Members List MTF Gallery Add To Favorites! MyLawnMowerForum.com - Lawnmower Forum FAQ
Register Home MTF Gallery Search Today's Posts Mark Forums Read
Reply
Thread Tools Display Modes
Old 01-01-2009, 11:52 AM   #1
Kens Cub Cadet
MTF Junior Poster
MTF Member # 20689
Default Need help w/wiring issues-no spark
Hey everyone, still going crazy not being able to figure this issue out with my Cub Cadet 2140 w/onan 14 hp single cylinder. I'm getting no spark, I still have to try to gap the coil/ignition module, but I'm starting to think it's something else because the previous owner (my father) never had an issue w/ no spark until he started messing with overridding the safteys on the thing. Does anyone have a wiring diagram for this tractor? I have the cub cadet service manual and it has no info on the engine at all. Is there a seperate manual for the engine? There has to be some issue with getting power to the coil that I don't know about, but I'm kinda lost w/o a wiring diagram. Any help would be great. Thanks in advance, Ken
P.S. Happy New Year to all !!!!!
Kens Cub Cadet is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-01-2009, 12:05 PM   #2
davidg
5K posts and climbing
davidg's Avatar
MTF Member # 807
Images: 2
Default Re: Need help w/wiring issues-no spark
well, sinc ethe problem started when he attempted to bypass the safeties, that tells me he screwed up and has the coil grounded. there will be a single wire going to the coil other than the plug wire(s). clip it and see if you get spark. be sure you leave plenty of wire there though, cause you need to hook it back together to kill the engine!
i can't help with teh diagram, but this should tell you if the coil is good.
you could also check teh safeties themselves. there will be one on the seat, one on the PTO, one on the brake, and one on the reverse linkage. pops probably just unplugged one of them, and this won't work on most safeties. some you unplug, some you short, and he got it wrong on one or more.
__________________
2008 Deere X500 48" with integral hitch
2004 Deere L130 48" with 15 gallon sprayer permanent mounted
1993 Craftsman GT6000 with AG tires and 3 pt mounted Snapper tiller
Bolen's 21" push mower
Craftsman 14" rear tine tiller
SH implements: Disc, Tine Cultivator, and Brinly 12" plow
Sundowner tow behind with blade
davidg is offline   Reply With Quote
Old 01-01-2009, 12:34 PM   #3
Bill Kapaun
Circumflatulater
Bill Kapaun's Avatar
MTF Member # 6264
You can get a schematic here-
http://ihregistry.com/wiring/master.html
DON'T CLIP any wires!
There should be a connector!
The engine connector shows the Yellow wire to it as the kill wire.
You could unplug that connector and manually jumper the starter solenoid to crank the engine.
A defective seat switch is the likely culprit.
Unplugging it should disable it.
Beware that it MIGHT have a "shorting" connector. IF SO, unplugging it doesn't do any good, because there's a metal tab that slides in place and completes the circuit to ground.
The schematic doesn't show that type though.
Bill Kapaun is offline   Reply With Quote
Old 01-01-2009, 12:34 PM   #4
Kens Cub Cadet
MTF Junior Poster
MTF Member # 20689
Thanks for the quick response, I'll try that today and see if it works, Hopefully it's something easy like that, I bought a new coil ($105.00) and the wife wasn't happy when that didn't fix it.
Ken
Old 01-01-2009, 12:45 PM   #5
Kens Cub Cadet
MTF Junior Poster
MTF Member # 20689
I don't know if this information matters (forgot to put it in the 1st post), but It cranks just fine, I just have no spark at the plug w/ a new coil. I do still need to gap the coil so I'll try that 1st and see if I have any luck. Thanks again for the help and the diagrams are a life-saver!!!!
Ken
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
