convert to electric fuel pump - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
Reply
Thread Tools Display Modes
Old 09-09-2013, 11:51 AM   post #1 of 18
Hicks
MTF Member
MTF Member # 118042
Default convert to electric fuel pump
i have a m&w zero turn with a kohler magnum 18 horse twin that i would like to change over to an electric fuel pump instead of the mechanical one. i was wondering how many psi the electric pump should be. i would think the smallest psi pump should work but would like some imput on the subject, thanks.
__________________
Hicks
1964 wagner little giant
1965 national ride on reel mower
1990`s lgt 18h ford
1970`s lgt 145 ford
424 dixon zeeter 424
very old home made tractor
massey fergusen 50c diesel fel
and im shure theres something else im forgetting
Hicks is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 09-09-2013, 05:28 PM   post #2 of 18
WattonYooper
Senior MTF Member
MTF Member # 53553
Default Re: convert to electric fuel pump
I put electric fuel pumps on 2 of my Onan power machines. Used 3.5/4 pound pressure pumps.
Ted
WattonYooper is offline   Reply With Quote Quick reply to this message
Old 09-09-2013, 07:16 PM   post #3 of 18
Hicks
MTF Member
MTF Member # 118042
thanks, i didnt think i would take a big pump since alot are gravity fed.
__________________
Hicks
1990`s lgt 18h ford
1970`s lgt 145 ford
Old 09-09-2013, 07:38 PM   post #4 of 18
Cannon51
Senior MTF Member
Cannon51's Avatar
MTF Member # 23545
How much power does it use and does your motor make enough power (electric) to add it?
Cannon
Cannon51 is offline   Reply With Quote Quick reply to this message
Old 09-09-2013, 07:45 PM   post #5 of 18
WattonYooper
Senior MTF Member
MTF Member # 53553
If it is gravity feed you don't need a fuel pump. My cub cadet has a K301 and the tank is mounted above the carb, no fuel pump needed.
I never had a problem with the electrical source, both have 15amp charging systems.
Old 09-09-2013, 09:27 PM   post #6 of 18
Hicks
MTF Member
MTF Member # 118042
this machine is not gravity fed. the kohler fuel pump went out. i can get an electric pump cheaper than the factory kohler pump. as far as the charging system goes it should be fine.
__________________
Hicks
1990`s lgt 18h ford
1970`s lgt 145 ford
Old 09-09-2013, 11:36 PM   post #7 of 18
Tractor-Holic
10,000 +posts!
Tractor-Holic's Avatar
MTF Member # 8867
You wont need much more than 1.5 lbs to run that engine fine,there are some 1.5 to 3 lb pumps available that have very low amp draw..
__________________
Tractor-Holic is offline   Reply With Quote Quick reply to this message
Old 09-10-2013, 09:13 AM   post #8 of 18
38racing
Proud Member of the 1K Club
MTF Member # 25899
Not sure if this forum or another that had thread on pumps. electric needs to shutoff if engine should stop running for any reason or it will keep pumping fuel?
38racing is offline   Reply With Quote Quick reply to this message
Old 09-10-2013, 10:11 AM   post #9 of 18
Hicks
MTF Member
MTF Member # 118042
1.5 is what i was originaly planning on getting for it. My thoughts were if a gravity feed system works fine , then the smallest psi pump should be more than enough. napa has a 1.5 for $55 the kohler pump is $86. thanks for the input guys!
__________________
Hicks
1990`s lgt 18h ford
1970`s lgt 145 ford
Old 09-10-2013, 01:45 PM   post #10 of 18
tomw0
2000 Posts and climbing!!!
MTF Member # 34922
I'd think a 1.5 would be fine. Be aware of the different filters as some will need higher pressure to flow. Likely a difference without distinction, I guess, but if you do have a problem, check the flow with and without filter to make sure a picky filter is not causing difficulty. Just flow into a container before the filter, and after for comparison.
Some pumps have internal switches that de-power the pump when there is no demand, applying power only when the pressure drops below a specific set-point. That saves energy, wear, and also will stop the pump in case of a roll-over or other difficulty. As long as the fuel line is intact, and the float bowl needle & seat working it will stop pumping. OTOH, flip, and the pump will continue to pump.
I would take a look at the wiring diagrams for any that have a powered pump to see if duplication of the safety switch system could be reasonably done. Definitely get a 'rollover' switch from a junkyard for a few dollars. Who knows, it may prevent conflagration. They are mounted under the glove box, behind the top edge of the carpet/floormat on the firewall or toe-board in Ranger trucks, and should work fine for your application. Cheap protection.
tom
tomw0 is offline   Reply With Quote Quick reply to this message
Old 09-10-2013, 03:15 PM   post #11 of 18
rgoers
Senior MTF Member
MTF Member # 100394
Quote:
You can buy genuine Mikuni mechanical fuel pumps for very little money. I think the last one I replaced on one of my snowmobiles was well under $20, and far less than the rebuild kit Polaris sells.
What exactly happened to your pump? There isn't much that can go wrong, besides the diaphragm leaking. Almost all of them can be rebuilt too...
__________________
NOW: 1993 Troy-Bilt #13066, 48" deck #14055, mulch attachment #14011, 26" tiller #14006, 42" blade #14007, 50lb weights #14090
FORMER: 1977 and 1985 John Deere 212's
rgoers is offline   Reply With Quote Quick reply to this message
Old 09-10-2013, 10:53 PM   post #12 of 18
Hicks
MTF Member
MTF Member # 118042
the current kohler pump quit working, diaphrams are bad. you used to be able to get a rebuild kit for them but now they quit making rebuild kits. you have to buy a whole complete pump, $86. plus the m&w machine has to be torn apart as the engine is under the seat. big pain. I just bought the 1.5 to 4 psi electric pump, and four feet of fuel line and four clamps for $54. gonna start on it soon I hope. also the new electric pump came with its own filter that screws in the (in side) of the pump so I shouldn't have to worry about filters. hope it all goes good.
__________________
Hicks
1990`s lgt 18h ford
1970`s lgt 145 ford
Old 09-11-2013, 01:16 AM   post #13 of 18
Tractor-Holic
10,000 +posts!
MTF Member # 8867
Most car engines had the oil pressure sending unit wired up to the electruc pump so it would shut off the fuel pump with the engine off automatically,,if yours has a full pressure lube system it maybe you can wire it up in the same fashion.
__________________
Old 09-11-2013, 04:30 AM   post #14 of 18
Cannon51
Senior MTF Member
Cannon51's Avatar
MTF Member # 23545
Would this be an option? http://tewarehouse.com/22-1012
Cannon
Sponsored Links
Advertisement
Old 09-11-2013, 12:19 PM   post #15 of 18
Tractor-Holic
10,000 +posts!
MTF Member # 8867
Yes it would,provided the engine has a vacuum port to hook it too,it sounds like it does if it had the old Walbro pulse pump..(kind of sucks you have to pay 8.95 to ship a 10 dollar part though--for a few bucks more you might locate an electric pump locally)..
The diaphrams seem to die early in the ethanol gas nowadays..thats why I lean toward going with an electric pump,one that has the solenoid type pump,with the nylon ball doing the pumping,not one with a diaphram to go bad eventually..
__________________
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
