NEw (OLD) Sears SS16 Onan Tractor - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 04-08-2009, 09:05 PM   post #1 of 16
buzz1
MTF Junior Poster
MTF Member # 23806
Default NEw (OLD) Sears SS16 Onan Tractor
Just about ready to start a restoration on a 1974 Sears SS16 Onan Engine Package. I has not ran in years... but not sure where to start. DO I start replacing everything... gaskets, carb, rebuild transmission??? To get it to run, I would have to hope the carburator worked... and dont think it does, at least not good? How do you see what I have to work with? Should I take it to a shop and pay to see what I have to work with?/ Suggestions?? Buzz
buzz1 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-08-2009, 09:08 PM   post #2 of 16
SonnyT
Hoosier Born & Raised!
SonnyT's Avatar
MTF Member # 21893
Images: 26
Garage
Default Re: NEw (OLD) Sears SS16 Onan Tractor
Does the engine turn over at all, by hand?
__________________
SonnyT is online now   Reply With Quote Quick reply to this message
Old 04-08-2009, 09:55 PM   post #3 of 16
TOMMY
MEMBER
TOMMY's Avatar
MTF Member # 11701
Nice looking tractor Buzz,here is a thread I posted about checking onan engines,alot of useful info in it.
http://www.mytractorforum.com/showthread.php?t=64591
TOMMY
__________________
2010 JD X320
48 FARMALL SUPER A
74 Sears ST-12(Disassembled)
74 Sears ST-12
73 Sears ST-12
TOMMY is offline   Reply With Quote Quick reply to this message
Old 04-08-2009, 10:03 PM   post #4 of 16
Wid LT1000
Senior MTF Member
Wid LT1000's Avatar
MTF Member # 15471
Buzz,
Thanks for the pics. I love these old machines, can't wait to get one of my own.
Good luck, and you'll get plenty of advice from the experts around here.
__________________
Chad
2001 Craftsman LT1000 16HP Kohler Command
2008 CC SLT1554 27HP Kohler Courage
Wid LT1000 is offline   Reply With Quote Quick reply to this message
Old 04-08-2009, 10:56 PM   post #5 of 16
Tractor-Holic
10,000 +posts!
Tractor-Holic's Avatar
MTF Member # 8867
I wouldn't worry,I have an 25 HP Onan twin very similar a friend traded me for a winch and some work--it had sat 15 years in his shed when I got it,and it sat 5 more in my garage,before I finally tried getting it running,to try and use ,to run a huge air compressor..I figured the carb would be junk,but it wasn't
I did not even have to take it off or clean it--it started after cranking it over about 15 times on choke,and it did flood once--after it ran about 30 seconds I heard it start smoothing out a lot better--I added some fuel system cleaner and marvel mystery oil to the gas,and it ran great for an hour or more..(I just pray it runs as good next time I go to run it,after sitting another 5 years since then!--the air compressor project was abandoned)..
I've had to get a few Onan's on motor home generators going after long neglected periods of non-use,and it was not diffucult to clean the carb,getting them OFF while in that cubby hole compartment was the worst part of the job..some have cork floats that are likely to be very fragile,and possibly no good,they tend to get "heavy" and sink with age,gas soaks into them...a brass one is a lot better...these engines were made for heavy duty industrial use,and can take abuse and long "downtime" pretty well..but if its been left out to the weather,anything will need restoration of course..
Looks like you found a diamond in the rough!..I'm very tempted to put my Onan on a parts Suburban I bought that originally had one on it,as far as I can tell,by the chassis being different where the engine mounts to it..but I'll need a second parts tractor to complete it,its missing a lot of things..
Tractor-Holic is offline   Reply With Quote Quick reply to this message
Old 05-18-2009, 10:24 PM   post #6 of 16
Loremaster72
Proud Member of the 1K Club
Loremaster72's Avatar
MTF Member # 25731
I've got the same model tractor, but it has a slightly newer Onan engine (B43M series). Mine has a diaphram fuel pump on the carb, so getting a factory carb rebuild kit really helps. I ended up having to go to a Cummins truck dealer to get the Onan carb rebuild kit. I love the way mine runs. It will push or pull up til you lose traction.
Also, it looks like your hood is still intact. There is probably a wire rope section stringing between the hood that opens and the base frame. This is very important, as it is the hood support and takes the weight of the hood in the open position. The fiberglass hood section will break if this isn't there. I've seen this on almost every other Sears of this era.
