Got my MTD Garden Tractor today! - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 07-02-2007, 10:46 PM   post #1 of 17
RED-85-Z51
Certified Technician
RED-85-Z51's Avatar
MTF Member # 2950
Images: 7
Default Got my MTD Garden Tractor today!
Had a good time getting it.
I decided it was too far to drive my Diesel on the road to retreive it, so I Got my little cousin, and I too my truck up the road with some chain.
We hooked onto the back of it and pulled it out of the overgrowth and got a good look at it. The sttering was locked up, but a few kicks fixed that. All 4 tires had been slashed at some point.
So I broke off the hood and front grille parts, they were rough anyways, and in the way. Hooked onto the front of the frame and got my cousin to sit on the seat and guide it while I pulled him 3/4 mile back to my place. Had a few tense moments at 20mph, but got it home.
Got the motor to turn over easy enough, deck looks great, belts look good, and it has a Peerless 618-0229 Peerless gearbox, and the SHIFT ON THE GO Variator setup that gives it 14 forward speeds, and 7 reverse speeds.
It says it is a GARDEN TRACTOR...and it has 12" rear wheels with 4 bolt hubs...is it capable?
Has an 18.5 hp Briggs opposed Twin.
Pics later this week.
__________________
1993 Wheel Horse 416-H
Onan P216G
1962 WH702
1997 K3500 Dually Sierra
Crew Cab, Long bed, Vortec 454
1995 K3500 Silverado
TBI 454
1995 K2500 Silverado
6.5 Detroit Turbo Diesel
1994 GMC Sierra Z71
350 TBI
RED-85-Z51 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-02-2007, 11:12 PM   post #2 of 17
jwor620
2000 Posts and climbing!!!
jwor620's Avatar
MTF Member # 1165
Images: 9
Default Re: Got my MTD Garden Tractor today!
With the exception to the 4 bolt rear wheels it sounds just like mine. I will have to measure the rear wheels for you tomorrow, but the tire size says 23 X 9.50 on the rear. You might look to see what your tires are supposed to be. The smaller Wards/MTD I have has 20X10 on the rear so, are you measuring just the rim????
Congrats on the safe trip home and on the find. The motor alone is probably worth the effort to get it home.
P.S. I did measure the actual diameter of the rear wheels on the GT I have. They measure exactly 12 inches. The front wheels fyi are 9 inches in diameter.
__________________
http://www.picturetrail.com/jwor620
Walk Behinds
LB7000
Honda HR216SX Commercial
Honda HR 215 HX Masters
Riders
Cub Cadet 2518
John Deere 332
jwor620 is offline   Reply With Quote Quick reply to this message
Old 07-03-2007, 01:00 AM   post #3 of 17
RED-85-Z51
RED-85-Z51's Avatar
MTF Member # 2950
Images: 7
Looks like the front wheel bushings are gone on this tractor...
If I get it running good, and everything works, Im thinking of getting some cheap Lug tires for the back, and some ribs for the front.
The rims are 12" in the back, and Im pretty sure the fronts are standard 8" tractor size, tire is most likely 18 or 16X-8.50-8
The rears look like 23-10.50-12, give or take an inch on the width.
Its got a different layout than any MTD ive seen...
Im impressed by the deck more than anything, it looks solid!
__________________
Onan P216G
1962 WH702
TBI 454
1994 GMC Sierra Z71
350 TBI
Old 07-03-2007, 02:22 AM   post #4 of 17
RED-85-Z51
RED-85-Z51's Avatar
MTF Member # 2950
Images: 7
Ive done a whole bunch of research tonight on this thing, and here is what Ive leanred.
MTD did in fact produce a Heavy Duty Tractor line known as the "800 series" back in the late 90's.
It used a special transmission that was heavier than anything else on any other MTD mowers at the time.
They had 46" 3 blade decks.
Frames were beefier.
They offered a 10" breaking plow, Electric Lift kit, Disc Harrow and Cultivators for the 800 series tractors. So it is qualified to use Ground engaging implements.
My model number is 14AS840H120
__________________
Onan P216G
1962 WH702
TBI 454
1994 GMC Sierra Z71
350 TBI
Old 07-03-2007, 07:00 AM   post #5 of 17
jwor620
jwor620's Avatar
MTF Member # 1165
Images: 9
All of that and for a mere price of towing it home. Not bad! Not bad at all! Look forward to seeing the pictures.
__________________
Walk Behinds
LB7000
Riders
Cub Cadet 2518
John Deere 332
Old 07-03-2007, 10:10 AM   post #6 of 17
Poopdeck Pappy
Senior MTF Member
MTF Member # 6127
Sounds like a real good find. Congrats. Please keep us updated on your progress. And, as always, pics would be nice.
