| Home | MTF Gallery | Add To Favorites! | Set MTF As Your Homepage | FAQ | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Snow Removal and Winter Tasks Winter snow throwing plowing and removal forum |
Thread Tools | Display Modes |
#1 |
Senior MTF Member
MTF Member # 9590
As I contemplate the possible need to get the snowblower out tomorrow, I have developed some snow blowing "rules of thumb" over the years that some of you newbies to snow blowing may want to consider. I figure that I have moved about 5,400 inches of snow with my three snow blowing rigs over the last 26 years. Feel free to add to my list, I am always looking for new techniques:
RULE 1. Don't put your hand in the moving augers. This is an obvious one. I have occassionaly stuck a broom handle down the chute in the spring with the blower running, but that is about as dumb as I get. I have develped a fondness for my appendages over the years. RULE 2. Make sure all of the crap that can break your blower and shear pins are out of the way, before the first snow.. When I have broken shear pins, it was always at the beginning of the season when a stray piece of firewood got in the way. Last week I went out with the rake and cleaned up any potential impediments. RULE 3. When you are going to have a major storm, if you can clean it in increments. Why stress the equipment and yourself? Anyway snowblowing with my rig is fun. If the snow I just blew drifts back into the driveway, I just do it again - twice as much fun with the same snow. RULE 4. Always clean all of the snow off of your equipment when you are done. I learned this the hard way the second time that I snow blowed. The snow blower was making a **** of a racket when I started it, and then I noticed black smoke coming from the drive belts in the back. So I shut it down and called the dealer. "Didn't you clean out the augers and impeller after you finished? When the snow melts it freezes on the bottom of the impeller assembly such that the impeller won't turn." Duh, nobody told me to do that. Now I clean off everything, but especially anything which if frozen could make it difficult to start the machine. With my new rig, I wipe all of the water off of the cab that I can get to, clean off the wiper blades and pull them away from the wind shield. Of course, it helps if you have a garage. I also put a piece of wood below the blower so it doesn't freeze to the floor. RULE 5. Make sure nothing critical is frozen when you start blowing. This is a continuation of what I said in 4. If you have a rig like mine (which shuts off the tractor if no one is in the seat when a PTO device is engaged) put a mirror where you can see that the impeller and augers are spinning freely and the chute rotation is working freely before you have at it. RULE 6. Never put the blower on the ground on a gravel driveway the first time you use it, unless you enjoy changing sheer bolts. This rule is just for those of us who don't have a paved driveway. I have a gravel driveway, so a good first snowblowing is a key to no problem for the rest of the winter. Like everyone else we get a few snow falls early where you know it is going to melt, so this next step is the one I take when we get our first real snowfall. First I run my SUV up-and-down the driveway until the snow is packed down into the gravel before I snow blow for the first time. Then I run the blower but keep it off the ground about an inch. This way the ground will freeze better for future efforts. The next time I run the blower on the ground with the skid plates as low as they go. We don't get much thawing once the snow starts in earnest. RULE 7. When the snow is deep, take smaller cuts of snow. My first run in the snow is very very slow, usually painfully slow. My next cut might be a half of the width of the blower or less. I would rather make more runs and use a little more fuel, then be replacing belts as I did with my old snowblower. The guy who wrote the Kubota snowblower manual obviously has never used a snow blower before. It says in deep snow take the top layer off and work your way down. To me this is nonsensical. You're going to be driving a tractor in the deep snow and making a general mess. How about just taking a narrower cut of the snowblower potential? Anyway I have been doing this and it has saved many a belt on my old snowblower. ![]() |
#2 |
Git'n da farwood
MTF Member # 15283
Good advice. Don't forget the extension cords hiding under the snow. I have a more "short" cords now with new ends.
__________________
I don't suffer from insanity. I enjoy every minute of it! |
#3 |
Custom User
![]() ![]() Join Date: Mar 2005
MTF Member # 82
As a reformed breaker of "RULE #1" I can tell you from experience that if you haven't got your hand mangled yet... you will unless you PAY ATTENTION! (Not just snowblowers either!)
