X540 with 48" Blade for snow - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 12-07-2008, 07:42 PM   post #1 of 28
JohnG
MTF Member
MTF Member # 20023
Question X540 with 48" Blade for snow
Got the green light for a X540 but can't afford the blower now, what a great wife hay. Anyway, how much weight do I need for the back of the tractor for pushing snow with HDAP tires and do I need chains as well. I live in S.E. Wisconsin so snow does seem to come often.
Thanks for any advice you might have.
John
JohnG is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 12-07-2008, 08:40 PM   post #2 of 28
Rodney in VA
Retired and Busy!
Rodney in VA's Avatar
MTF Member # 6015
Images: 6
Default Re: X540 with 48" Blade for snow
That is great news on the approval "green light." It is always better if mama is in agreement. That way she want lock the door on you when you are out pushing snow! Welcome to MTF and I would look into some chains because of all the snow you get. Is your drive on a slope? You do have traction control on the X540, so if you have flat terrain you may get by with out the chains if the snow is not too deep. Personally... I would rather have the chains and not have to worry about it.
__________________
Rodney
John Deere 2305 TLB
John Deere X540 GT
"Retired and Busy"
Rodney in VA is offline   Reply With Quote Quick reply to this message
Old 12-07-2008, 09:04 PM   post #3 of 28
Nathan Werneburg
Professor of makin stuff
Nathan Werneburg's Avatar
MTF Member # 20392
i agree if not chains then at leas an agressive tire turfs are not good on snow
Nathan Werneburg is offline   Reply With Quote Quick reply to this message
Old 12-07-2008, 09:17 PM   post #4 of 28
Dude Man
Senior MTF Member
Dude Man's Avatar
MTF Member # 15523
Congrats on the new ride.
I'm from SE Wisconsin too.
I do not have chains. But I do have a blower and a 749, so its 4 wheel drive all the time. I have blown snow 4 times now and have not got stuck once. That includes going down a hill to my burning barrel on grass about 100' away from the back of the house. Also going through a lot of drifts, my property is really windy.
However those HDAP tires are really sweet and get really good traction. I have not had to lock up the rear end yet either, even with all of that wet heavy stuff we had Monday morning of last week.
I also run 6 suitcase weights and have the cab too so that is some more weight also.
My advice is try with out chains and if you need them go buy them. Or buy them right away and not put them on and see what happens. If you need them you can put them on, but if not see if your dealer will take them back.
IMO, I would really see what you can do to get a blower. You will not be disappointed.
good luck
__________________
The Impossible Just Takes A Little Longer
Dude Man is offline   Reply With Quote Quick reply to this message
Old 12-07-2008, 10:25 PM   post #5 of 28
BlackSnowSlide
MTF Junior Poster
MTF Member # 20183
My brand new 540 is coming tomorrow with a 54" deck and a snow blower attached to the front. I have a very long and steep driveway over 300' long. I have the chains coming because when your stuck is a lousy time to run to the Deere store for chains.
BlackSnowSlide is offline   Reply With Quote Quick reply to this message
Old 12-07-2008, 10:48 PM   post #6 of 28
JohnG
MTF Member
MTF Member # 20023
Man-- just looked at the Kubota GR2110 WOW is that tempting.
Old 12-07-2008, 10:54 PM   post #7 of 28
HydroHarold
10,000 +posts!
MTF Member # 82
Images: 1
I echo the above, stuck is stuck and very unhandy! My GX is probably around the same weight and chains are essential for any snow over 4" on my rounds. Some jobs require all the snow to be pushed to one side and heavy stuff piles pretty quick. Backing up, especially with a blower/plow raised will reduce your traction LOTS. There's always some snow left after a plow and it gets slippery quick running over it on pavement. Unless your jobs are dead flat go chains absolutely AND weight.
Lock in the rear axle for more control when blade's angled BEFORE wheel slippage starts. Don't hit the pedal when the wheels are spinning, bad for transmission... I envy that "new tractor smell"!
HydroHarold is offline   Reply With Quote Quick reply to this message
Old 12-08-2008, 08:09 AM   post #8 of 28
ccsial
Senior MTF Member
ccsial's Avatar
Location: Northern IL 30 mi NW of Rockford, IL in farm country
MTF Member # 7152
Quote:
One think to check on if it is important to you.
The X540 has hydraukic raise and lower for the blade. At least my 355 did and I think that is the X500 series now.
When I looked at the GR's a few years back they were manual raise and lower.
