removing air in hydraulic system - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 08-24-2008, 06:04 AM   post #1 of 5
rik1202
MTF Junior Poster
MTF Member # 16503
Yikes removing air in hydraulic system
I think I have air trapped somewhere in my hydraulic system,can any tell me how to go about getting the air out?It is aMF 1030,the filter is inverted,could that be where the problem is?.....................Rick
rik1202 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-24-2008, 09:58 AM   post #2 of 5
Dude11
2000 Posts and climbing!!!
Dude11's Avatar
MTF Member # 8852
Images: 4
Default Re: removing air in hydraulic system
What makes you think you have trapped air?Is 3pt.jerky,or does it slip?Reason I ask is,the system should bleed itself if the vents are clear and everything is like it should be.
__________________
Dude11
Dude11 is offline   Reply With Quote Quick reply to this message
Old 08-24-2008, 05:26 PM   post #3 of 5
rik1202
MTF Junior Poster
MTF Member # 16503
Quote:
HYDRAULICS ARE SLOW UNLESS I TAKE PRESSURE OFF THE SYSTEM BY LOWERING THE GANNON A BIT. I THINK THE PUMP IS STRONG BECAUSE IT STILL CAN PICK UP THE SAME WEIGHT AS ALWAYS. I WAS TOLD THAT SLOW HYDRAULICS ARE A SYMTOM OF AIR IN THE LINES.
RICK
Old 08-24-2008, 05:27 PM   post #4 of 5
rik1202
MTF Junior Poster
MTF Member # 16503
Quote:
RICK
3 POINT IS NOT JERKY AND THERE IS NO SLIPPING TO ANSWER YOUR Q'S.
RICK
Sponsored Links
Advertisement
Old 08-25-2008, 12:11 PM   post #5 of 5
Dude11
Dude11's Avatar
MTF Member # 8852
Images: 4
Is it slow to respond on the lifting or on the releasing?I'm thinking that if air is in the system,it would state something in a service manual about how to bleed it off?I would call a MF dealer service dept.in your area and ask them about it.I would also look for a petcock of some kind close the pump.I can barely remember a vent thing on the top of the reservoir of a MF20 I had,must have been a one way type air thing or it would have shot fluid everywhere.That's why I said it would bleed itself off.Think about it,everytime you add or ck fulid level you are opening the system,so to speak.So therefore it has air that has to be bleed off?Maybe a bad air/check valve in the reservoir tank?These are just shots in the air,that's why I'd ck with a service dept.with MF.
__________________
Dude11
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