Good luck with the restoration. Post some more pics when you can.
Loremaster72 is offline   Reply With Quote Quick reply to this message
Old 05-19-2009, 12:52 AM   post #7 of 16
Dude11
2000 Posts and climbing!!!
Dude11's Avatar
MTF Member # 8852
Images: 4
As hard as it is--try very hard to get everything in good running condition prior to any restorial stuff.Once you've done that you will have a good base to work from plus you will have learned how and where things are and how to fix or replace them.I have done it myself,"Oh,I'll remember how that goes on."--NOT---Do it the right way and you'll enjoy it more.All it cost is hundreds of dollars,months of time,use of all the tools you own now plus countless trips for more,hours on the computor bidding wayyy too much on the last part on earth,and most important--bucket loads of knuckle-meat!!But **** we all do it,man-up,take pics.and keep us posted,we love it!!
__________________
Dude11
Dude11 is offline   Reply With Quote Quick reply to this message
Old 05-19-2009, 07:53 AM   post #8 of 16
slkpk
USMC
slkpk's Avatar
MTF Member # 37
Images: 21
I really like the looks and ruggedness of the old SS. slkpk
__________________
1964 JD RF110 Restored
2004 Ingersoll 318LGT @ the church doing the Lord's work
2007 JD 2305
It's too late to worry about it now!
slkpk is offline   Reply With Quote Quick reply to this message
Old 05-29-2009, 05:42 PM   post #9 of 16
rattosh51
JD318
rattosh51's Avatar
MTF Member # 2535
Images: 2
points, plugs, change fluids and try it.
__________________
Rattosh51
'85 JD318 w/54 blade, 50" deck
'90 Yamaha YT6800 48" deck
'75 JD100 34" deck
'98 Craftsman 16.5hp 42" deck
rattosh51 is offline   Reply With Quote Quick reply to this message
Old 05-29-2009, 11:59 PM   post #10 of 16
bwdbrn1
bwdbrn1's Avatar
MTF Member # 18767
Images: 3
You're going to love that thing when you hear it run for the first time! I know I did when mine started. I must have been lucky with mine because it had been sitting under a tarp for God knows how long before I got it. After charging the battery, and checking that the wiring was all hooked up, I turned the key, shot some starter fluid in the carb, and it fired! I've rebuilt the carb, and fuel pump, but never have checked the points other than to take the cover off to see that there isn't any crud under it. Darn thing absolutely purrs.
This guy here has a huge library of manuals for the Suburban line.
http://sears.pammar.net/
Good luck with yours, and have fun.
bwdbrn1 is online now   Reply With Quote Quick reply to this message
Old 05-30-2009, 12:47 AM   post #11 of 16
BLIND REF
MTF Concierge
BLIND REF's Avatar
MTF Member # 8658
Garage
Quote:
I am a big fan of the old SS. Especially with the onan engine.
__________________
John Deere 2305 TLB, 62MMM
BLIND REF is online now   Reply With Quote Quick reply to this message
Old 02-17-2010, 11:17 PM   post #12 of 16
220pawn
MTF Junior Poster
MTF Member # 38339
Need help. I broke the outlet for the gas line on the fuel pump of my sears ss16 with twin onan. Help........Give me a call i also have several attachments for the sears example. mower, plows etc for sale. 540-904-8451
220pawn is offline   Reply With Quote Quick reply to this message
Old 02-17-2010, 11:18 PM   post #13 of 16
220pawn
MTF Junior Poster
MTF Member # 38339
Sears ss16. I have a sickle mower, hay rake, plows, and electric hitch for sale. 540-904-8451.
Old 02-17-2010, 11:27 PM   post #14 of 16
Small Fry
5000 Strong & Climbing
Small Fry's Avatar
MTF Member # 8155
Quote:
Do you have 2 nipples on your pump ? If so you maybe able to block the broken one and drill a hole in the other nipple.
If not you can buy a rebuild kit and you get that part. 70 bucks or so.
What are you asking for the elec. hitch ?
__________________
Small Fry is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-17-2010, 11:28 PM   post #15 of 16
Small Fry
Small Fry's Avatar
MTF Member # 8155
Maybe post this stuff in the for sale forum.
__________________
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