Poopdeck Pappy is offline   Reply With Quote Quick reply to this message
Old 07-03-2007, 06:48 PM   post #7 of 17
saskman49
Nicky&Sterling RIP 03-08
saskman49's Avatar
MTF Member # 4038
Sounds a little like my white
http://www.mytractorforum.com/showthread.php?t=43411
__________________
John
JD2320 with 62D, 200 CX with 53" bucket
Speeco QH & Hydraulic top link
JD 647 tiller
JD 413 Rotary Cutter
Frontier SP1060 Soil Pulverizer
Frontier BB2060 Box Blade
Land Pride 1572 Rear Blade
Allied 50" blower
Frontier pallet forks
55 Gal 3pt sprayer
Frontier middle buster
3 section diamond drag harrows.
JD X485 with 62C deck
JD Gator TH 6x4
JD 216H 46 mower and 33 tiller
JD JS35 Mower
Stihl BG86, 017, MS250, FS90R, KM130R
Gone LT2000, JD GT235, X500, LT180, 108 and 265 also White GT1822
saskman49 is offline   Reply With Quote Quick reply to this message
Old 07-20-2007, 01:32 AM   post #8 of 17
jwor620
jwor620's Avatar
MTF Member # 1165
Images: 9
Red,
Did you ever take any pictures of this tractor? I would like to see how it compares to my GT.
__________________
Walk Behinds
LB7000
Riders
Cub Cadet 2518
John Deere 332
Old 07-25-2007, 12:06 PM   post #9 of 17
Tvern13
Senior MTF Member
Tvern13's Avatar
MTF Member # 385
Images: 1
Red,
They made 800 series after the 1990's. Model number on mine is 14AI808H731 and it was made in 2004. It has a 46" 3 blade deck and is rated for a 10" plow and a hydraulic tiller. They offer both a manual and an electric hitch for it.
__________________
The little red tractor(s) that could!!!
OOPs - How did that cub get in here!!!
Cub Cadet GT2100 23 HP Kohler
54" Fabricated deck
Rear Bagger
Yanmar 1610D
Koyker 80 FEL
4' Box blade
Yanmar RSB1401 Tiller
Howse PHD
Howse middle buster
MTD Pro 25 HP Garden tractor
46" mower deck
Rear bagger
Johnny Bucket
Weight box
17 cu. ft. Brinley dump cart
Tow behind sprayer
Tvern13 is offline   Reply With Quote Quick reply to this message
Old 07-27-2007, 02:49 AM   post #10 of 17
RED-85-Z51
RED-85-Z51's Avatar
MTF Member # 2950
Images: 7
Havent done much to it, looks like its going to need a starter...engine turns over SLOW
__________________
Onan P216G
1962 WH702
TBI 454
1994 GMC Sierra Z71
350 TBI
Old 07-31-2007, 07:19 AM   post #11 of 17
jwor620
jwor620's Avatar
MTF Member # 1165
Images: 9
Red,
Are you sure it is the starter? I have read different threads indicating this could also be a valve clearance issue among others I can not remember. Thought I would throw that out just in case. By the way,
__________________
Walk Behinds
LB7000
Riders
Cub Cadet 2518
John Deere 332
Old 08-16-2007, 04:21 PM   post #12 of 17
Sarge
Sarge
MTF Member # 6927
I was really happy to find your post on the MTD GT. I have one just like it and am not very familiar with MTD. I am missing the 5th number in the model number. Mine reads
14AS?4AHO62 Do u have any clue as to what it could be?
Thanks, Sarge
__________________
Sarge in Lickskillet, Texas
Sarge is offline   Reply With Quote Quick reply to this message
Old 08-24-2007, 06:47 PM   post #13 of 17
Sarge
Sarge
MTF Member # 6927
RED,
Where are you when I NEED you? Seems like you haven't posted about this in years!
__________________
Old 08-24-2007, 09:31 PM   post #14 of 17
Kbeitz
Collector of many tractors
Kbeitz's Avatar
MTF Member # 86
Images: 4
The heavy duty ones was made more like in the 60's-70's not the 90's
MTD = Machine tool and Die co.
Pulling anyones garden tractor 20 mph with a chain is asking for trouble...
And putting a kid on it is really asking for trouble...
Glad no one got hurt...
__________________
Kbeitz is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-25-2007, 12:51 AM   post #15 of 17
jwor620
jwor620's Avatar
MTF Member # 1165
Images: 9
Kbeitz,
I believe the M = Modern
Check this link. That is where I got the information.
http://www.mtdproducts.com/corporate/ourCompany.jsp
Look on the side of the truck in the picture about half way down.
__________________
Walk Behinds
LB7000
Riders
Cub Cadet 2518
John Deere 332
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
