using the landscape rake - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 01-14-2008, 09:28 PM   #1
2Lazyt2
MTF Junior Poster
2Lazyt2's Avatar
MTF Member # 8389
Default using the landscape rake
OK, I broke down and rented a landscape rake. Got it hooked up to the 3 point and off I went to play in the dirt.
So, I start trying to rake the stone debris out of the dirt around the house left by the builders. I set the rake down into the dirt about an inch and very shortly I'm digging a lot of dirt. It's real sandy and dry and should just fall through the tines but it doesn't. It piles up in the rake and pretty soon I have a trench across my property and lots of stones left behind!
I have the thing set pretty level. Should I adjust top link to give it less angle on the tines? Also, I have a 2320. I can't find anything in the manual that explains how to use the dang 3pt other than simple up and down. Is there a float position and would it work on a rake?
2Lazyt2 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-14-2008, 09:49 PM   #2
Argee
5000 Strong & Climbing
Argee's Avatar
MTF Member # 5
Images: 11
Default Re: using the landscape rake
Set the rake so it barely touches the surface when down...that way you'll grab the stones and leave the soil.
__________________
Randy G
Argee is offline   Reply With Quote
Old 01-14-2008, 10:20 PM   #3
2Lazyt2
MTF Junior Poster
2Lazyt2's Avatar
MTF Member # 8389
Well, I tried that too and it wouldn't pick up the rock. To make matters worse, after screwing around out there for a while, I had the whole place so lumpy with piles of rock and sand and leaves, I couldn't keep the rake level enough to do much of anything except make it worse.
Old 01-14-2008, 10:40 PM   #4
ccsial
Senior MTF Member
ccsial's Avatar
Location: Northern IL 30 mi NW of Rockford, IL in farm country
MTF Member # 7152
Gauge wheels are pretty handy for this work. I added them to my rake. Otherwise I had to go real slow and keep adjusting.
Your 3PH should float up but not down. I'm not aware of anyway to make it float both ways.
__________________
JD X748SE - Kubota L3400HST - Ford 1910 FEL
ccsial is offline   Reply With Quote
Old 01-14-2008, 11:09 PM   #5
2Lazyt2
MTF Junior Poster
2Lazyt2's Avatar
MTF Member # 8389
If I drop it all the way down with the control lever, is that the float position?
Old 01-14-2008, 11:35 PM   #6
Argee
Argee's Avatar
MTF Member # 5
Images: 11
Yes....as long as you don't have draft control. But that's not going to help...as you're going to fill it up again...it's just the nature of the beast. Try angling it while just keeping it touching until you can get the lumps flattened out.
__________________
Randy G
Old 01-15-2008, 02:03 AM   #7
JDFANATIC
9K+ Poster
JDFANATIC's Avatar
MTF Member # 41
Images: 1
Garage
2lazyt2,
3PH float is the weight of the implement. I don't know how big of a landscape rake you are using, but it probably has enough weight to start digging into the soil. As pointed out, gauge wheels make all the difference (expensive option but worth it), other than that, you need to keep playing with the position control.
__________________
Cheers
JDFANATIC
JD2210, loaded tires, 62C MMM, 210 Loader, 47" Snowblower, York Rake, PTO Spreader, Heated Cab, JD Plug Aerator, FIMCO Sprayer, Wheel Spacers, FEMCO Folding ROPS, JD Cart, Stihl MS170 and HT101, Wallenstein BX32 PTO Chipper
JDFANATIC is online now   Reply With Quote
Old 01-15-2008, 07:53 AM   #8
2Lazyt2
MTF Junior Poster
2Lazyt2's Avatar
MTF Member # 8389
Yep. All good advice. Thanks. I hear the rain just started. Oh well. It's gonna be an interesting day today. Got about 6 hours left on the one day rental. My main objective for renting was to see if I should buy one. Considering how long it took yesterday to make a genuine mess of my front acre...... renting is no option.
Old 01-15-2008, 08:25 AM   #9
Argee
Argee's Avatar
MTF Member # 5
Images: 11
Quote:
If you decide to buy one, consider one that is a foot wider than your tractor....that way when you angle it, it will cover your tire tracks.
__________________
Randy G
Old 01-15-2008, 01:28 PM   #10
bontai Joe
Citizen of Earth
bontai Joe's Avatar
MTF Member # 51
Images: 2
The one I rented was not a 3 point, but a simple pin hitch connection and had gage wheels. Used just it's own weight and worked very well. I went from the outside edges of the yard and raked toward the center until I had a single "windrow" of rocks and stones. Then I shoveled them into a cart.
__________________
If it's FREE, it's for ME!
ALWAYS remember to remove the spark plug wire from the plug before sticking your hand in the machine!!!! The fingers you save could be your own.
bontai Joe is offline   Reply With Quote
Old 01-15-2008, 02:23 PM   #11
Argee
Argee's Avatar
MTF Member # 5
Images: 11
I have a 7' unit I use on my tractor which is 5' wide.
I have this unit that I pull behind my GT5000. It's 48" wide but is available in 60" and 72".....I wish that I would have gotten the 60". My GT is 36" wide.
__________________
Randy G
Old 01-15-2008, 05:29 PM   #12
Team_Green
Banned!
MTF Member # 7124
Images: 2
Would those rakes work well for leveling also?
Agree thats a nice looking ford you have there..Is that your garden space in the picture?
Team_Green is offline   Reply With Quote
Old 01-15-2008, 05:36 PM   #13
Argee
Argee's Avatar
MTF Member # 5
Images: 11
The 3PH one works fair for leveling. The pull behind works great.
Thanks for the compliment and yes that's one of my garden spaces.
__________________
Randy G
Old 01-15-2008, 05:42 PM   #14
Dude11
2000 Posts and climbing!!!
Dude11's Avatar
MTF Member # 8852
Images: 4
These are called "rock rakes"around here and if you angle it as some said it works great for leveling crush run type driveways.I used one on another home once owned with Longgg rock driveway.Angled that boy to the center on both sides then just barely hit the top down the middle.Works great!!I'm pretty sure the angle thing is the best bet any where you use it yards,fields,etc.Good Luck,Dude11
Dude11 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-15-2008, 06:26 PM   #15
escavader
Senior MTF Member
escavader's Avatar
MTF Member # 8693
Ive rigged up a quick hitch that easilt attaches to my loader bucket.Here is a pic of my rake up front instead of on back
ALAN
Name:	100_1627 (671 x 447).jpg
__________________
BX-23 TLB,LOADED AG TIRES,MECHANICAL THUMB,BUCKET FORKS ,FRONT BUCKET QUICK HITCH,REAR 3 POINT QUICK HITCH,WOODS 5 FOOT RAKE,6FT TSC BLADE,SALSCO 600 CHIPPER, MARKHAM TOOTHBAR,BACKHOE TRAILER HITCH,HOME MADE HEATED CAB,PRONOVOST PUMA 54 SNOWBLOWER WITH HYDRAILIC CHUTE CONTROL
escavader is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
