Kohler Fuel Pump Rebuild - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
Reply
Thread Tools Display Modes
Old 08-19-2007, 09:13 AM   post #1 of 11
MaineDad
Proud Member of the 1K Club
MaineDad's Avatar
MTF Member # 547
Images: 3
Default Kohler Fuel Pump Rebuild
Guys,
I'd like to rebuild my original fuel pump on my 1996 Kohler Fuel Pump. Part number 47-559-08. Where can I find a new diaphragm for it?
__________________
Micah
MaineDad
1963 Wheel Horse 753
1977 Wheel Horse B-100
1977 Wheel Horse C-120
http://www.gardentractorgardening.com/
MaineDad is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-19-2007, 09:31 AM   post #2 of 11
glenn27
10,000 +posts!
glenn27's Avatar
MTF Member # 703
Images: 2
Default Re: Kohler Fuel Pump Rebuild
Micah--=You might be able to find it locally, if you have a good sized shop near you that does a lot of Kohler parts.
Online, I have dealt w/ these folks twice and both times got what I needed//
http://www.tulsaenginewarehouse.com/
**Side note**--I'm in the midst of replacing the pump on the K321, and as far as I looked, at the time--no bebuild kit was still available,for my application, so I purchased a new one (plastic replacement)--now i can leasurally find a rebuild for the old one.
Your Toro or JD dealer should be able to order it, if you don't have an independant shop near by.
Stand-by for sticker shock, though!!
__________________
Sometimes you just have to laugh..To keep from going insane!!
Jimmy Buffett
glenn27 is offline   Reply With Quote Quick reply to this message
Old 08-19-2007, 09:52 AM   post #3 of 11
MaineDad
MaineDad's Avatar
MTF Member # 547
Images: 3
Glenn,
Thanks. I have already bought and installed a $49 replacement at NAPA, but it does not have a check valve. Now the gas drains out of the pump if it sits for a while and it takes 3 times to start. I believe the check valve keeps the fuel from draining out allowing it to have some gas for the next start. Any thoughts on what else to do?
__________________
Micah
MaineDad
Old 08-19-2007, 10:41 AM   post #4 of 11
glenn27
10,000 +posts!
glenn27's Avatar
MTF Member # 703
Images: 2
How about one of those little in-line shutoff's ??just a twist of the plunger when you finish--then open when you get ready to start?
About 3.00 at most..
I've got them on two mowers now and work good.
I think Volfandt installed one on his 856--look back thru his {Venerrable 'ol W/Horse} thread for a picture...
__________________
Jimmy Buffett
Old 08-19-2007, 10:55 AM   post #5 of 11
MaineDad
MaineDad's Avatar
MTF Member # 547
Images: 3
Good idea. Will try that first.
__________________
Micah
MaineDad
Old 08-19-2007, 02:53 PM   post #6 of 11
LilysDad
Just Have a Little Faith!
MTF Member # 7161
If it drains out where does it go? In the cylinder?
LilysDad is offline   Reply With Quote Quick reply to this message
Old 08-21-2007, 08:23 PM   post #7 of 11
MaineDad
MaineDad's Avatar
MTF Member # 547
Images: 3
I believe it goes back down the fuel line...
I sprayed a little starter fluid in the carb tonight and it started right up. I ran it for a few minutes and then shut her down and turned off the line with a new inline shutoff valve. Hopefully that keeps the gas from draining back down and starts up quicker. I'll try to start it tomorrow night and see what happens. I'd still like to find an original fuel pump with the check valve if possible.
__________________
Micah
MaineDad
Old 08-21-2007, 09:01 PM   post #8 of 11
Mowerman
Senior MTF Member
MTF Member # 2691
MaineDad, something doesn't sound right. The Kohler pump, and the one from NAPA should have the check valves. (In and Out). there's no other check valves that I know of. Try the shutoff as you said, you may have a bad pump. One of the check valves maybe dislodged in the pump. Tony
Mowerman is offline   Reply With Quote Quick reply to this message
Old 08-21-2007, 09:29 PM   post #9 of 11
Kbeitz
Collector of many tractors
Kbeitz's Avatar
MTF Member # 86
Images: 4
You can buy little check valves from people at this link...
http://www.smokstak.com/forum/calendar.php?c=1
__________________
Kbeitz is offline   Reply With Quote Quick reply to this message
Old 08-23-2007, 08:18 PM   post #10 of 11
MaineDad
MaineDad's Avatar
MTF Member # 547
Images: 3
Update: Started her up after two days with the shut off valve keeping the gas from draining out of the pump and it started up on the first crank! So it adds just one extra step after I turn it off but it's better than spending $90 for another pump.
Thanks for the advice guys...
__________________
Micah
MaineDad
Sponsored Links
Advertisement
Old 08-23-2007, 08:58 PM   post #11 of 11
glenn27
10,000 +posts!
glenn27's Avatar
MTF Member # 703
Images: 2
Thanks--Micah--sometimes the simplest (until you find the real cure) work good.
Let me know what you decide to do later on...
Good luck, friend!
glenn
__________________
Jimmy Buffett
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