__________________
JD X748SE - Kubota L3400HST - Ford 1910 FEL
ccsial is offline   Reply With Quote Quick reply to this message
Old 12-08-2008, 10:21 AM   post #9 of 28
JDGX335Bill
Senior MTF Member
JDGX335Bill's Avatar
MTF Member # 1164
Harold I throw and don't push but I'll only spin if I can't remove the snow close to the pavement-which is almost never an issue so far. The only other time I had a minor traction issue is if it's slushy and cakes the treads of my turf tires. Do you find it necessary to run chains with your thrower? I really don't like chains after I saw what they do to paved surfaces.
__________________
2003 JD GX335 with 54C mower & 42" snowthrower, Brinley Aerator, Earthway 2050TP Broadcast Spreader, Stihl FS80R Trimmer, Stihl BG-85 Blower, Stihl MS-170 Chain Saw, Lawn Boy 10323 6.5 HP "Dura Surger"
JDGX335Bill is offline   Reply With Quote Quick reply to this message
Old 12-08-2008, 05:03 PM   post #10 of 28
saskman49
Nicky&Sterling RIP 03-08
saskman49's Avatar
MTF Member # 4038
The X500/X520 are foot operated mechanical lift with manual steering and the X540 is Hyd lift and power steering as well. The GR2110 has all that and 4wd as well. It is quite the nice machine but I wonder when looking at the specs just how close in $$$ you are getting to an X7xx machine.
__________________
John
JD2320 with 62D, 200 CX with 53" bucket
Speeco QH & Hydraulic top link
JD 647 tiller
JD 413 Rotary Cutter
Frontier SP1060 Soil Pulverizer
Frontier BB2060 Box Blade
Land Pride 1572 Rear Blade
Allied 50" blower
Frontier pallet forks
55 Gal 3pt sprayer
Frontier middle buster
3 section diamond drag harrows.
JD X485 with 62C deck
JD Gator TH 6x4
JD 216H 46 mower and 33 tiller
JD JS35 Mower
Stihl BG86, 017, MS250, FS90R, KM130R
Gone LT2000, JD GT235, X500, LT180, 108 and 265 also White GT1822
saskman49 is offline   Reply With Quote Quick reply to this message
Old 12-08-2008, 06:58 PM   post #11 of 28
HydroHarold
10,000 +posts!
MTF Member # 82
Images: 1
[QUOTE=JDGX335Bill;548471]Harold I throw and don't push but I'll only spin if I can't remove the snow close to the pavement-which is almost never an issue so far. The only other time I had a minor traction issue is if it's slushy and cakes the treads of my turf tires. Do you find it necessary to run chains with your thrower? I really don't like chains after I saw what they do to paved surfaces.[/QUOTE]
Here's a couple of shots of my driveway showing the hill. Since I had the driveway "painted" I can't get enough traction going up to plow/blow snow no matter what the conditions. If I stop on the grade going up and try to start again Johnny sits there and spins (Need another case or 2 of Oreos!)
Also across the street I do 2 neigbors who have downhill sections just off the road. I have to clear one about 1 car length deep and back up and so on until they can get the cars out for me to finish. No way I can get traction to back out of there with the attachments raised and no room in front of the first car to turn around. I've told all my "customers" the situation and they made the plow/no plow/scratches decisions themselves. I plow, they sit inside warm and dis-shoveled.
ID:	56581   Click image for larger version
Old 12-08-2008, 09:06 PM   post #12 of 28
JohnG
MTF Member
MTF Member # 20023
Default Price quote
How does this price look to you guys. This is from a local dealer.
X540 54 Deck HDAP Tires $6800
48 Blade $739.00
Angle Kit $230.00
4 Weights $180.00
Set-Up & Del $100
Halogen Headlight Kit $ 51
Total $8100
Tax $413.31
Total $8513.10
Old 12-08-2008, 09:34 PM   post #13 of 28
JohnG
MTF Member
MTF Member # 20023
Question LT 166-what is it worth
Have a "MINT" LT166 16hp Briggs twin with a 42" Freedom Deck What is worth.
Old 12-08-2008, 11:30 PM   post #14 of 28
Dude Man
Senior MTF Member
Dude Man's Avatar
MTF Member # 15523
What is the price difference if you get a blower instead of the plow and the angling kit??
Just wondering...
__________________
Sponsored Links
Advertisement
Old 12-08-2008, 11:42 PM   post #15 of 28
JohnG
MTF Member
MTF Member # 20023
$9280 with a 47" blower
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
