A couple tips on changing oil on an L series - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 04-15-2009, 07:24 PM   #1
Grateful11
2000 Posts and climbing!!!
Grateful11's Avatar
MTF Member # 5025
Default A couple tips on changing oil on an L series
I cut an old oil bottle up to catch the oil from the oil filter, I put it under there
before loosening the filter with a cap style wrench and if you roll the left
rear tire up on something about 2" thick you'd be surprised how much more
old oil come out of the drain tube. Be careful with that plastic bayonet mount
oil drain cap.
I cut away a little too much of my bottle:
__________________
'11 John Deere 5065M /cab
'10 Kubota L3940 w/FEL
'09 JD X720
'91 CaseIH 5140 Maxxum w/cab
'78 IH 686 w/M&W Turbo 106 PTO hp w/canopy
Grateful11 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-15-2009, 07:27 PM   #2
D-Dogg
The Magnificent
D-Dogg's Avatar
MTF Member # 20164
Images: 2
Garage
Default Re: A couple tips on changing oil on an L series
Now that is one fine no-cost idea!
Thanks for sharing.
__________________
D-Dogg is offline   Reply With Quote
Old 04-15-2009, 07:36 PM   #3
Grateful11
Grateful11's Avatar
MTF Member # 5025
Quote:
Thanks for sharing.
I got tired of ending up with oil all over the frame. So brainstormed a bit.
Should have left a bit more bottle up towards the neck but I think I know
where I can get another empty bottle ;-)
__________________
'09 JD X720
Old 04-15-2009, 07:40 PM   #4
FrankMA
Proud Member of the 1K Club
FrankMA's Avatar
Location: Merrimack Valley in Northeastern Massachusetts
MTF Member # 10550
Great Idea! Thanks for sharing with us.
__________________
2002 Toro Wheel Horse 522xi
Honda HS928TA Snowblower
Honda HS621AS Snowthrower
Honda HS520A Snowthrower
Honda HS624WA Snowblower (Sold 8/23/2010)
Honda EM6500SX Generator
Stihl BR550 Backpack Blower
McCulloch MS1635 Chainsaw
Weedeater SST25 Line Trimmer
"It is what it is!"
FrankMA is offline   Reply With Quote
Old 04-15-2009, 07:56 PM   #5
jeepersmitty
Retired Aug.31 2007
jeepersmitty's Avatar
MTF Member # 6130
Images: 2
Thanks for the tip. Great idea.
__________________
I always know...
God won't give me more than I can handle
There are times I just wish He didn't trust me quite so much.
jeepersmitty is offline   Reply With Quote
Old 04-16-2009, 11:40 AM   #6
davidg
The Travelin' Mod
davidg's Avatar
MTF Member # 807
Images: 2
after the first couple changes i started doing similar with a bent peice of cardboard. i guess i need to cut up a plastic bottle so it will be reusable!
__________________
Check out our new HOMEPAGE
davidg is offline   Reply With Quote
Old 04-16-2009, 12:26 PM   #7
1086
3K Poster!!!!
1086's Avatar
MTF Member # 1086
Images: 11
You mean the filter is supposed to be changed!!!!!!!! I thought the manual just said to change the oil like on my wife's car says "change oil soon" OR 5% oil life remaining.
That little filter is the same size as the car filter and according to my hour calculations that little engine will never need it's filter changed until death does it part or 1,500 hours or which ever occurs first.
1086 is offline   Reply With Quote
Old 04-20-2009, 08:11 AM   #8
Victory
Senior MTF Member
MTF Member # 6699
Images: 3
Maybar,
Hope you are joking. Your tractor sees a LOT more dust and dirt than your car or truck does. How dirty is your air filter after one mowing? Just one example.
Oil is the blood of an engine. Clean it clean and keep it happy.
Victory is offline   Reply With Quote
Old 04-20-2009, 05:48 PM   #9
wally2q
wally2q's Avatar
MTF Member # 45
yea, yea... nevermind that.... it's the +/- 0.100 tolerances on the $5 piston,and $15 cylinder / engine casting, and the $5 carb, that causes less than optimum engine fuel-air control, and results in chunks of carbon being blown down into the oil pan. 50 hours and that oil is black!.
keep in mind, if you go 60 mph in your car for 50 hours, you will have driven 3000 miles.... hmmm... time for an oil change....
wally2q is online now   Reply With Quote
Old 05-21-2009, 06:31 PM   #10
Flintlock1776
Senior MTF Member
Flintlock1776's Avatar
MTF Member # 26571
Just too bad JD can't figure a better way than us having to use jury rigged deals
__________________
Remember the 343
George Johnson, Ladder 157
Dan McWilliams, Ladder 157
Bily Eisengrien, Rescue 2
Scott Strauss NYPD ESU
________________________________________
JD 178
JD L120
JD x520
and other JD toys for boys!
Flintlock1776 is offline   Reply With Quote
Old 05-21-2009, 07:12 PM   #11
unit40
Senior MTF Member
unit40's Avatar
MTF Member # 5574
Like a peice of folded up aluminum foil........or how about tearing away a page out of the owners manual...or the cover for that case, more oil resistant.
unit40 is offline   Reply With Quote
Old 05-21-2009, 10:40 PM   #12
sproulman
Senior MTF Member
MTF Member # 26295
now thats great idea.i will use your idea next oil change, thanks.
sproulman is offline   Reply With Quote
Old 05-22-2009, 10:16 PM   #13
Flintlock1776
Senior MTF Member
MTF Member # 26571
Quote:
__________________
Remember the 343
JD 178
JD L120
JD x520
Old 05-23-2009, 09:43 AM   #14
sproulman
Senior MTF Member
MTF Member # 26295
i did a little reading on oil filters for briggs motors.i found that ph 8172 which is 2.7 inchs long or ph 3614 which is 3.4 inchs long is what most are using on their JD briggs/stratton. also the ph 4967 was rec but i did not look at that one.wix,napa,super tech ,fram tough guard,ac,purulator were 6 that was tested on quality of filters.
notice i did not list the fram others ,only the TOUGH GUARD was ok on material in fram line.
these are auto oil filters.i personelly for price and tests i read like the WAL-MART super-tech but now they are making them in mexico with plastic by-pass.that plastic by-pass is only ,in my opinion a problem if your oil changes went over like 7500 miles on auto,for lawnmower if you change oil/filter yearly,i change my oil 2 times a year and filter 1 time in my mower ,no problem i can see.
i think wix/napa/ac still put metal in their by-pass valves.
funny, i went to store looking for yugo filter which i heard fits the briggs and it was PH3614,same as those 2 i listed on what was used by others.
Sponsored Links
Advertisement
Old 05-23-2009, 08:44 PM   #15
sproulman
Senior MTF Member
MTF Member # 26295
forgot, i also put a magnet on top of the oil filter,this helps keep the metal particles in the filter and out of oil to engine parts.
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
