Briggs 19D engine no spark - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
Reply
Thread Tools Display Modes
Old 11-16-2007, 03:27 PM   post #1 of 26
kwwolfe
Senior MTF Member
MTF Member # 2672
Default Briggs 19D engine no spark
As some of you might know, I recently purchase a 1964 Sears Suburban 725. The engine is a B&S 19D (7.25HP). I am learning as I go. Last night I took the wire off the plug and pull started it using a rope.....no spark. Tried it a couple of times with no visible arc. I even held the end of the wire to see if I could feel anything. Nope
The nice folks over at B&S emailed a copy of the parts manual for the tractor. It appears that the engine has a magneto flywheel and armature. I believe I understand how this works. I need help trouble shooting. Tonight I am going to look for loose wires. What else could it be?
kwwolfe is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 11-16-2007, 03:36 PM   post #2 of 26
scrodamoon
Senior MTF Member
scrodamoon's Avatar
MTF Member # 7911
Images: 2
Default Re: Briggs 19D engine no spark
did you put a new plug in or was it the old one?
__________________
one day there will be a nice list of tractors here.
scrodamoon is offline   Reply With Quote Quick reply to this message
Old 11-16-2007, 03:45 PM   post #3 of 26
scrodamoon
Senior MTF Member
scrodamoon's Avatar
MTF Member # 7911
Images: 2
nice machine tho you got pics of it? if its not that id check the carb or drain old gas if there is any carb might just need a good cleaning its a pain testing for spark on a pull start I ushally have a buddy help me one pulls while the other one checks just easyer there is also spark plug testers you can get and they are ushally good I gotta thank my grandpa I still have his tools from the good old days haha.
dump some gas down her and see what she does she should burp or fart atleast.
__________________
Old 11-16-2007, 04:39 PM   post #4 of 26
kwwolfe
Senior MTF Member
MTF Member # 2672
I took the wire off the plug and layed it next to the exhaust to see if I could see a spark/arc. None. Someone here at work suggested that I take off the cover and see if the mangets are rusting. If so clean them up and then see what happens. I also read online to disconnect the stop wire and see if that helps. I am dying to here this things run.
Here are some pics.
Old 11-16-2007, 05:10 PM   post #5 of 26
scrodamoon
Senior MTF Member
scrodamoon's Avatar
MTF Member # 7911
Images: 2
wow thats gonna be a fun toy right on. lemme know what happens when you get to that part if you have any luck with it.
__________________
Old 11-16-2007, 05:14 PM   post #6 of 26
winhoops
MTF Junior Poster
MTF Member # 8028
is the switch on
winhoops is offline   Reply With Quote Quick reply to this message
Old 11-16-2007, 05:38 PM   post #7 of 26
kwwolfe
Senior MTF Member
MTF Member # 2672
Quote:
Originally Posted by winhoops View Post
is the switch on
Yep. The machine has a knob you pull out to run. I am assuming that when the knob is pushed in, it connects the stop wires and shuts the engine off.
Old 11-16-2007, 07:26 PM   post #8 of 26
lawnmowertech
Proud Member of the 1K Club
lawnmowertech's Avatar
MTF Member # 7268
Images: 2
hmmm sounds like a points or condenser or even both bad in this machine
__________________
Owner of CM Small Engines. We can access obsolete small engine parts to help get your machine back up and running. PM me with your inquiries!
lawnmowertech is offline   Reply With Quote Quick reply to this message
Old 11-16-2007, 08:30 PM   post #9 of 26
kwwolfe
Senior MTF Member
MTF Member # 2672
Quote:
Does it have them? I don't that I see that in the parts diagrams. Only the "flywheel magneto" and the "amature assembly". I was assuming that the magnets on the flywheel pass by the armature (coil) and create and electrical current that travels straight to the spark plug. Does this sound right????
Old 11-16-2007, 09:51 PM   post #10 of 26
Dad0850
7000 posts and climbing!!
Dad0850's Avatar
MTF Member # 4482
Images: 7
If the engine is still original, it will have points and condenser. They are the likely suspects!
Dad0850 is offline   Reply With Quote Quick reply to this message
Old 11-16-2007, 10:41 PM   post #11 of 26
bser
Senior MTF Member
MTF Member # 7211
Electronic coils did not come out till 1981. Look under flywheel for pts and cond., replace them both. If after you have replaced pts/cond,and you still don't have spark, then replace coil. After looking at pictures,does this mower have a coil like a car and on the outside of engine?
bser is offline   Reply With Quote Quick reply to this message
Old 11-21-2007, 03:50 PM   post #12 of 26
kwwolfe
Senior MTF Member
MTF Member # 2672
Got a chance to work on the 725 last night. I got the starter pully off using a gear puller. This gave me a chance to get a good look at the magneto and the armature. In the pictures below, I took a brass wire wheel to the magnets to clean them up. They had a layer of rust over them. Next I need to remove the armature and clean that up.
You all were right. I found the breaker point. I also attached a picture of that. When I removed the cover (sealed), I found that the parts contained within looked like new. I guess that cover has been doing its job. I guess I should also clean the point and check the gap.
When I spun the flywheel, I could see the breaker plunger back up (making the breaker make contact) right after of the compression stroke.
Name:	magneto and armature.jpg
ID:	29586   Click image for larger version
Name:	breaker points cover.jpg
ID:	29587   Click image for larger version
Name:	breaker points.jpg
Old 11-21-2007, 11:11 PM   post #13 of 26
lawnmowertech
MTF Member # 7268
Images: 2
it looks like its either the coil bad or the points thanks
calvin
__________________
Old 11-23-2007, 04:51 PM   post #14 of 26
Dad0850
Dad0850's Avatar
MTF Member # 4482
Images: 7
At the very least, I would clean up the points and check the gap.(if they don't look too bad) And, I would replace the condenser. Then put the flywheel on, with the nut just finger tight or a little more, and then check for spark again.
Sponsored Links
Advertisement
Old 11-23-2007, 08:01 PM   post #15 of 26
Kbeitz
Collector of many tractors
Kbeitz's Avatar
MTF Member # 86
Images: 4
The best thing to do is first get a good points file... Sometimes you need to clean the point 5-6 time before they will spark again... Next I would get a drill socket adapter so you can put a socket in your drill... Put the socket on the big nut on the flywheel and take the spark plug out and lay it with the wire attached on the engine head... Use the drill to spin the engine over and make sure it's turning the right way... Now you can watch for spark and play with the points... Anytime you park a tractor engine with points for a long time you will need to clean them to get it running again...
__________________
Kbeitz is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
