LawnBoy Governor Adjustment? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Walk Behind Mowers We all use them from time to time... no seats on them.. but they get the job done!!!
Reply
Thread Tools Display Modes
Old 07-15-2008, 04:16 PM   #1
ZeroJunk
Senior MTF Member
MTF Member # 67364
Default LawnBoy Governor Adjustment?
I got my 10515 running today.Apparently the only problem was the governor spring which I replaced.
It's not exactly right. The sping seems to be about 1/4 inch or more too long. It extends through the linkage slot.
But, it may be that I don't have it set in the right place.
It works. RPM sounds about right WOT and it idles down fine. But, at about the last 1/8 inch from being all the way to idle the governor lets it go back to WOT.
Do I need to rotate the adjustment one way or the other, or what? Thanks
ZeroJunk is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-15-2008, 04:44 PM   #2
Indy452
4K Poster!!!
Indy452's Avatar
MTF Member # 7780
Images: 9
Default Re: LawnBoy Governor Adjustment?
Does your 10515 have a metal or plastic carb?
Indy452 is offline   Reply With Quote
Old 07-15-2008, 05:55 PM   #3
mhdi22
Senior MTF Member
mhdi22's Avatar
MTF Member # 14295
I'll be watching for the answer too.........metal and plastic carbs...........just can't seem to get it right (finding the high revs)
__________________
8480......6257......10650
mhdi22 is offline   Reply With Quote
Old 07-15-2008, 06:03 PM   #4
ZeroJunk
Senior MTF Member
MTF Member # 67364
It's plastic.
Old 07-15-2008, 06:47 PM   #5
Edward
My kid @ W.H. gift shop:
Edward's Avatar
MTF Member # 4340
Images: 9
http://mytractorforum.com/showthread...ighlight=10323
and theres a few more pics I know of that I took on other threads I started, and I know others have posted pics too. If you search, do a user search of threads started by me using 10323 as the keyword
Edward is offline   Reply With Quote
Old 07-15-2008, 07:43 PM   #6
ZeroJunk
Senior MTF Member
MTF Member # 67364
Edward, you mentioned the service manual suggested starting at 1/3 on the governor adjustment. Do you remember whether that is CW or CCW looking down the barrel?
Old 07-15-2008, 09:38 PM   #7
Edward
Edward's Avatar
MTF Member # 4340
Images: 9
Clockwise
Old 07-15-2008, 09:57 PM   #8
Walt 2002
Senior MTF Poster
MTF Member # 1229
"he spring seems to be about 1/4 inch or more too long. It extends through the linkage slot."
Don't think that is unusual.
Walt Conner
Walt 2002 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-16-2008, 12:56 PM   #9
ZeroJunk
Senior MTF Member
MTF Member # 67364
Mystery Solved
The cable was coming in at such an angle that it cocked up the throttle linkage enough that it was contacting the adjustment nut and pulling the butterfly open. Tied the cable at a couple of placed to secure it in correct postion, idles fine now. Thanks for the input.
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
