51' Farmall H - How to Replace Generator belt? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 12-07-2008, 03:41 PM   post #1 of 4
Ionfuel
MTF Junior Poster
MTF Member # 20388
Default 51' Farmall H - How to Replace Generator belt?
Hello,
I have a 51' H. The generator belt broke. It goes on the innermost pulley on the "pulley assembly" in front of the water pump housing. My question; how do I get the new belt on?
So far, I have removed the radiator and fan blade. I'm not sure what to remove next or how to do it. It looks as if the pulley assembly can come off of the shaft some how, but I'm not sure how to do it.
Also, I want to replace the fan/crankshaft belt. Once I understand how to remove the pulley assembly the crankshaft belt can come off. However the manual crank start shaft is rusted to the frame. There is just enough clearance for the crankshaft pulley to turn, but not enought clearance to get the belt off (or the new one on).
If anyone has any insight on how to to this, let me know. Thanks!
Kevin
Ionfuel is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 12-07-2008, 10:02 PM   post #2 of 4
Kbeitz
Collector of many tractors
Kbeitz's Avatar
MTF Member # 86
Images: 4
Default Re: 51' Farmall H - How to Replace Generator belt?
The best way is to buy some link-belt... Then you wont need to take things apart... Look for the ones with rivets not the twist type...
I did a fast search and found this...
http://www.rockler.com/product.cfm?p...0&cookietest=1
http://www.woodcraft.com/product.asp...FamilyID=20051
__________________
Kbeitz is online now   Reply With Quote Quick reply to this message
Old 12-08-2008, 09:51 PM   post #3 of 4
Ionfuel
MTF Junior Poster
MTF Member # 20388
Too late for that; already took apart. Those look like they're made in China!
I got the new generator belt on (local Case IH dealer had one-USA made) then partially got the new crankshaft belt started, kicked her over about 1/2 RPM, and it jumped right on.
I found a replacement set of hoses from a site in MA (www.tractorpart.com). They needed replaced anyway. I'm glad I took it part. Learned a few things.
Thanks
Sponsored Links
Advertisement
Old 12-27-2008, 12:36 AM   post #4 of 4
caseman-d
Senior MTF Member
MTF Member # 226
Ok ypu took more off than need be. You have to take the fan belt off, to do this you need to loosed the belt by loosing the set screw and gentley taping the housing of the fan housing. You turn it one way to tighten, another to loosen it. To get a break down of how tthis works go to casih.com for a parts breakdown. It's not as hard as it seems.
caseman-d
caseman-d is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
