snapper yt12d rear end fluid? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 03-23-2009, 09:27 AM   post #1 of 2
ragman396
MTF Junior Poster
ragman396's Avatar
MTF Member # 23481
Default snapper yt12d rear end fluid?
On the left rear side cover I took off the rubber gromet and it looks like its full of bearing grease. Is this right? I cant seem to find what the fluid is to be.
Any help out there? Thanks in advanced for any help with this....
Steve
ragman396 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-11-2009, 09:24 PM   post #2 of 2
mark2550
MTF Junior Poster
MTF Member # 30848
Default Re: snapper yt12d rear end fluid?
According to the manual for transmission differential remove check plug on the inside of the unit to check level of oil. add snapper #0 grease as needed thru upper fill hole to bring level up to the lower of the check plug hole. reinstall plugs. (chain case) remove plug and check if dry, add 1 ounce of snapper 0 grease do not overfill. Total capacity must not exceed 2 ounces. These our direct quotes from a yt 12d series 4 tractor manual
mark2550 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
