Two-Stroke engine fuel warning - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
Reply
Thread Tools Display Modes
Old 10-17-2007, 09:27 AM   post #1 of 12
Artpb
Proud Member of the 1K Club
Artpb's Avatar
MTF Member # 52
Images: 1
Default Two-Stroke engine fuel warning
This may be old news to amny of you. The key seems to be homewowners use where the engine is not used to often. Would a little dry gas help?
Wednesday, October 17, 2007 4:15 AM EDT
Ethanol not so friendly to power tools
BY PAUL SINGLEY REPUBLICAN-AMERICAN
Anyone who uses a chainsaw, weed whacker or snowmobile may notice the engines in their equipment breaking down quicker than they used to.
Many times the reason is ethanol, a fuel additive made of corn, sugar and other grains that Connecticut gasoline distributors have been using since 2003.
Ethanol is supposed to burn cleaner, reduce air pollutants and serve as a healthy alternative to MTBE, the additive it has replaced. But high amounts of ethanol can wreak havoc on small power tools that use two-stroke engines -- as opposed to four-stroke engines used in many automobiles -- according to local experts on power equipment.
"The biggest problem is that ethanol absorbs water, especially when people leave the gas cap off on a hot, sunny day," said Lee Schmidt, owner and manager of Schmidt's & Serafine's, an outdoor power equipment company in Waterbury. "We'll have customers bringing in new lawnmowers, and the carburetors will be corroded like they are 10 years old."
Schmidt, who has almost 30 years of experience working on outdoor power equipment, recommends that all of his customers use a high-octane fuel with low ethanol levels. He recommends using at least an 89 octane fuel, with 11 percent ethanol. His company sells brand-name STIHL equipment, and Schmidt said a STIHL chainsaw will run on E-10, meaning 10 percent ethanol. "Anything over 12 or 13 percent and it won't even start," he said.
"This is not as much of a problem in automobiles because they are running all the time," he said. "The biggest problem is with the small stuff, like chainsaws. People need to keep the gas caps on properly."
Dave Blersch, owner of Chainsaws Unlimited Inc. in Southbury, agrees with most of Schmidt's suggestions. He urges customers to use at least a 93 octane gas.
"Every time the gas hits the air it loses a point of octane, so I suggest a higher octane gas," he said.
High-octane gas costs a little more, but it's worth it, he said.
He also urges people to keep gas no longer than 30 days, because the longer it sits, the more water it absorbs.
"People will argue with you that they never used to do it this way," said Blersch, who has been in business since 1978. "I have that conversation at least three times a week. But the average person doesn't know of all the changes that the government has made to the gasoline, and it's our job to educate them."
Artpb is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 10-17-2007, 10:04 AM   post #2 of 12
06toro
First, do no harm.
MTF Member # 4595
Images: 3
Default Re: Two-Stroke engine fuel warning
Can i use the two cycle gas up in another 4 stroke engine so it does not get old. Will it burn up with out gumming up things in the two stroke?
I always have chainsaw gas left over.
06toro is offline   Reply With Quote Quick reply to this message
Old 10-17-2007, 10:19 AM   post #3 of 12
freebird
Camaniac
MTF Member # 63
I've been told to put your leftover 2 cycle gas in your car/truck tank. It gets diluted nicely and the little extra lube it gives your valves and cylinder walls doesn't hurt either.
A friend of mine has a son in the military who works on small 4 stroke engines and ALL of them look brand new inside, the secret? They mix 2 oz of 2 stroke oil per 5 gallons of gas. Makes them run real good.
__________________
1956 Cub Lo-Boy
JD LA175
JD LT133
JD RX73
Sears 16/6
If you can't fix it with a hammer, it must be an electrical problem!
freebird is offline   Reply With Quote Quick reply to this message
Old 10-17-2007, 10:41 AM   post #4 of 12
munderhill
5000 Strong & Climbing
munderhill's Avatar
MTF Member # 3901
Images: 7
A little pre-mix wont hurt any 4 stroke.
munderhill is online now   Reply With Quote Quick reply to this message
Old 10-17-2007, 11:47 AM   post #5 of 12
Artpb
Artpb's Avatar
MTF Member # 52
Images: 1
Old 10-17-2007, 12:57 PM   post #6 of 12
1086
3K Poster!!!!
1086's Avatar
MTF Member # 1086
Images: 11
Not according to Wikipedia.
Dry gas is an ethanol-based additive used in automobiles to prevent any water in the fuel from freezing, or to restore combustive power to gasoline spoiled by water. It is a liquid that is added in to the fuel tank, that absorbs the water and keeps it in solution. (Some brands contain methanol and some contain isopropyl alcohol.[1])
Some states require a 10-15% ethanol solution be sold at refueling stations. Most current gasoline-powered automobiles can safely run up to a 15% ethanol solution without any modification. However, at 20% or above older vehicles may require replacing the fuel lines to prevent degradation and rupture, and the electric fuel pump may need modification to prevent ethanol "dry rot". There is no point in adding dry gas to fuel that already contains a significant percentage of ethanol. Maybar
1086 is offline   Reply With Quote Quick reply to this message
Old 10-17-2007, 02:05 PM   post #7 of 12
Artpb
Artpb's Avatar
MTF Member # 52
Images: 1
Ah Maybar, now I understand. Ethanol dosn't displace water it attracts it.
Old 10-17-2007, 06:33 PM   post #8 of 12
echoman
2 stroke enthusiast
echoman's Avatar
MTF Member # 6344
Images: 1
Isopropyl absorbs H2o. This should should be the only type used in small engines especially 2 strokes. I've always used MMO and SeaFoam usually together in all my batches of fuel both 2 cycle mix and straight. Some of my older engines would get a dose of Sta-Bil on top of that, and I have never had a corroded fuel system in over 20 years now(off season storage). Not 20 years sitting idle. I'm a BIG fan of fuel conditioners/additives. I live in the Midwest where 10% ethanol blended fuels have been the norm for about 25 plus years now.
echoman is offline   Reply With Quote Quick reply to this message
Old 10-17-2007, 08:06 PM   post #9 of 12
Artpb
Artpb's Avatar
MTF Member # 52
Images: 1
Hmm. Now I am confused again. Isopropyl absorbs H2o. Isn't that what is known as rubbing acohol? Not that is a bad thing.
Thanks for the input guys.
Old 10-18-2007, 08:15 AM   post #10 of 12
echoman
2 stroke enthusiast
echoman's Avatar
MTF Member # 6344
Images: 1
You are correct Artpb, but I don't know if the concentration levels are the same from actual fuel drier to the wife's bottle under the bathroom sink. I'd stick to the real stuff to be safe. Most manu's will lable their product ISO, or ISO-HEAT, ISO-DRIER, like that. It will say which type of alcohol is used so simply read the lables, front and back to find out for sure.
Old 10-18-2007, 01:03 PM   post #11 of 12
Bountyhunter
Senior MTF Member
MTF Member # 1091
Won't using old two stroke mixtures in your cars reek havoc with the emissions systems in cars, especially the catalytic converters?
Bountyhunter
Bountyhunter is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 10-18-2007, 01:36 PM   post #12 of 12
echoman
2 stroke enthusiast
echoman's Avatar
MTF Member # 6344
Images: 1
A few gallons of 32-50:1 with 15 plus gallons straight gas would give you a 200:1 or so mix ratio(without calculating). I usually give my older unused mix away for others to burn in older vehicles. It won't "kill" the emission system, but I wouldn't practice doing this much more than once a year.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
