Members List MTF Gallery Add To Favorites! MyLawnMowerForum.com - Lawnmower Forum FAQ
Register Home MTF Gallery Search Today's Posts Mark Forums Read
The Barn General discussion of Full size tractors and accessories
Reply
Thread Tools Display Modes
Old 03-03-2009, 08:23 AM   #1
JD40
Heater of branding irons
JD40's Avatar
MTF Member # 20360
Help Farmall M(grader)
Guys,
I just got back from the woods this morning from visiting my Farmall. It is kinda sad.It has been abandoned for about 30 years. It has only been protected by a tarp.For the most part it seems complete and solid.Would this be worth my time or should I just leave it there? The man says I can have it for my Toyota Diesel.Would it be worth that? Sorry for the long post.
JD40 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 03-03-2009, 08:36 AM   #2
tiretrx
Tractor Color Blind
tiretrx's Avatar
MTF Member # 13571
Default Re: Farmall M(grader)
Like to give you an opinion, but I would need a few photos of the Farmall and an idea what you think your Toyotas worth. Is the tractor stuck or has this subject been covered in another post?
__________________
Regards, Ellis
1991 Gravely 24G "Hoss"
1980 Gravely 8169
1967 Gravely 424
1968 Gravely 432
1969 Wheel Horse 700
2000 John Deere LT155
1982 John Deere 210
1966 Cub Cadet 102
1963 Simplicity 725
1949 IH Cub
1968 Ford 3000 FEL "Blue"
1960 Bungartz T5 Diesel
Here's to Old Iron
tiretrx is offline   Reply With Quote
Old 03-03-2009, 08:48 AM   #3
freebird
Camaniac
freebird's Avatar
MTF Member # 63
Images: 8
We'd like to see some pics please. Also to ask if you have a shop?
__________________
1956 Cub Lo-Boy
JD LA175
JD LT133
JD RX73
Sears 16/6
If you can't fix it with a hammer, it must be an electrical problem!
freebird is online now   Reply With Quote
Old 03-03-2009, 08:50 AM   #4
JD40
JD40's Avatar
MTF Member # 20360
No this is the first post on it. My toyota is another freebie so you can't really lose money on that.Aboutthe tractor the engine of course is stuck,but I'm not so sure how bad.The sheet metal is mostly good. The grader part is good and solid. The tires are well, crappy but that isn't suprising.But they do allow it to roll back and forth.The seal around the shifter is tight also.I will try to get pictures.
Old 04-02-2009, 06:30 AM   #5
Paul J
Old Crop Duster
Paul J's Avatar
MTF Member # 19817
Images: 1
Quote:
A factory built Farmall grader is a fairly rare find. It would be a nice museum piece if you plan on restoring it. I could be wrong but, I would think it would be more valuable to a collector than a straight "M". There's plenty of those around. JMHO. PJ
Paul J is offline   Reply With Quote
Old 04-02-2009, 06:35 PM   #6
parts man
2000 Posts and climbing!!!
parts man's Avatar
MTF Member # 9
Send a message via MSN to parts man
Paul J is right, a very collectable machine, not really sure of the value of a restored one, but definetly unique. Seized engine is not a huge problem, they are a sleeved engine so you can get cylinder kits and have a new engine as ong as it hasn't had a bunch of water in the block and froze and broke the block.
__________________
VP of TSA (takin stuff apart)
Need parts? Check out
parts man is offline   Reply With Quote
Old 04-02-2009, 06:41 PM   #7
attorney_barnabas_collins
MTF Junior Poster Esq.
attorney_barnabas_collins's Avatar
MTF Member # 7575
Images: 7
Well it's not like M blocks are rare anyway. At least it isn't a Hoyt-Clagwell.
attorney_barnabas_collins is offline   Reply With Quote
Old 04-02-2009, 08:17 PM   #8
JD40
JD40's Avatar
MTF Member # 20360
Sorry to neglect you guys. I've been very busy and will get you pictures very soon.
Old 04-03-2009, 08:35 AM   #9
Paul J
Old Crop Duster
Paul J's Avatar
MTF Member # 19817
Images: 1
There were various companies that made grader attachments. Here's one made for a 8N Ford.
Old 04-03-2009, 10:36 AM   #10
ZZRGUY
MTF Member
ZZRGUY's Avatar
MTF Member # 20250
Images: 4
Guys,
Toyota Diesel what? Inever seen one you got a pic
If you want a farmall and don't need or use the toyota why not
ZZRGUY is offline   Reply With Quote
Old 04-03-2009, 01:14 PM   #11
MTF Member # 7575
Images: 7
Does it look like this?
Old 04-03-2009, 07:35 PM   #12
grnspot110
Proud Member of the 1K Club
grnspot110's Avatar
MTF Member # 4515
Images: 21
The one on the Ford above was made by Dearborn, they made several attachments for Ford tractors. There is a grader like that one that makes shows in our area.
This one was on a tractor cruise(drive) I was on a few years ago:
Name:	Farmall Grader (Small).jpg
__________________
Home of the JD 317 "Special"!
grnspot110 is offline   Reply With Quote
Old 04-03-2009, 08:13 PM   #13
JD40
JD40's Avatar
MTF Member # 20360
attorney collins,
yeah for the most part.
Old 04-04-2009, 09:59 AM   #14
tcanthonyii
Snapper Lover
MTF Member # 23497
Send a message via MSN to tcanthonyii
If the toyota was a freebie go for it. I would love to get one of those up at my place to fix the driveway.
T.C.
tcanthonyii is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
