just bought a cen-tech multimeter - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Tool Time Tool questions and discussions
Reply
Thread Tools Display Modes
Old 06-16-2008, 02:36 PM   post #1 of 16
silver hair deere
Old as Sin
silver hair deere's Avatar
MTF Member # 4257
Images: 4
Yikes just bought a cen-tech multimeter
just sent away for a cen-tech 7 function digital multimeter from harbor freight , # 92020-1vga , couldn't afford a fukes , so anyone have one , any good or did i just waste my money ?also what type of battery do they use ?
silver hair deere
silver hair deere is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 06-16-2008, 02:57 PM   post #2 of 16
professor
2000 Posts and climbing!!!
professor's Avatar
MTF Member # 90
Images: 11
Default Re: just bought a cen-tech multimeter
I've been using their cheaper one for a couple of years - no problem.
professor is offline   Reply With Quote Quick reply to this message
Old 06-16-2008, 02:57 PM   post #3 of 16
Milwaukee
Dan
Milwaukee's Avatar
MTF Member # 2557
Images: 4
I have one I bought $3 dollars it does great job than my school who order 20 craftsman multimeter which cost $20 was worst it tell wrong volt. My truck have problem electric this one say 10 volt but craftsman say 4 then 20 then 0.
It seem I got good multimeter from harbor freight.
__________________
Case 222
Ford 601
Please join this
Milwaukee is offline   Reply With Quote Quick reply to this message
Old 06-16-2008, 06:15 PM   post #4 of 16
Bill Kapaun
Circumflatulater
Bill Kapaun's Avatar
MTF Member # 6264
You should get a good idea if it works by simply testing it on a couple circuits of a known voltage.
Use AC range to test wall plug in the house, DC for a 12V battery. Also test a dry cell battery, like an AAA>D size.
IF you want to get "crazy", you could buy a couple resistors at Radio Shack to check OHMS, although in reality about the only time you would test OHMS would be electric PTO or alternator stator windings. Those are LOW ohm readings, so a 10 Ohm resister would probably be adequate for a reference reading for those.
Bill Kapaun is offline   Reply With Quote Quick reply to this message
Old 06-17-2008, 12:15 AM   post #5 of 16
Greg
A day ahead of y'all..
Greg's Avatar
MTF Member # 11
SHD,
Is this for your home wiring project? Should work fine, and for other uses too.
Uses 9V battery.
Here's a link to the manual. http://www.harborfreight.com/manuals...2999/92020.pdf
Good luck, and be safe....
Greg is offline   Reply With Quote Quick reply to this message
Old 06-17-2008, 01:05 AM   post #6 of 16
silver hair deere
Old as Sin
MTF Member # 4257
Images: 4
mostly for automotive or tractor. now will have to get a hayes manual (10420)to use it as the cen-tech looks a little short on it ! and i don't want to keep pestering you guys all the time .
silver hair deere
Old 06-17-2008, 02:25 AM   post #7 of 16
okieduc104
dirtgeezer
okieduc104's Avatar
MTF Member # 7177
I probably have 4 or 6 big ones, little various multimeters, three or 4 Blasters multimeters, a couple of Fluke digital multimeters with high voltage 3000 volts DC probes, a couple of vacuum tube voltmeters and recently I bought 4 of those Harbor Freight digital multimeters for either 3 or 4 dollars each and put one in each of the old Chevies and also in the two modern daily drivers, and one in the 3/4 ton GMC. They are cheap enough that it don't pay to replace the battery, just buy another meter.
Now if I could just find a good cheap meter that would correct my spelling!
My wife starts to panic and have the shakes and the vapours,...... when I stop at Harbour Freight and say "I think I will just go in and look around."
__________________
(I was borned in Okiehoma but, my Pappy, brung me to Texxus cause he wonted me to git a god edjekashun!!)
okieduc104 is offline   Reply With Quote Quick reply to this message
Old 06-17-2008, 08:48 AM   post #8 of 16
silver hair deere
Old as Sin
MTF Member # 4257
Images: 4
same here ,but it takes only looking through one of the sale books , which seem to come about evey other day ! some times i find them in the trash before i have looked at them .
silver hair deere
Old 06-17-2008, 03:09 PM   post #9 of 16
tommyj3
Senior MTF Member
MTF Member # 6305
I've got 4 Cen-Tech meters, 2 yellow and 2 red. I keep 2 in my toolbox, 1 in the house, and 1 in the pickup. They all work great.
tommyj3 is offline   Reply With Quote Quick reply to this message
Old 06-17-2008, 06:27 PM   post #10 of 16
bblalocksr
haffast
bblalocksr's Avatar
MTF Member # 1112
Images: 7
Okie, your givig away your age. "vacuum tube volt meters" I have a few, but they haven't been made in quite a while. I have a Simpson 260 & 270 too.
I did the same thing with the HF multimeters, I think I bought 4.
__________________
The only difference between a rut and a groove is the depth.
bblalocksr is offline   Reply With Quote Quick reply to this message
Old 06-17-2008, 07:01 PM   post #11 of 16
okieduc104
dirtgeezer
okieduc104's Avatar
MTF Member # 7177
Quote:
I have 2 of the Simpson 260 meters a roll top and one for bench work and they are my everday bench meters. and also one 260 that has been modified into a Blasting Multimeter. I also have a Triplett, it is better for checking microamps than the Simpson and it has a higher ohm scale for checking teensy amounts of leakage. I don't think the Triplett is as sturdy as the Simpsons. Yes I did indicate my age with the RCA V.T.V.M. I also have a Techtronic RM540, and a 350 suitcase Oscope. I was a Jr. in college when I saw my first transistor! I promptly went out and bought a Transistor Radio! I have a bunch of analog power supplies and even have a glass door Honeywell 4 pin recorder paper, somewhere that should be in a muesum.
__________________
Old 06-17-2008, 07:05 PM   post #12 of 16
okieduc104
dirtgeezer
okieduc104's Avatar
MTF Member # 7177
Quote:
silver hair deere
Don't ever tell your wife that Harbour Freight has an online catalog or that they sell birdhouses, park benches and such.......Oh well it is probably too late, I bet she already knows!
__________________
Old 06-17-2008, 08:11 PM   post #13 of 16
silver hair deere
Old as Sin
MTF Member # 4257
Images: 4
she already knows , when i'am on the computer , the phone in the living room blinks , and i can count the secounds till them little feet come running down the hallway to see what i'am doing or looking at !!!
shilver hair deere
Old 06-27-2008, 09:01 PM   post #14 of 16
littletoes
Father of 7!!LordHelpMe!
MTF Member # 6328
Already owned a Fluke before HF was in existence around here. I think its a "77", but I don't think I'll go trade it in as of yet.....works great, right answer every time. Use another fluke, much simpler model, 99, at work, plus an old model 23 when I need to take temp's.
littletoes is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 06-27-2008, 11:38 PM   post #15 of 16
silver hair deere
Old as Sin
MTF Member # 4257
Images: 4
deal fell through with the cen-tec , went with a actron cp7676 which is geared more toward auto , with tac, dwell ,ect . should get it in about a week . anyone got one of these ?
silver hair deere
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
