Attaching 42" Snow Blade to C160 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 01-02-2009, 07:13 PM   post #1 of 17
wkmcgee
Senior MTF Member
wkmcgee's Avatar
MTF Member # 17793
Images: 5
Default Attaching 42" Snow Blade to C160
OK, it seems so simple, but I could not get the blade attached today. Would you recommend attaching the rear mount first? Is the blade just attached to the rear & then to the lift assembly in the middle of the tractor? I could not get the shaft in the holes in the back. Tried to lift it & hook it by myself & just couldn't do it. Then I tried setting it on blocks so I didn't have to lift it so far, but still couldn't get it attached.
When I went to hook the lift assembly in the middle, I don't think I was doing that right either. Here are some pictures of what I have. This blade was attached when I bought it, so I know it fits, etc.
The part in the last picture (short link?) was attached to the part in the first picture with the bolt that is in picture 1. From the drawing on Toro, it looks like it is attached to blade & lift assy with clevis pins. Is Pic #3 the lift assembly? The drawing shows a lift bar. Do I attach the short link to the part that sticks out on the lift lever in Pic 2 or to the hole to the left with a clevis pin???
I am sorry guys that I am so new at this. I'm in training, remember!! Any help you can give me is always appreciated.
Wanda
__________________
Wanda
Goochland, VA
1975 Wheel Horse C160 w/Hydraulic Lift (Kohler K 16)
42" Side Discharge Rotary Mower (1975)
36" Tiller (1974)
42" Snow/Dozer Blade (1975)
10" Brinly Plow w/Coulter (1975)
WH Cultivator (NOS)
2005 Kubota BX1500 4WD
Kubota Front Loader LA181FL
1985 BCS 725 2-Wheel Walk-Behind (Kohler M 8)
Berta Rotary Plow (2006)
30" Tiller (1985)
36" Sickle Bar Mower (1985)
36" Dozer Blade (2006)
Hiller/Furrower (2006)
Chipper/Shredder Bio 100
wkmcgee is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 01-02-2009, 07:25 PM   post #2 of 17
paul52446m
Senior MTF Member
paul52446m's Avatar
MTF Member # 5089
Default Re: Attaching 42" Snow Blade to C160
In pic. one, the little plate in pic. three goes from the bolt in the blade frame straight up to the hole in your lift bar
paul52446m is offline   Reply With Quote Quick reply to this message
Old 01-02-2009, 07:36 PM   post #3 of 17
wkmcgee
Senior MTF Member
wkmcgee's Avatar
MTF Member # 17793
Images: 5
OK, that resolves that. Thanks so much.
Wanda
__________________
Wanda
Goochland, VA
36" Tiller (1974)
WH Cultivator (NOS)
30" Tiller (1985)
Old 01-02-2009, 08:41 PM   post #4 of 17
wkmcgee
Senior MTF Member
wkmcgee's Avatar
MTF Member # 17793
Images: 5
Do I need to take the blade off, install the frame then remount the blade? Is that the trick?
__________________
Wanda
Goochland, VA
36" Tiller (1974)
WH Cultivator (NOS)
30" Tiller (1985)
Old 01-02-2009, 09:36 PM   post #5 of 17
4StarCstms
Senior MTF Member
4StarCstms's Avatar
MTF Member # 10781
Wanda, I get it all lined up, Mount the Lift Link - Raise the blade, and it should fall right into the rear hitch, and hold it there...allowing you to close and pin hitch...
__________________
1976 B-80 36" RD Deck
1987 418A 42" SD Deck
54" Snow Blade -
Sleeve Hitch -
WH 36" Tiller -
WH Cultivator -
Lowes 4 Wheel Wagon
My Youtube Videos
Stihl K55 Kombi-Motor
String Trimmer - Cultivator
[/FONT]
4StarCstms is offline   Reply With Quote Quick reply to this message
Old 01-02-2009, 10:52 PM   post #6 of 17
Teddy da Bear
Oldbie
MTF Member # 5659
Wanda.....
I put the bar of the plow frame in the rear quick hitch first.
I use a short car jack (out of my corvette) and jack the bar
into the slots in the quick hitch. You may have to go to the
front of the tractor and nudge the whole plow to the left or
right to square up the plow frame to allow the bar to fit into
both sides of the quick hitch. Once in place....clamp it in
with the clamp arms. Then go to the front of the blade and
raise it up and set it on blocks as high as it will go (you could
use the jack here also). Then pull your impliment lift arm up
until it locks in the "up" position. Then you can attach the
mid-lift (in your picture) with your pins and bar (you also have
shown). You can then take it down from the blocks (or jack)
in the front.
