#1 |
The Magnificent
For leveling out and filling in small holes (moles, dogs digging for moles, etc), I'm thinking of essentially a weighted box frame with chain link on the underside. Shoveling a little dirt into the frame and drag it around the yard.
Has anyone built a similar attachment? Any ideas for a better way? Thanks, |
| Sponsored Links | |||
Advertisement | |||
#2 |
standard issue neuralyzer
I was thinking of some such thing with chain link fencing but sans the weighted box. I was just going to tie a series of heavy pipes across the width every foot and let it flex along its length. That way you can roll it up for storage.
__________________
I don't suffer from insanity. I enjoy every minute of it! |
#3 |
I also thought of using 4x4 timbers across the width instead of pipe. I could just fix them to the fencing with extra long fence staples. Considering drilling holes in the timbers that I could drop large spikes into to convert to a spike harrow.
__________________
#4 |
Senior MTF Member
MTF Member # 1431
Here is a drag that made and use several years ago.
![]() ![]() Drag in action: ![]()
__________________
Just trying to help |
#6 |
Senior MTF Member
MTF Member # 20302
very nice. I just might have to make me one!!
__________________
It was broke, then I welded it, But its still broke!!!! 1975 WH C-120 special 46" deck 48" craftsman blade, homemade bracket to fit. clevis style hitch no attachments yet 1972 WH 800 Comando 1974 WH B-80 4 speed WH 520-H 48" deck |
#7 |
IDK a thing but i try
MTF Member # 11239
Here is mine. Its an old headache rack off my truck. Works pretty good. The bumper is actually full of lead.
#8 |
Proud Member of the 1K Club
MTF Member # 1189
I built a mounted drag harrow. Used square tubing for the frame work and mount, the harrow will pivot up&down separate from the lift mount so that it will follow the ground. The mount lifts it and pulls it along, pivots at the frt of the frame and a chain from the top link mount to the back of the harrow. Pieces of 3/8" rod welded onto the frt of the frame hooks the chain link fence and at the back I brought the fence around&over the frame, used two pieces of flat strap bolted together to sandwich the fenceing. One piece of flat strap has two eyebolts welded to it, a chain runs from one eyebolt to the other, then I welded a piece of 5/8" threaded rod to the center of that chain, the threaded rod goes to a bracket so I can adjust the tension on the fenceing. It works great for finish work on a new yard before seeding. I made mine 4'x6', got to be careful when I turn a corner. If I had it to do all over again I'd probably make it 4'x4' instead.
#9 |
Handyman
MTF Member # 6544
Here is some info for you about the split rail drag I cobbled together.
http://www.mytractorforum.com/showth...ght=split+rail I used the wooden drag and then chain link. Now I have a grader balde that mid-mounts under my Simplicity tractor. |
#10 |
MTF Member
MTF Member # 81260
i used a 3' piece of 1" pipe for the front left to right, cut 2 truck tire chains in half to have 4 equal lenghts , welded the chains to the pipe in a row at the front and at the back to a piece of 2x2 angle iron so the flats were on top and at back (like an upsidedown l) then put abou 50 1/4" x 2" bolts randomly dispersed thru the chain links to act like a spike harrow...works awesome and doesnt need any xtra weight....plus you can roll it up or hang it on the side of your shed when your done...oh an I welded a each end of a 5' chain to the outside edges of the pipe to hitch to my tractor
| Sponsored Links | |
Advertisement |
#11 | |
Badge Crew Member
Quote:
Looks like your young'in has some "Green Fever"! That drag looks like it works pretty well.
__________________
![]() Current Machine JD 322 Former Machines: JD 318, JD 216, JD 212, 1965 JD 110 My videos: www.youtube.com/user/tkelley16341 |
| Sponsored Links | |
Advertisement | |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