One major family illness problem + a sticky and deep snow X a 4hp tiny Airens with no safety guards = one "Sadder But Wiser HydroHarold"! Yup, I did it back in '88... I had unlined gloves on which saved all of 2 fingers but I lost 2/3rds of the tip joint on right middle finger and 1/3 of the tip of the ring finger right next to it. In addition some tendons were "loosened" all the way into my wrist... totalling 8 mos. physical therapy and 2 years before I could start RE-learning to fingerpick my Taylor "Leo Kottke Signature Model" 12 string again! "See Hydro! AND you're the guy yelling against all the safety stickers and interlocking safety clutches/switches/levers/buttons...!" That's right, but sooner or later, one way or the other ALL of us will make a damn stupid mistake and all the safety stuff won't help when you cut yourself on a dog food can lid or break your finger in the washing machine lid... THAT'S why they call 'em ACCIDENTS. In my case it just happened to be a sweet running little snow blower, I could have been doing anything... "JUST PAY A-$^%#in'-TTENTION!!!!"
__________________
"Well, I won't do THAT again any time soon!" (Or so I thought!) John Deere '04 GX335, 48C Deck, PowrFlo w/ 1 single twin double (dual) bagger @ 7 bu. (that's 'bushels' folks, seven bushels, WOW!), JD 42" snowthrower, JD 48" front blade, JD front dethatcher, JD 10cu.ft. cart/system platform, Brinley plug aerator, Earthway tow spreader, 1996 Snapper RP21600 (re-engined to 6.75hp Quantum Briggs), Stihl 026Pro w/20".325", Ryobi 725r w/trimmer and tiller, 1 White-Henway, Stihl BG-85 blower w/gutter kit and giant silent dog whistle |
#4 |
Administrator
MTF Member # 1
good set of rules...
with my dog, i always find hidden 'toys' that violate rule # 2. ![]() ive still got parts of a rope toy wrapped around the ends of my blades from 2 years back... |
#5 |
Proud Member of the 1K Club
MTF Member # 7934
Good rules. I managed to survive our 15 inch snowstorm last year with just a 3 hp 16 toro powerlite. Granted, I only have a triple wide residential driveway. Had to do that one three times. D'oh...
#6 |
MTF Member # 52
Beware of wet or frozen newspapers aslo.
#7 |
MTF Member # 9436
Good rules. As far as number two goes, it isn't pretty what my old Toro 624 can do the my daughter's baton when it accidentally falls out of the car!
As for number 7, don't completely dismiss the technique of taking the top layer off and making a second pass. The Berco manual recommends this method. Not surprising since your great looking Kubota thrower looks suspiciously like a Berco. I have used this method with my old Toro single stage blower on my 212-5. The snow was about 14" deep and I was bogging down with the blower all the way down. I lifted the blower up and the going was much better.
__________________
ggsteve 08 Craftsman Professional 24hp B&S ELS, 42" deck, 3 bin bagger, Berco Northeast 44" blower & 48" blade, MTD soft cab 71 John Deere 140H3 w/integral hitch, 54" 4-way blade, 48" deck, cozy cab 78 John Deere 316, #49 blower Toro Wheelhorse 212-5, 38" deck, 2 bin bagger, 36" blower Other: Craftsman 12 cu. ft. poly cart, JD 36" front dethatcher, Precision Products 42" plug aerator, 40" drop spreader, Brinly 38" box blade, Sears Roebuck single bottom plow, Agrifab 38" Sweeper
#8 |
MTF Member # 90
Regarding rule number one- tie / keep a broom handle or minature shovel on your machine to use for cleaning out the shute AFTER shutting off the rotor. That way there is no temptation to use your hand.
__________________
Every day is a victory. |
#9 | |
Custom User
MTF Member # 82
Quote:
) toilet brush. A nice round one with stiff bristles hangs from my chute rotation handle bracket by a chrome pelican clip. Of course these days I have 17 different electrical circuits also looking out for my well being and the ever present "SAFETY DECALS" which I recite like a blizzard mantra...![]()
__________________
#10 |
3K Poster!!!!