You can also take the time to adjust the working height if you
do not have a cement or asphalt drive. Lift the plow and set
it on blocks again until it is approzimately 1/4" to 1/2" above
a flat level surface. Lower your lift arm and adjust your lift
limit adjustment knob.until your arm rises slightly. You can
now lower your plow and it should ride at the above measurments
so you won't scrape up a pile of rocks when you plow snow.
If you have cement or asphalt.....you can let the blade scrape
the surface of the drive. But it is entirely up to you.
Keep us posted....
__________________
M.
Teddy da Bear is offline   Reply With Quote Quick reply to this message
Old 01-03-2009, 01:26 PM   post #7 of 17
Teddy da Bear
Oldbie
MTF Member # 5659
Don't keep us in suspense.. Did you get it on?
__________________
M.
Old 01-03-2009, 03:01 PM   post #8 of 17
wkmcgee
Senior MTF Member
wkmcgee's Avatar
MTF Member # 17793
Images: 5
Quote:
I haven't tried yet. Sorry. I had to work on that pesky left wheel hub again. I can't figure out why it still works itself loose.
Having a family bonfire tonight in the garden, so won't have time until tomorrow. I'll let you know though. I printed out your instructions. Thanks.
Wanda
__________________
Wanda
Goochland, VA
36" Tiller (1974)
WH Cultivator (NOS)
30" Tiller (1985)
Old 01-03-2009, 06:14 PM   post #9 of 17
glenn27
10,000 +posts!
glenn27's Avatar
MTF Member # 703
Images: 2
Let us know....
__________________
Sometimes you just have to laugh..To keep from going insane!!
Jimmy Buffett
glenn27 is offline   Reply With Quote Quick reply to this message
Old 01-03-2009, 07:29 PM   post #10 of 17
Teddy da Bear
Oldbie
MTF Member # 5659
Roll that tractor out to the Bonfire..... You can have a round table on it....lol
__________________
M.
Old 01-03-2009, 11:16 PM   post #11 of 17
wkmcgee
Senior MTF Member
wkmcgee's Avatar
MTF Member # 17793
Images: 5
I did use my tractor with wagon attached to take my great nephew for rides around the farm. He was afraid of the noise at first, but after his first trip he was hooked. We had a blast! Hopefully, will attach blade tomorrow.
Wanda
__________________
Wanda
Goochland, VA
36" Tiller (1974)
WH Cultivator (NOS)
30" Tiller (1985)
Old 01-03-2009, 11:38 PM   post #12 of 17
Tmo
MTF Member # 89
Wanda,
Go to the Red Square Wheel Horse site and particularly to this post:
http://whtractor.15.forumer.com/inde...showtopic=5988
It gives you info on the snow plows. And for info for installation, go to this one: http://whtractor.15.forumer.com/index.php?showtopic=291
Tmo is offline   Reply With Quote Quick reply to this message
Old 01-04-2009, 01:41 AM   post #13 of 17
4StarCstms
Senior MTF Member
4StarCstms's Avatar
MTF Member # 10781
Need to repost the pics in that second thread. All the links are no good..
Btw that was a helpful post over there!
__________________
54" Snow Blade -
Sleeve Hitch -
WH 36" Tiller -
WH Cultivator -
Lowes 4 Wheel Wagon
My Youtube Videos
[/FONT]
Old 01-04-2009, 11:50 AM   post #14 of 17
rwilson
Senior MTF Member
MTF Member # 20302
Are you guys members of redsquare too?
__________________
It was broke, then I welded it, But its still broke!!!!
1975 WH C-120 special
46" deck
48" craftsman blade, homemade bracket to fit.
clevis style hitch
no attachments yet
1972 WH 800 Comando
1974 WH B-80 4 speed
WH 520-H
48" deck
rwilson is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 01-04-2009, 12:54 PM   post #15 of 17
4StarCstms
Senior MTF Member
4StarCstms's Avatar
MTF Member # 10781
Yeah, Thou I try not to just post links to RedSquare. Does'nt help MTF IMO
__________________
54" Snow Blade -
Sleeve Hitch -
WH 36" Tiller -
WH Cultivator -
Lowes 4 Wheel Wagon
My Youtube Videos
[/FONT]
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
