Cub cadet dump bed - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Home Made Tractors, Implements and Accessories For you guys handy with a blow torch, welder or a wrench.. show us what you can do....
Reply
Thread Tools Display Modes
Old 12-26-2008, 11:09 PM   post #1 of 104
atatro
MTF Member
atatro's Avatar
MTF Member # 20929
Default Cub cadet dump bed
I'm getting ready to take a 105 cub cadet and streach the frame and add a dump bed to it. I'm looking for ideas at this point. Does anyone have any pictures of something like this. Any input would be great.
Thanks
Andy
atatro is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 12-26-2008, 11:22 PM   post #2 of 104
Nathan Werneburg
Professor of makin stuff
Nathan Werneburg's Avatar
MTF Member # 20392
Default Re: Cub cadet dump bed
got a dump bed trailer home made if that will help
Nathan Werneburg is offline   Reply With Quote Quick reply to this message
Old 12-28-2008, 08:52 PM   post #3 of 104
atatro
MTF Member
atatro's Avatar
MTF Member # 20929
Well I got started on the 105 dump bed today. WOW!! This is the first time that I've had to work much on a narrow frame. I like the wide frames much better. I gurantee one thing that when this goes back together it will be more like a wide frame than a narrow. I'm planning on making the tunnel cover come off for one thing. The plan is to stretch the frame about 3 feet and add a hydraulic dump bed. I think that I'm going to look for a doner narrow frame for the stretch. Does anyone know if the 100 has the same frame? I think that I have a 100 frame at my dads place. Thanks, Andy
Name:	will cub before.jpg
ID:	57713   Click image for larger version
ID:	57714   Click image for larger version
ID:	57715   Click image for larger version
Old 01-02-2009, 09:04 PM   post #4 of 104
atatro
MTF Member
atatro's Avatar
MTF Member # 20929
Well I made some progress on the 105 dump truck today. I'm going to work tomarrow and going to bend the frame rails that I need to fill in the gap. I should have more pictures tomarrow. I'm streching the frame 38.5 inches.
ID:	57973   Click image for larger version
Old 01-02-2009, 09:10 PM   post #5 of 104
Nathan Werneburg
MTF Member # 20392
thats a long sucker now wonder how its going to turn though well well have to wait and see kind of like my chronicles that i post
Old 01-02-2009, 10:13 PM   post #6 of 104
Magnum RT
2000 Posts and climbing!!!
Magnum RT's Avatar
MTF Member # 4746
Images: 10
Be sure to design for some flex, because it will! I would also want to allow ground clearance for the box when it dumps so that it will empty cleanly. I built a hydraulic dump and had to drag it to empty. This fall, I removed the box and moved it forward about a foot. The tongue was long enough for me to do that. Now I can dump with out dragging.
__________________
Rol
Extreme S.W. Michigan
Ingersoll Fan
Green Bay Packers Fan
A lazy mind finds easier solutions!
Magnum RT is offline   Reply With Quote Quick reply to this message
Old 01-03-2009, 02:25 AM   post #7 of 104
kawiram
MTF Junior Poster
MTF Member # 8287
how are you going to get the power to the rear end?
__________________
White GT954H
Murray 14/42
kawiram is offline   Reply With Quote Quick reply to this message
Old 01-03-2009, 10:54 AM   post #8 of 104
Magnum RT
Magnum RT's Avatar
MTF Member # 4746
Images: 10
Qoute: How will you get power to the rear end? end quote
You could use a Case/Ingersoll transaxle and just run two hydraulic lines!
That would be my choice!
__________________
Rol
Ingersoll Fan
Old 01-03-2009, 11:56 AM   post #9 of 104
drbailey
Ratchet Jaw old Member
drbailey's Avatar
MTF Member # 71
Images: 33
Garage
Quote:
Thanks
Andy
This is interesting , Im following your threads. I also like your friends grader and drag cub.
Here is what I started on last week , should finish it in a couple weeks.
It will be a working mower.
__________________
]Dont junk it,build a Hot Rod...
drbailey is offline   Reply With Quote Quick reply to this message
Old 01-03-2009, 08:25 PM   post #10 of 104
atatro
MTF Member
atatro's Avatar
MTF Member # 20929
Well I got some time today to get the frame rails bent and welded in place.
ID:	58038   Click image for larger version
ID:	58039   Click image for larger version
Old 01-03-2009, 08:31 PM   post #11 of 104
AcreFarm
Master Dismantler
AcreFarm's Avatar
MTF Member # 4194
Images: 7
Lookin' good, needs duals
__________________
GTTalk
AcreFarm is offline   Reply With Quote Quick reply to this message
Old 01-03-2009, 09:40 PM   post #12 of 104
mdmre
MTF Member
mdmre's Avatar
MTF Member # 20697
Images: 3
I think a tandem axle at the rear would look nice!
mdmre is offline   Reply With Quote Quick reply to this message
Old 01-03-2009, 10:05 PM   post #13 of 104
johnboggs21
The Link King
johnboggs21's Avatar
MTF Member # 9494
yea tandems would be awesome
Maybe put an dead axle out back just for extra load support and you get that cool factor
__________________
I'm gonna sign my name in that diesel smoke and let the ones that come along behind me choke!
1993 Ford F-250HD 7.3L IDI 370,000 miles
Just follow the diesel fumes and the banjo music
http://murray.forumotion.com
johnboggs21 is offline   Reply With Quote Quick reply to this message
Old 01-03-2009, 10:22 PM   post #14 of 104
dirtybug
Senior MTF Member
MTF Member # 20744
It shouldn;t be too tough to make it a live set of wheels if you can find an identical trans. If you where to make it a dead axle you could run the risk of low centering with the drive wheels off the ground. I've been planning to do a tandem axle, the search for a cheap matching trans continues.
dirtybug is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 01-03-2009, 10:34 PM   post #15 of 104
ElectricalBen
To Much Useless knowledge
ElectricalBen's Avatar
MTF Member # 6539
Images: 3
Looking good this is a pretty creative and useful project. you could put some extra seats on so you can mow with so buddies
ElectricalBen is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
