2554 Scotts transaxle problems - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 02-03-2009, 06:41 PM   post #1 of 41
johndeere100
MTF Member
MTF Member # 19864
Default 2554 Scotts transaxle problems
The transaxle in my 2001 2554 Scotts Hyrdo is slipping. I have been thinking about a replacing it with a larger transaxle. I have found a k66 replacment for a G110 it looks just like mine on Ebay. If I put a better transaxle I would have to make the brackets. Please give some feedback. Ryan
johndeere100 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-04-2009, 02:49 AM   post #2 of 41
Sergeant
Tech Exchange Moderator
Sergeant's Avatar
MTF Member # 24
Default Re: 2554 Scotts transaxle problems
A transaxle from a Sabre GT or a JD G100 or a Transaxle from a GT275 would work as well. Your scotts GT2554 is based on the GT275.
__________________
John Deere Models:X748,140H3,112,Sabre 1542
Cub Cadet Models:0riginal,70,106,2206 & Experimental Non Production Rear engine rider
Ingersoll Model:3016PS
Simplicity Models:Wonder Boy
White Model: GT2055
"The only thing necessary for the triumph of evil is for good men to do nothing." Edmund Burke
Sergeant is offline   Reply With Quote Quick reply to this message
Old 02-04-2009, 07:36 AM   post #3 of 41
Bob-S
MTF Junior Poster
MTF Member # 8729
Hi johndeere100,
The Scotts S2554 came with a k66 transaxle. While the S2048 came with aK62 transaxle.
Bob
Bob-S is offline   Reply With Quote Quick reply to this message
Old 02-04-2009, 09:58 PM   post #4 of 41
johndeere100
MTF Member
MTF Member # 19864
I am looking for a k66 Tuff Torque Transaxle for sale.
Old 02-06-2009, 06:10 AM   post #5 of 41
johndeere100
MTF Member
MTF Member # 19864
Is the G110 K66 transaxle the same? Ryan
Old 02-26-2009, 01:07 AM   post #6 of 41
johndeere100
MTF Member
MTF Member # 19864
I cleaned the old fluid out of the transaxle with a large piece of IV tubing. I had to suck it out. Making sure not to drink it. It was an hour of fun! I got no fluid in my mouth today. It worked great for the transaxles without drain plugs.
Old 02-26-2009, 06:21 PM   post #7 of 41
wally2q
2000 Posts and climbing!!!
wally2q's Avatar
MTF Member # 45
The K66 in the scotts is probably the same as the G110. The G110 was based on the scotts chassis.
You can get a replacement K66 here for $235:
http://www.smallenginedistributors.net/transaxles.html
I got a K66 at that place one time - tranny was brand-new, works great, people were great to work with, order came in less than a week.
All in all: this is where you want to buy your new K66.
wally2q is offline   Reply With Quote Quick reply to this message
Old 02-26-2009, 10:05 PM   post #8 of 41
johndeere100
MTF Member
MTF Member # 19864
Did your transaxle come with a drain plug? Than
Old 02-27-2009, 05:34 AM   post #9 of 41
wally2q
wally2q's Avatar
MTF Member # 45
yes - 2 drain plugs actually, and a reservoir tank, etc.... oil changes are a piece of cake - the difficult part is getting to the fill plug to get the oil in - the tractor frame nearly encloses the whole thing.... 3'8" tubing and a funnel is what I used.
Old 02-27-2009, 05:42 AM   post #10 of 41
wally2q
wally2q's Avatar
MTF Member # 45
I think the K66 has standard drain plugs - they are the 2 bolts on the bottom, that are "bigger heads" than the rest.... and have a "seal washer". They're quite easy to distinguish from the rest of the bolts.
cheers!
Old 02-27-2009, 10:11 PM   post #11 of 41
wanna_be_farmer
Senior MTF Member
wanna_be_farmer's Avatar
MTF Member # 225
Images: 7
What oil did you refill with? How many hours did you get before the slipping? Sorry for the questions, just curious of the lifespan.
__________________
Rory
Toro LX468
wanna_be_farmer is offline   Reply With Quote Quick reply to this message
Old 02-27-2009, 10:26 PM   post #12 of 41
S DIAMOND
MTF Member
S DIAMOND's Avatar
MTF Member # 18630
Rory, the last service I did for a Scotts 2554 called for 5W-50 full synthetic oil.
Actually “they” recommended that or Deere low viscosity Hy-gard, “for demanding environments.”
S DIAMOND is offline   Reply With Quote Quick reply to this message
Old 03-01-2009, 08:03 PM   post #13 of 41
johndeere100
MTF Member
MTF Member # 19864
I use Deere low viscosity Hy-gard. I have about 750 Hrs on my 2554. After servicing the rear end the tractor moves faster.
Old 03-01-2009, 08:05 PM   post #14 of 41
johndeere100
MTF Member
MTF Member # 19864
Thanks Wally2Q I see the bolts you are talking about. I was looking for a drain plug. I like doing things the hard way!
Sponsored Links
Advertisement
Old 03-01-2009, 10:28 PM   post #15 of 41
wally2q
wally2q's Avatar
MTF Member # 45
The TuffTorq web site provides a lot of answers to various maintenance questions about this and other trannies. Feel free to browse.
The tranny is rated for Ground Engaging duty, although it's on the "lighter side" of the GT tranny spectrum.
It should last many years, but the number one killer of the trannies is oil temp. If the tranny case goes above 90 deg. C, the internal oil temp is at a higher level - a level at which it begins to burn and turn to "tar".
Without knowing the specifics of your environment, it's tough to say if your tranny began to fail prematurely or what....
In any case, like many mechanical systems, it may need repair or replacement from time to time.
Even a 1-ton, heavy-duty pick-up truck that only hauls a couple of people every day of its' life, can experience a transmission problem. It happens. It's statistics. It doesn't mean it's useless and "crappy".
How is it after you changed the oil?
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
