wheel Horse charging system - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 05-31-2008, 03:37 PM   post #1 of 19
TJN
MTF Member
MTF Member # 12701
Help wheel Horse charging system
Hi Guys/Gals, I have a 1973, 42" cut, 12 HP, hydro, electric start/pto WH that I purchased new and am in the process of restoring. The charging system quit some time ago, consequently the electric pto pulls the battery down. I don't have any manuals so am at a loss as to what I need. Any ideas? Many thanks, TJN/56Nomad
TJN is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-31-2008, 04:09 PM   post #2 of 19
kyforeman
Senior MTF Member
kyforeman's Avatar
MTF Member # 12005
Default Re: wheel Horse charging system
More than likely you have a wiring issue or could be something a s simple as a blown fuse if it has any. On my C-160 It was overcharging went I bought it and it turned out to be the regulator. I ended up using one from a Craftsman GVT/16 until I can find the correct one I need. Below you will find a link to Kohler that has all the specs as well as shows you how to test the stator and some of the generic wiring harnesses. Although they are not wheel horse specific one can use then to figure out usually what need to be wired up . Hope this can be of help as I am new here too and want to be of help as well when I can.
http://www.kohlerengines.com/common/...es/tp_2379.pdf
kyforeman is offline   Reply With Quote Quick reply to this message
Old 05-31-2008, 04:36 PM   post #3 of 19
TJN
MTF Member
MTF Member # 12701
Kyforeman, cute kids! Thanks for the website, electrical is not my bag! TJN/56Nomad
Old 05-31-2008, 05:47 PM   post #4 of 19
kyforeman
Senior MTF Member
kyforeman's Avatar
MTF Member # 12005
On the Kohler its a fairly easy set up if its just the two wire set up coming form the engine stator as they are the ones with the AC voltage that goes to the regulator to be converted to Dc and to be stepped down in voltage. Follow the testing methods in the book. A god volt meter would be a handy tool to have and you can get a good digital one at most any auto parts store for less than 20.00 or ebay for that matter. Any questions ask away and I'm sure someone will be along to help. Yep the kids are cute, they just don't stay that way forever though. I just got done playing on ebay and I know its not a Wheel horse and all please for give me but look at my new toy.
Its a 1971 JD 140 H3 These are the auction pics as I haven't got her home yet.
Old 05-31-2008, 09:51 PM   post #5 of 19
4StarCstms
Senior MTF Member
4StarCstms's Avatar
MTF Member # 10781
That the one off Ebay in Versailles?? I REALLY thought about biddin on it..
__________________
1976 B-80 36" RD Deck
1987 418A 42" SD Deck
54" Snow Blade -
Sleeve Hitch -
WH 36" Tiller -
WH Cultivator -
Lowes 4 Wheel Wagon
My Youtube Videos
Stihl K55 Kombi-Motor
String Trimmer - Cultivator
4StarCstms is offline   Reply With Quote Quick reply to this message
Old 05-31-2008, 11:23 PM   post #6 of 19
kyforeman
Senior MTF Member
kyforeman's Avatar
MTF Member # 12005
Yep thats the one, I really dont think that it is indeed a patio tractor, but the hood could have came form one I suppose. Will know more when I go pick it up.
Now I need to figure out what I need to sell to make some room around here as its starting to get piled up again.
Old 06-02-2008, 11:47 PM   post #7 of 19
sorekiwi
MTF Member
sorekiwi's Avatar
MTF Member # 7592
Quote:
I have a similar tractor, a 73 14hp auto. The spade terminals on the back of the regulator were rusty on mine - I scratched them up a bit and its been working fine for the last 4 years.
Mike
__________________
Everything I have is old, even my wife...
sorekiwi is offline   Reply With Quote Quick reply to this message
Old 06-03-2008, 08:13 AM   post #8 of 19
kyforeman
Senior MTF Member
kyforeman's Avatar
MTF Member # 12005
TJN,
Have you figured out your issue with your charging system yet? If not and have a volt meter find the two wires coming from the stator and measure the voltage from these at high rpm, the manual claims you should have around 28 volts. Make sure you have your meter set to Ac for that part of the test. If that is showing ok the check the regulator side. Again it could be a bad stator,regulator,fuse, or even a bad ground or wiring. Just trace it down in steps and it should be a simple fix.
kyforeman
Old 06-03-2008, 10:18 AM   post #9 of 19
Mike in WI
MTF Junior Poster
Mike in WI's Avatar
MTF Member # 12979
Quote:
Originally Posted by kyforeman View Post
TJN,
kyforeman
So you're saying test the stator with the volt meter on AC, not DC? Interesting. I'm troubleshooting a charging issue with my tractor and I'm getting a 0 reading on the stator leads when on the DC side of my multimeter. Hmmm, time to do more testing tonight! Maybe I'll get lucky and it's just the regulator that's bad.
Mike in WI is offline   Reply With Quote Quick reply to this message
Old 06-03-2008, 10:36 AM   post #10 of 19
catman81056
Senior MTF Member
catman81056's Avatar
MTF Member # 7893
It's not DC current till it goes thru the rectifier.
__________________
Tim Lewis
1974 Wheel Horse D-160
1968 Wheel Horse Electro12(soon to be 16)
1967 Wheel Horse 1267
1971 TerryBass Boat 65hp Merc
catman81056 is offline   Reply With Quote Quick reply to this message
Old 06-03-2008, 10:53 AM   post #11 of 19
Mike in WI
MTF Junior Poster
Mike in WI's Avatar
MTF Member # 12979
Quote:
Yeah, that lightbulb went off in my head after reading kyforeman's post.
Old 06-03-2008, 01:25 PM   post #12 of 19
kyforeman
Senior MTF Member
kyforeman's Avatar
MTF Member # 12005
Quote:
Mike,
If its a Kohler charging system follow this link and goto page 80 or so and go through the testing section. Should get you up and going. If your Regulator is a solid state non adjustable one a lot of times they simply stop working because the terminals get corroded. I have actually removed the terminals and soldered the wiring directly in place as long as the regulator was working ok.
Old 06-03-2008, 06:26 PM   post #13 of 19
kyforeman
Senior MTF Member
kyforeman's Avatar
MTF Member # 12005
Mike,
Oops, My lightbulb just flickered abit and forgot that link,
Old 06-03-2008, 08:10 PM   post #14 of 19
catman81056
Senior MTF Member
MTF Member # 7893
And I thought it was just me!!!!
__________________
Tim Lewis
Sponsored Links
Advertisement
Old 06-03-2008, 10:30 PM   post #15 of 19
TJN
MTF Member
MTF Member # 12701
Sorekiwi, Where exactly IS that regulator? Thanks, TJN/56Nomad?1973, 42"cut, WH, Hydro
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
