #14 of 18
Tonyx
MTF Member
MTF Member # 25163
Ok, I changed the hydro oil over the weekend on my 12.5 LTH. I now understand why it's not common procedure : )
I drove the tractor backwards onto car ramps to get better look. There were no drain plug of any kind, but I did see hose from bottom side going back to front mounted reservoir. It's white plastic nipple with 1" hex on it. I loosen that out and out came the original hydro oil, all 1.1L of it.
That was the easy part. After reassembly, carefully so no contaminants get in, I tried to fill the reservoir with new oil but it didn't take. There was no natural drain to the transmission nor was there self priming action to suction the oil into transmission. I ended up injecting the new oil using the large syringe used for 2 cycle oil/gas mixing.
Fill up the syringe with new oil, insert the tip into the bottom hole in the reservoir and inject. Repeat ten times to fill up the system. During the process you can see the old oil squirting through the return line as new oil is injected into the system. There was night and day difference in color where the new oil was honey color, the old oil was dark brown. If nothing else, it made me feel better to have done the change.
Sponsored Links
Advertisement
Old 08-21-2009, 11:53 AM   post #15 of 18
Tonyx
MTF Member
MTF Member # 25163
Update on the trans oil change and a tip:
Used 30W non-detergent oil per manual and it was ok. Clearly the draining procedure does not get all the oil out of the system. After using the tractor for awhile the oil color changes as it mixes with stagnant oil in the trans.
Reading other posts who found improvement using modern oil with 20W-50 synthetic, I drained the oil again. Same process and used 20W-50 synthetic, Valvoline. I didn't notice any difference, sound(whine) still the same going up hill but at least I feel better having better oil in there.
Tip I found. After several hot mowing sessions, I noticed the engine would run-on after shutdown. I poured in 1/3 container of Seafoam into 4gal fuel. This cured the run-on. I'd imagine the fuel is cooking in the carburator near the hot engine and causing varnishing to build up.
I use Seafoam on all my small engine equipment with great results.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
