Members List MTF Gallery Add To Favorites! MyLawnMowerForum.com - Lawnmower Forum FAQ
Register Home MTF Gallery Search Today's Posts Mark Forums Read
Reply
Thread Tools Display Modes
Old 11-17-2008, 09:37 AM   #1
thud
MTF Junior Poster
MTF Member # 9111
Default Will tire chains for turf tires fit ag tires?
I just got a 442 and I will be needing more traction. If I buy a set of 2 link chains will they fit if I change the tires out for ags later? Thanks
thud is offline   Reply With Quote
Sponsored Links
Advertisement
Old 11-17-2008, 10:12 AM   #2
oldtimer
2000 Posts and climbing!!!
oldtimer's Avatar
MTF Member # 4355
Images: 1
Default Re: Will tire chains for turf tires fit ag tires?
HI thud,and welcome. I'm not 100% postitive, but i think Ags have a much larger diameter. I'm sure some else will be able to let you know for sure.
oldtimer is online now   Reply With Quote
Old 11-17-2008, 10:21 AM   #3
zionview
Senior MTF Member
zionview's Avatar
MTF Member # 12953
Images: 4
You may have to lengthen them. I've changed chains around many times, including widening them. It beats buying more and having extras laying around. If the set you buy is a little long, leave 'em overlap. The ride will be a little more bumpy, but you put more cleats on the snow in the meantime. Let it snow.
zionview is offline   Reply With Quote
Old 11-17-2008, 10:40 AM   #4
Caseguytoo
3K Poster!!!!
MTF Member # 7029
Are you going to be in mud? If so, then just get the Ag's and forget the chains.
Are you going to be on frozen ground? If so, then get the 2 link chains and forget the Ag's.
Either way, load the tires with RV plumbing anti-freeze and find some big cast iron wheel weights for 16" rims at one of the local agricultural dealerships in your area. Lots of machinery used the same style of 16" rims that are on your tractor and those rims often needed wheel weights too. In other words, don't think that you must find Case weights in order to be happy. Check with Ford, Massey, I/H, Deere and other dealers. If you have to take one back wheel with you, then so what? It's all about finding weights that work for the least amount of coin.
Caseguytoo is offline   Reply With Quote
Old 11-17-2008, 11:39 PM   #5
thud
MTF Junior Poster
MTF Member # 9111
thanks for the info, Ag tires it is then.
Old 11-27-2008, 07:25 PM   #6
atractorkid7
Senior MTF Member
atractorkid7's Avatar
MTF Member # 17755
Images: 8
it depends if the ag tires are taller or wider, and if they are its easy to lenthen the chains.
atractorkid7 is offline   Reply With Quote
Old 11-28-2008, 06:16 AM   #7
Ingersoll444
ex spelling bee champ
Ingersoll444's Avatar
MTF Member # 16
Images: 13
Send a message via AIM to Ingersoll444 Send a message via MSN to Ingersoll444
I was wondering the same thing when I went to the AG tires. You know what... I have not needed them, so I never tryed.
__________________
Paul B
Ingersoll444 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
