Briggs 20hp Twin Governor Shaft Oil Leak - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
Reply
Thread Tools Display Modes
Old 02-24-2009, 12:38 PM   post #1 of 1
seebass322
MTF Member
seebass322's Avatar
MTF Member # 21038
Default Briggs 20hp Twin Governor Shaft Oil Leak
Ok, so I bought a Used Craftsman Tractor with a Briggs Intek and it has an oil leak. I have narrowed the leak down to the governor shaft going into the sump/block in the front right side of the motor. The Motor is a Briggs 20hp V-Twin Intek . It's model 407777 type 0027R. Judging by the engine schematic, I would say I have to replace Item #691 (Part #790574) Governor Shaft Seal. I don't feel any vertical play in the shaft, so I would assume the bushing is still good. The shaft does slide in and out of the block approximately 1/8th". Has anyone done this before? How do I get the shaft out? Do I have to take the shaft out to replace the seal? Could it be leaking due to to much crankcase pressure?
HELP!
Thanks!
~Seebass322
917.272140
Briggs Intek 20hp Twin 407777 Type 0027R
seebass322 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
