2010 Clutch Pressure Plate tool - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 07-18-2008, 03:22 AM   post #1 of 6
Kevin B
MTF Member
Kevin B's Avatar
MTF Member # 9281
Default 2010 Clutch Pressure Plate tool
Does anyone have the dimensions for the pressure plate spring height gage tool. I put a rebuilt pressure plate and clutch in my 2010 and the clutch is not disengaging completely. When I start in gear (safety switch bypassed) and the clutch is depress, the tractor will start, but not move. And when I let the clutch out the tractor will move. However, I can not change gears with the tractor running. Not any gear or range. The only thing I can think of is the pressure plate wasn't adjusted correctly at the factory when it was overhauled.
Kevin B is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-18-2008, 10:30 PM   post #2 of 6
Kevin B
MTF Member
Kevin B's Avatar
MTF Member # 9281
Default Re: 2010 Clutch Pressure Plate tool
Quote:
OK. I found a great John Deere Dealer in Ritzville, WA that was willing to let me copy the JD277 Pressure Plate Tool. I made one according to my drawings. Now, is the gauge supposed to just touch the tip of the pressure plate finger that touches the bearing? Or is the gauge supposed to touch inside the valley of the finger between the tip and the spring cup?
Old 07-18-2008, 10:51 PM   post #3 of 6
jd110
Senior MTF Member
jd110's Avatar
MTF Member # 6718
It should only touch the tip that contacts the throwout bearing.
jd110 is offline   Reply With Quote Quick reply to this message
Old 07-19-2008, 02:39 AM   post #4 of 6
Kevin B
MTF Member
Kevin B's Avatar
MTF Member # 9281
Quote:
Great, thanks, I did it right. Ready to go back together in the morning.
Old 07-20-2008, 02:13 AM   post #5 of 6
Kevin B
MTF Member
Kevin B's Avatar
MTF Member # 9281
I got the tool made. By the measurements off the JD227 tool, the pressure plate fingers are exactly .250" above the outer rim surface of the pressure plate. Tractor goes back together in the AM
Sponsored Links
Advertisement
Old 07-20-2008, 02:54 AM   post #6 of 6
Team_Green
Banned!
MTF Member # 7124
Images: 2
Good to hear your back up and going (and changing gears when needed).
Team_Green is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
