WD Hydraulic fluid - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 01-05-2009, 02:59 PM   #1
Inwywind
MTF Junior Poster
MTF Member # 20948
Default WD Hydraulic fluid
My manual shows using SAE 20 Hydraulic fluid. I went to the store which had a selection of three different types of Hydraulic fluid but none said SAE 20. My guess is that in the last 50+ years there have been some improvements and this is no longer made. What fluid should I use?
Inwywind is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-05-2009, 04:13 PM   #2
Inwywind
MTF Junior Poster
MTF Member # 20948
Default Re: WD Hydraulic fluid
Has anyone used UTF universal tractor fluid? it sounds like it could be used in the Transmission, Hydraulics, Rear end, everything...
Old 01-05-2009, 04:26 PM   #3
paul52446m
Senior MTF Member
paul52446m's Avatar
MTF Member # 5089
Send a message via MSN to paul52446m
I have a WH D160, it is a 1980. after i bought the Hydraulic fluid, i read my manual it said i could use 10w30 motor oil. i don't if you can mix them or not?? Motor oil is less money. Later Paul
paul52446m is offline   Reply With Quote
Old 01-05-2009, 04:29 PM   #4
1086
3K Poster!!!!
1086's Avatar
MTF Member # 1086
Images: 11
Quote:
In that era it was common to use 20 or even 30 wt non detergent engine oil in hydraulic systems. Non detergent may have been recommended because of it being a little cheaper then but there was a lot of regular engine oil used too.
I'd look in my WD-45 manual to see if it says but I don't know where it is.
1086 is offline   Reply With Quote
Old 01-07-2009, 11:50 AM   #5
Jeff B
Jeff B
MTF Member # 4268
Maybar is right just use 10 or 20 wt engine oil. I have an old wd45 with a loader that has a little leak on the pump it get's what I have at the time engine oil, dextron and I have used 15w40 in a pinch. keep in mind that hyd. were new to ag tractors in the 40's and 50's they are very basic systems.
Jeff
Jeff B is offline   Reply With Quote
Old 01-10-2009, 11:19 AM   #6
jeff64
MTF Junior Poster
MTF Member # 21371
Inwywind, you should use the Universal Hy-Tran (hydraulic-transmission) oil. In some old machines, the transmission, hydraulics, and differential all used the same oil out of a common reservoir. I think your WD-45 is like that. I know the B/C/CA is. Ford and Ferguson used this system with 90wt. oil, but they used a big piston. Allis used small hydraulic pumps in a high pressure system, and specified the thinner, 20wt. oil. Nondetergent was used because it did not foam and the detergents were unproven in that era. Nowadays, the UTF is the accepted substitute and it has additives that 20wt did not. It is available from Tractor Supply, or Case-IH dealers (Hy-Trans). Other dealers probably have it under some other name.
Don't use regular hydraulic fluid. It works in the hydraulics, but doesn't have the viscosity you need for the differential. The final drives still use 90wt. I've heard of people using 15-40wt in Farmall Cubs, but I don't know if they have heavy drawbar loads or just mowing. I don't know how it would hold up in a larger tractor, but I would think any modern oil would be better than 20wt of the 1940s.
jeff64 is offline   Reply With Quote
Old 01-12-2009, 11:54 AM   #7
Jeff B
Jeff B
MTF Member # 4268
WD and WD45 are not like the B and C The hyd reservoir for the wd is just hyd. the hand clutch and pto are in one and then the rear end and tranny are in there own
Jeff
Old 01-13-2009, 07:54 PM   #8
jeff64
MTF Junior Poster
MTF Member # 21371
Thanks, Jeff B. I didn't realize the WD/WD-45 had a separate hydraulic reservoir. I checked the Yesterday's Tractors forum, and some of those WD owners are using the Universal Hy-Trans oil in their hydraulic systems.
Sponsored Links
Advertisement
Old 01-25-2009, 04:15 PM   #9
Johnlaw
MTF Junior Poster
MTF Member # 21699
I use UTF at work, its made for machines in which the rear end is also the hydraulic tank, it lubricates gears and runs hydraulic system. It has special additives that makes it cost more than just straight hydro fluid. Newer machines are set up this, older ones used a seperate tank for hydro system. I would not use ATF in rearends unless specified. Hope this helps
Johnlaw is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
