Hooking up to the hydraulic control valve (help) what else do I need - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 03-28-2008, 06:40 PM   #1
JD Power
425 AWS owner
JD Power's Avatar
MTF Member # 10371
Images: 7
Default Hooking up to the hydraulic control valve (help) what else do I need
How or what do I need to hook up the BM17347 Front Hitch??? What fittings I have two female on the hitch
__________________
-Greg
'96 John Deere 425 AWS
'84 Massey Ferguson 210 w/front loader 216
w/attachments
--backups--
'94? Toro Groundmaster 445-D
'90? Jacobsen Turfcat II DW 224
JD Power is offline   Reply With Quote
Sponsored Links
Advertisement
Old 03-28-2008, 06:45 PM   #2
JDFANATIC
9K+ Poster
JDFANATIC's Avatar
MTF Member # 41
Images: 1
Garage
Default Re: Hooking up to the hydraulic control valve (help) what else do I need
JD,
You need the hydraulic coupler kit. I'm not sure of the p/n, but will check.
__________________
Cheers
JDFANATIC
JD2210, loaded tires, 62C MMM, 210 Loader, 47" Snowblower, York Rake, PTO Spreader, Heated Cab, JD Plug Aerator, FIMCO Sprayer, Wheel Spacers, FEMCO Folding ROPS, JD Cart, Stihl MS170 and HT101, Wallenstein BX32 PTO Chipper
JDFANATIC is online now   Reply With Quote
Old 03-28-2008, 09:34 PM   #3
JD Power
425 AWS owner
JD Power's Avatar
MTF Member # 10371
Images: 7
this ? if so how would install it with out draining the fluid
__________________
-Greg
w/attachments
--backups--
Old 03-29-2008, 08:03 AM   #4
JDFANATIC
9K+ Poster
JDFANATIC's Avatar
MTF Member # 41
Images: 1
Garage
Yes,
I've never installed one, but I'll bet you don't spill that much and can just top off what was lost. Then again, it may be a good excuse for a tranny fluid change.
You might want to pm Unit40 as he just went through this on his post which is something that goes along with the couplers: http://www.mytractorforum.com/showthread.php?t=54837
__________________
Cheers
JDFANATIC
Old 03-29-2008, 10:02 AM   #5
Caseguytoo
Banned!
MTF Member # 7029
Fluid loss is next to nothing as long as none of the spool valves are pushed in either direction. Just remove the plugs, screw in the appropriate quick-coupler half and tighten them. Don't forget to use thread sealant.
You can check your fluid level after but you won't be adding anything.
Caseguytoo is offline   Reply With Quote
Old 03-29-2008, 10:14 AM   #6
bruce56bb
MTF Member
bruce56bb's Avatar
MTF Member # 6691
jd power, i installed a blade with the angling cylinder this week on my 425aws. the part #for the 4 coupler kit is BM17763.
there is not much oil that drains from the ports when you remove the plugs.
bruce
__________________
JD 425 AWS, Husky 346XP and 51, EarthStove 2800HT
bruce56bb is offline   Reply With Quote
Sponsored Links
Advertisement
Old 03-30-2008, 10:48 AM   #7
JD Power
425 AWS owner
JD Power's Avatar
MTF Member # 10371
Images: 7
thanks for all the info and help/part numbers
__________________
-Greg
w/attachments
--backups--
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
