Snow Blower Chute deflector actuator - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 12-21-2008, 09:28 PM   post #1 of 19
trrjohn
MTF Junior Poster
MTF Member # 5918
Default Snow Blower Chute deflector actuator
I finally got tired of getting off and on the tractor to change the chute deflector. I have hydraulic turn on the chute. SO I designed and engineered using a 12 volt linear actuator for moving the deflector. It uses a DPDT toggle switch mounted in the weather enclosure.
I just got back from doing the neighbors driveway. He had a stroke about 10 days ago and may never recover. His wife has a bad heart and cannot shovel. They had about 36" from the snow plow and a 48" drift in front of the garage. It is really nice to not have to get out of the cab to fight the 8 below zero with 20-30 MPH winds. I am glad that I finished it in time for the cold weather.
J
ID:	57342   Click image for larger version
ID:	57343   Click image for larger version
trrjohn is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 12-21-2008, 10:41 PM   post #2 of 19
professor
2000 Posts and climbing!!!
professor's Avatar
MTF Member # 90
Images: 11
Default Re: Snow Blower Chute deflector actuator
Real nice job!
And you are a good neighbor!
__________________
Every day is a victory.
'64 Simplicity Broadmoor
'66 Simplicity Broadmoor 707
'68 Sears Xl 10
? Dynamark 11/42
'71 Wheel Horse Special
'71 Wheel Horse Gt14
'72 Cub 127
? Bolens 10H
professor is offline   Reply With Quote Quick reply to this message
Old 12-21-2008, 10:54 PM   post #3 of 19
Magnum RT
Magnum RT's Avatar
MTF Member # 4746
Images: 10
Very nice job! I find the rotation to be a bigger issue for me, so I puchased a 44 rpm wiper motor fron Surplus Supply for about $15.00 and modified mine to get ride of the crank. This is my second year with it and am very happy!
Name:	Chute drive.jpg
ID:	57363   Click image for larger version
Name:	Chute mtr mount.jpg
__________________
Rol
Extreme S.W. Michigan
Ingersoll Fan
Green Bay Packers Fan
A lazy mind finds easier solutions!
Magnum RT is offline   Reply With Quote Quick reply to this message
Old 12-21-2008, 10:58 PM   post #4 of 19
trrjohn
MTF Junior Poster
MTF Member # 5918
I have a hydraulic spout rotator and needed a way to raise or lower the chute without having to get off and on the tractor.
J
Old 12-21-2008, 10:59 PM   post #5 of 19
LPBOLENS
Nine Year Site Sponsor
MTF Member # 857
Very clever, and a neat installation. And ditto on being a good neighbor: everyone hopes to have a neighbor like you when they are in need themselves.
Doug
LPBOLENS is offline   Reply With Quote Quick reply to this message
Old 12-22-2008, 01:53 AM   post #6 of 19
Jim Hayes
Senior MTF Member
MTF Member # 19089
Very ingenious both of you never would have thought of that. using a wiper motor, Tell me do you have to let it cycle to change direction ?
Also it is a great jesture to help those in need sounds like you growed up where I came from. Too bad all the world aren't like that.
Jim Hayes is offline   Reply With Quote Quick reply to this message
Old 12-22-2008, 09:48 AM   post #7 of 19
Magnum RT
Magnum RT's Avatar
MTF Member # 4746
Images: 10
The rotator is run by a $5.00 Radio Shack, 2 way switch, spring loaded to center off. Push to direction of desired rotation, release when satisfied.
Actually, abput 80 to 100 RPM would be better. A couple of fellow have 160 RPM, and they seem to draw too much amperage under load. A lot of trouble with blown fuses. 44 is probably a slow hand speed, but easier!
Hey, where I come from ( and hopefully, where I am going,) helping one another is what is meant to be!
__________________
Rol
Ingersoll Fan
Old 12-22-2008, 11:15 PM   post #8 of 19
SnowMower
Senior MTF Member
SnowMower's Avatar
MTF Member # 1058
Images: 1
John/ Magnum, both to very nice and clean installs. I'm very impressed.
In terms of using a wiper motor vs a power window motor, I guess you need to ground the case of a wiper motor where you do not need to with the window motor.
Here is my post from many moons ago.
http://www.mytractorforum.com/showthread.php?t=34131
Bill
__________________
Gravity. It's not just a good idea ... it's the LAW!
SnowMower is offline   Reply With Quote Quick reply to this message
Old 12-22-2008, 11:38 PM   post #9 of 19
old_nodaker
Senior MTF Member
MTF Member # 257
And of course there's the option of using an old 12 volt drill motor.
old_nodaker is offline   Reply With Quote Quick reply to this message
Old 12-22-2008, 11:55 PM   post #10 of 19
06toro
First, do no harm.
MTF Member # 4595
Images: 3
I like it!
__________________
Every action deserves an equal and opposite reaction.
06toro is offline   Reply With Quote Quick reply to this message
Old 01-06-2009, 08:03 PM   post #11 of 19
AaronandErinandHeath
Senior MTF Member
AaronandErinandHeath's Avatar
MTF Member # 20706
Images: 5
Slap a little paint on that and it will look like it came with it....
Get er Done
AaronandErinandHeath is offline   Reply With Quote Quick reply to this message
Old 01-06-2009, 11:11 PM   post #12 of 19
Magnum RT
Magnum RT's Avatar
MTF Member # 4746
Images: 10
Bill
I tried both power window and power seat motors, neither would turn my chute!
__________________
Rol
Ingersoll Fan
Old 01-14-2009, 09:54 PM   post #13 of 19
stewart1940
MTF Junior Poster
stewart1940's Avatar
MTF Member # 14499
Images: 3
trrjohn,
Thanks for sharing the info on where to buy the linear actuator. I went ahead and bought one for myself. It works great!! THANK YOU!!!
stewart1940
stewart1940 is offline   Reply With Quote Quick reply to this message
Old 01-21-2009, 05:38 PM   post #14 of 19
wesk
smokey hollow
MTF Member # 17780
Would like to do chute deflector and chute rotation. mechanically challenged
so detailed instructions would br great.Thanks!
wesk is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 01-21-2009, 07:04 PM   post #15 of 19
Magnum RT
Magnum RT's Avatar
MTF Member # 4746
Images: 10
I am still pondering the power deflector. Maybe for next year!
__________________
Rol
Ingersoll Fan
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
