| Home | MTF Gallery | Add To Favorites! | Set MTF As Your Homepage | FAQ | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Photography Pics spice up the forum. Cameras, use and reviews |
Thread Tools | Display Modes |
#1 |
3K Poster!!!!
![]() Join Date: Dec 2005
MTF Member # 1086
Reading snow blowing posts triggered a thought that's easy to often forget when taking pics and videos.
Before returning the cold camera to the indoor environment it is generally an accepted practice to place the camera in a plastic bag to prevent condensation. When the camera reaches room temperature it can then be removed. |
#2 |
Super Mod Orator
![]() ![]() Join Date: Mar 2005
MTF Member # 14
Good idea. I've always wondered about that. No use taking chances!
__________________
![]() John Deere 2210, 62" MMM, 210 FEL, LX-4 Rotary Cutter Lawn Boy Silver Series 21" SP RedMax EBZ7100 Backpack Blower RedMax BCZ2400S String Trimmer Echo CRS345 Chainsaw Echo ES 2100 Blower Vac Stihl FS52 String Trimmer |
#3 |
LIFE MEMBER
![]() ![]() Join Date: Apr 2005
MTF Member # 284
I would think putting it in a plastic bag, would keep any condensation in, while it warmed up ?? No ? Yes ?
I am not saying your wrong at all .. just asking |
#4 |
(O\_!_/O)
MTF Member # 7780
#5 |
Proud Member of the 1K Club
MTF Member # 18268
Then the crumbs would jam up the video drive!
__________________
A Day Inport Is Like A Day Without Sunshine! USS TULLIBEE (SSN-597), USS FULTON (AS-11), USS PAIUTE (ATF-159), USS BAINBRIDGE (CGN-25), USS ASHLAND (LSD-48), USS GRAPPLE (ARS-53) Naval Station Guam, US Forces Carribean Key West FL, EOD Group Two VA, Allied Command Atlantic (NATO), VA. |
#6 | |
3K Poster!!!!
MTF Member # 1086
Quote:
No --- There will be no condensation form until the camera is subjected to a warmer atmosphere that has a dew point temperature higher than the camera temperature. By placing it in the bag room air can't come in contact. Remove it when it has reached room temp. Hope I explained that right. Firearms are another item where this is a common error. Then later it's a puzzle as to what caused all that rust on my gun. I've never been out in the rain with it. ![]() |
#7 |
2000 Posts and climbing!!!
MTF Member # 43
same principal as a dehumidifier. room temp air blown across a cold coil & water from the air condenses on the coil to the point it drips off into a bin.
#8 |
Live from Mars!
MTF Member # 12
That's a good suggestion. As the air and camera warm in the sealed bag the internal humidity level in the bag will actually drop.
(Warm air can hold more water. That's why it condenses on cold surfaces or in this case only the exterior of the bag.) *But you do need to put it in the bag while still outside so the air in the bag is also cold or it will have already started to sweat.* Last edited by Mark / Ohio : 12-28-2008 at 10:30 PM. |
#9 |
MTF Member # 8803
I have a bit of experience with optics and massive temp changes. regularily hunt/work in -40 C out of a house/truck that is kept at + 20.
For us cameras go in outside jacket Pocket not in bags when going from one temp to the other. You need to allow these things to freeze and dethaw slowly. the jacket allows this to happen. Scopes and rifles are kept in the cold as much as possible but when brought in or out a blanket, jacket or some other clothing is w***** loosley around it until temps equalize. I layed a -30C win 94 inside a trailer where the wife was boiling a kettle, I could not believe the water! within a couple minutes it was dripping and icicles were forming! I have missed great wildlife photos because I thougt I'd have time to click the shutter before things fogged up WRONG. |
#10 | |
Tech Nerd Tractor Convert
![]() Join Date: Oct 2008
MTF Member # 18867
Quote:
Also moisture in air tends to want to spread out evenly so even without much airflow if the cold camera had dehumidified just the air nearby it, it would quickly equalize in moisture content to the air further out, causing the camera to have access to yet more moisture, repeat, etc so long as the camera body remains cooler than the surrounding moist air. This is why a little portable dehumidifier can dry a large space even though it's a little box in a corner with a weak fan. By the way, it's generally not a good idea to let LCD screens get *really cold*. They contain a liquid crystal fluid which could freeze and expand and crack the screen. It will freeze at a lower temperature than water, but why take the risk? If you're going to go on a long cold ride somewhere, the camera will fare better in an inside pocket vs an outside one where it will stay warmer due to body heat. This will also help avoid the condensate effect when bringing it indoors.
__________________
Paul. Cub ZTT50/i1050 | Tach | Deck | Blade | Blower | Chains | Cyclone | Sweep | Gators | Cart | Knob | PC "Time is nature's way of keeping everything from happening at once." Last edited by Toolin : 12-29-2008 at 04:34 PM. |
#11 |
Custom User
MTF Member # 82
Old wisdom used to tell us that we should keep our SLR "button batteries" warm before use. Hence I had 3 holders with 2 in pocket warm at all times. Zat still apply to the new tech NMiH's, etc.?
__________________
"Well, I won't do THAT again any time soon!" (Or so I thought!) John Deere '04 GX335, 48C Deck, PowrFlo w/ 1 single twin double (dual) bagger @ 7 bu. (that's 'bushels' folks, seven bushels, WOW!), JD 42" snowthrower, JD 48" front blade, JD front dethatcher, JD 10cu.ft. cart/system platform, Brinley plug aerator, Earthway tow spreader, 1996 Snapper RP21600 (re-engined to 6.75hp Quantum Briggs), Stihl 026Pro w/20".325", Ryobi 725r w/trimmer and tiller, 1 White-Henway, Stihl BG-85 blower w/gutter kit and giant silent dog whistle |
#12 | |
MTF Member # 18867
Quote:
Here's some information posted on a climber.org on the cold-temperature performance of different types of batteries And here's a short discussion on the same topic on Photo.net, a photography website. |
#13 |
Custom User
MTF Member # 82
Thanx Toolin! Interesting!! I like using the larger batteries that operate my digital. Not as much chance of them getting away!
Button cells were a major PITA!![]()
__________________
#14 | |
MTF Member # 8803
Quote:
Yep batteries do not last long in the cold when they are in use. Sitting in the camera does not kill them it is the extra work they do in an increased resisitance environment that kills them . the only thing to do is carry lots. Opening and closing your camera to install warm batteries in a outdoor emvironment aint gonna last for long and how long did you teacher figure a 3 gram piece of metal can hold it's heat while in a 3 pound hunk of cold metal and plastic. The most important thing you can do to insure optic performance in exreme temps is to learn how to look through the scope/view finder and breath with out fogging the equipment. yeah sure you can but I bet if you don't practice you wont get the perfect muskox in front of northern lights pic. Best thing to do is stay in warm climates, cold sucks. |
#15 |
3K Poster!!!!
![]() Join Date: Jul 2005
MTF Member # 495
Toolin is talking about LCD screens not freezing from being left in too cold an environment, hence putting them in an inside pocket... not about cold hands.
__________________
www.squidoo.com/bathouse Craig -CJA CUSTOM WOODWORKING 1989 Wheel Horse 416-8 16hp Onan |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