![]() Join Date: Jul 2005
MTF Member # 495
I like the toilet brush idea, that is really smart. Especially the ones that have that little bend in them. I am not new to snowblowing, but am new to snowblowing in a tractor. This single stage screams, it really moves. My big concern will be anyone nearby, making sure that no kids run in front of me while operating it. Can't wait to try it out... just waiting for a good storm.
__________________
www.squidoo.com/bathouse Craig -CJA CUSTOM WOODWORKING 1989 Wheel Horse 416-8 16hp Onan |
#11 |
MTF Member # 5603
Great tips. I made sure my kids plastic tools were out of the lower driveway by the barn. They don't sweat the small stuff, all they know is that watching Dad from the kitchen window snowblowing is, cool! Mrwiggles, you need to come south one county, we got plenty of the white stuff in the last two days to give that new cab a proper try out.
__________________
JD 2320 with FEL, 62On Ramp MMM, 47"Quick Hitch Front Mounted Snowblower, 48" King Kutter Tiller, Markham Toothbar, 48" FarmForce Brush Hog Craftsman Equip: Mini Tiller/Cultivator, Weedeater, Chainsaw Others: Cub Cadet 5hp Rear Tine Tiller, Toro 4hp Walk Behind Mower, AgriFab 36"Poly Roller, Tow Behind Poly 10cu.ft. Yard Cart John Deere 185 w/46" Deck and PowerFlow Bagger |
#12 |
Senior MTF Member
MTF Member # 3908
Lets not forget our faithful "helpers",,,, keep Rover in the house! I run a Gravely with the infamous "dog eater",,the dachsuns wouldn't stand a chance,, oh and reminder to self,,, stay away from the vehicles! Last year I caught a bumper with the reel,, it tried to eat that little Festiva!!
#13 | |
7K+ Poster!
MTF Member # 41
Quote:
Thanks for the informative post, however, you must be a masochist -- 5,400" of snow and you still live where you live? I'd be on the phone with my realtor and travel agent! ![]()
__________________
Cheers JDFANATIC JD2210, loaded tires, 62C MMM, 210 Loader, 46" Snowthrower, York Rake, PTO Spreader, Heated Cab, JD Plug Aerator, FIMCO Sprayer, Wheel Spacers, FEMCO Folding ROPS, JD Cart |
#14 |
Senior MTF Member
MTF Member # 42
These are all good tips on safely operating your snow blower.
The whole process of operating a snow blower is dangerous and in my experience the end of the driveway (EOD) is where you really have to be on your toes. There can be a lot of rocks and ice chunks packed in that snow. You really need to keep your eyes opened looking for vehicles passing by. I always disengage the blower when a vehicle passes by and the discharge just happens to be directed towards the road. I also never direct the discharge towards the house or garage. Every year there are accidents where someone gets clipped by a passing car while clearing their EOD. I just got back from spending 2 months in sunny Guam recovering parts of a B-52 that made a very rapid water landing and I am not really ready for this snow. At least I had time to pick up all of the door mats but I wish I had the time to trim back some of the shrubs! |
#15 |
MTF Member # 18268
Good thoughts ll around. My driveway is 100' X 18' with a turn around that's 20' X 20'. It's begining to chip and crack. It has many, many coats of sealer on it. The driveway hasn't been kept up in a few years. The driveway is asphalt (about 2" deep) on top of concrete (4" deep) With all the little pieces of asphalt working themselves loose, I really don't thing a blower is the best thing for us. Still looking for a plow setup for my ST160. Till then, it's shovel and push brrom work. The plow blade new from Sonny's is almost $400.00 and a 200 mile round trip. Still too deep for my pockets.
__________________
A Day Inport Is Like A Day Without Sunshine! USS TULLIBEE (SSN-597), USS FULTON (AS-11), USS PAIUTE (ATF-159), USS BAINBRIDGE (CGN-25), USS ASHLAND (LSD-48), USS GRAPPLE (ARS-53) Naval Station Guam, US Forces Carribean Key West FL, EOD Group Two VA, Allied Command Atlantic (NATO), VA. |
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| Thread Tools | |
| Display Modes | |
