| Register | Home | FAQ | Active Topics | Garage | MTF Gallery | Search | Today's Posts | Mark Forums Read | Store | Chat Room |
Thread Tools | Display Modes |
#1 |
Senior MTF Member
I am going to pick a 2nd lawn sweeper tomorrow. I would like to pull 2 at once. Both are 38" sweepers.
Has any one else on here done that? Any suggestion on tow bars? thanks Chuck
__________________
Ford LGT 145, 2003 Craftsman GT 5000, 1977 MTD 990, 1983 Ford LGT 165, 1988 Cub Cadet 1210
| Sponsored Links | |||
Advertisement | |||
#2 |
ex spelling bee champ
I have thought of that also. The one is just not wide enough!!!
#3 |
Senior MTF Member
The only down side is 1 sweeper is hard enough to back up, 2 will be impossible.
Guess that's a good reason to make a rubber edge for my blade so I can push the piles into 1 big pile to load into the compost.
__________________
#4 |
Dumping would be a HUGE problem. Also you would want to stagger them, so they overlap. That would also make dumpping harder
#5 |
Senior MTF Member
I could either stagger them or space them to leave a 30" strip between them, and then I would still be able to cover twice the area, the next pas would pick up the area between the sweepers, and 1 section over.
__________________
#6 | |
Senior MTF Member
Quote:
__________________
#7 |
standard issue neuralyzer
If you also tied them together near the inside wheels, they would be easier to back up.
__________________
I don't suffer from insanity. I enjoy every minute of it! |
#8 |
Proud Member of the 1K Club
I tied a couple of push mowers to my tractor last year and it did work well in a straight path- turning was the issue. Sharp turn would leave an uncut strip. The only way around that was link them closer together, which of course, defeats the idea.
__________________
Every day is a victory. '64 Simplicity Broadmoor '66 Simplicity Broadmoor 707 '68 Sears Xl 10 ? Dynamark 11/42 '71 Wheel Horse Special '71 Wheel Horse Gt14 '72 Cub 127 |
#9 |
Senior MTF Member
MTF Member # 11189
wouldnt you want them rite be side each other so u dont leave a strip
#10 |
Tech Nerd Tractor Convert
Considering the trouble you're going through to create a custom hitch, might it be just as easy to part out the two sweepers and build a single "stretch" sweeper that's twice the width?
__________________
Paul. i1050|Maint|Gov|Tach:ind,laser|Deck|Blade|JBJr|SBlow:Fit,Winch,Act|Chain|Cyclone|Sweep|Gators|Aerator|Cart|Knob|Hoist|Cab|Trailer|PC|Bits "I am thankful for a lawn that needs mowing, windows that need cleaning and gutters that need fixing because it means I have a home." ~Nancie J. Carmody |
#11 | |
Senior MTF Member
Quote:
Toolin: the hitch for the sweeper I was thinking of building was going to be pipe and/or angle iron scrap I have on hand. But the idea of 1 super sweeper sounds interesting as well. I will looking that also.
__________________
#12 |
Senior MTF Member
Here's another thought....
Get a second tractor and a helper, if possible. When my Granma's place (about 2 acres with oak trees) needs the leaves picked up I use my tractor and sweeper and my wife uses my Grandma's tractor and sweeper.
__________________
Just a word of advice, If women don't find you handsome then try to be handy. |
#13 |
Lindeman crawler fan
![]() Join Date: Mar 2008
MTF Member # 10122
I like the idea of the 34 inch strip.
If you fastened both sweepers solid to the "T" bar hitch so they don't turn independently, wouldn't they then back up like a regular trailer? You would need to make the tow bar longer so the "T" bar would clear the tires on turns.
__________________
Ray 1945 John Deere Lindeman ( modified ) 1949 Agricat crawler 1946 FMC Bean Cutler ( flat belt drive ) 1948 Bolens Ridemaster - 35AA01 Ser#230 1948 Bolens Ridemaster - 35AA01 Ser#457 1948 Bolens Ridemaster - 35AB01 1953 Bolens Ridemaster 35AB03 ( modified cart ) 1937 Shaw Du-All tractor conversion "R/T" home made tractor http://www.youtube.com/watch?v=-1aD1wn7yNE |
#14 |
Tech Exchange Moderator
![]() ![]() ![]() Join Date: Mar 2005
MTF Member # 24
Perkins use to make a 3 across sweeper pull behined for IH Cub Cadet in the 1960's& 70's It just like the design above except you had a sweeper behined the two and it was in the middle
__________________
John Deere Models:X485,140H3,112,Sabre 1542 Cub Cadet Models:0riginal,70,106,2206 & Experimental Non Production Rear engine rider Ingersoll Model:3016PS Simplicity Models:Wonder Boy,7016 White Model: GT2055 "The only thing necessary for the triumph of evil is for good men to do nothing." Edmund Burke |
| Sponsored Links | |
Advertisement |
#15 |
5000 Strong & Climbing
![]() Join Date: Dec 2007
MTF Member # 8602
You could fabricate something like our tandem hay rakes...
__________________
So Long, and Thanks for All the Fish |
| Sponsored Links | |
Advertisement | |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
