gravely governor - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 02-04-2009, 04:41 PM   post #1 of 6
fleter
MTF Junior Poster
MTF Member # 22109
Default gravely governor
hello all, new to the forum. I have a mid 60s 7.5 convertable that has given good service for a long time. recently I started it up and would only run with the choke pulled out. It would rev high when not under load. the governor has a little fill spout the appears empty. does anyone know what weight oil/fluid is recommended for the governor. thanks
fleter is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-04-2009, 10:11 PM   post #2 of 6
Dan 2N
Senior MTF Member
Dan 2N's Avatar
MTF Member # 3578
Images: 13
Default Re: gravely governor
Welcome to the gang, I use #30 in all of my Gravely governors, should be a thumb screw to remove at the bottom of the case body for checking the oil level.
Dan 2N
Dan 2N is offline   Reply With Quote Quick reply to this message
Old 02-05-2009, 07:43 AM   post #3 of 6
fleter
MTF Junior Poster
MTF Member # 22109
thanks, we'll fill 'er up.
Old 08-24-2009, 10:38 AM   post #4 of 6
fleter
MTF Junior Poster
MTF Member # 22109
what is the correct oil level? thanks
Old 08-25-2009, 01:33 AM   post #5 of 6
bluegoose
2000 Posts and climbing!!!
bluegoose's Avatar
MTF Member # 23010
There should be a removable screw on the side/bottom of your governor unit - slowly fill the governor with 10W-30 until the oil starts to run out of the hole - then tighten things back up. I usually put a couple squirts of oil in the unit every couple of times that I use the tractor. I believe that some later governor units were sealed and supposedly perm. self-lubricated.
bluegoose is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-26-2009, 12:20 PM   post #6 of 6
fleter
MTF Junior Poster
MTF Member # 22109
thanks
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
