Sputter or Stall Downhill to the Right - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 08-07-2013, 11:04 AM   post #1 of 16
ctrobk
MTF Junior Poster
MTF Member # 134874
Default Sputter or Stall Downhill to the Right
Hello all,
I am looking for some advice on an issue I am having. I have a DGT6000 with 27hp Kohler. I think its around 2003 model.
When I head on a downward slope or angled to the right the engine sputters like it is going to stall. Once the tractor levels out, the rpm's shoot right back to normal speed.
I know it is not the seat safety switch. I disconnected it to troubleshoot the problem.
I think it might be a fuel problem. Runs normal uphill and level. No trouble starting.
Any ideas?
Thanks
ctrobk is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-07-2013, 12:32 PM   post #2 of 16
nkaust
Proud Member of the 1K Club
nkaust's Avatar
Location: Berkeley Springs West Virginia, Hello My Name Is Nkaust And I Am Addicted To Garden Tractors
MTF Member # 37424
Default Re: Sputter or Stall Downhill to the Right
sounds like it's running out of gas to me
__________________
78 Sears GT/14
57 Farmall Cub
1254 Bolens
1253 Bolens
1050 Bolens
I'm Sure Theres Others Somewhere Lol
Common Sense And Caution Are factors which Cannot Be Built Into Any Product.
These Factors Must Be Supplied By The Operator.
nkaust is offline   Reply With Quote Quick reply to this message
Old 08-07-2013, 01:34 PM   post #3 of 16
Tractor-Holic
10,000 +posts!
Tractor-Holic's Avatar
MTF Member # 8867
All float type carbs will exhibit this to some degree,when you tilt them at an angle far enough off camber or uphill/downhill,,the fuel in the bowl tends to seek its own level and some fuel starvation occours, or they will flood..some are more sensitive than others...
Many off road 4x4 enthusiasts use Quadrajet carbs because they seem less prone to this problem,compared to an Edelbrock or Carter,or Holley carb...
You could check the float level to be sure its set to the corrct level,and if it has a fuel pump,ensure its delivering enough fuel...if those 2 things check out,I am afraid you may just have to live with it...this is why some engines used diaphram type carbs,so the engine will run at any angle ,like a chain saw...most 4 cycle engines wont like running too long tilted to far even if the carb would allow it too though,it might starve for oil and do some lower end damage..
__________________
Tractor-Holic is offline   Reply With Quote Quick reply to this message
Old 08-07-2013, 02:46 PM   post #4 of 16
Sixgun
6's & 8's
Sixgun's Avatar
MTF Member # 83377
Garage
I had a similar issue with another motor and it turned out to be the low oil sensor. When turning one direction or going uphill the engine died. It didn't sputter though, it just cut out.
Something to consider if it turns out not to be a fuel issue.
__________________
72' SS12 Sears Suburban
Sixgun is offline   Reply With Quote Quick reply to this message
Old 08-07-2013, 03:16 PM   post #5 of 16
ctrobk
MTF Junior Poster
MTF Member # 134874
Quote:
At first I thought it might be caused by low gas level since when it is tilted toward the right causes the fuel to move away from the outlet. I filled the tank and still had the same issue.
This is a new problem, I have been cutting the same slopes with this machine for the past 6 years.
I will take a look at the float in the carb. But hoping someone here has had a similar problem and can pinpoint a solution.
Thanks again.
Old 08-07-2013, 04:12 PM   post #6 of 16
jaevans
MTF newbie
jaevans's Avatar
MTF Member # 77027
Try rotating the fuel filter 90 degrees and see if it fixes the issue. If it does, the filter should be replaced. My thoughts are that the fuel filter is clogged on just part of its surface area and the slant makes it so no fuel can get through.
jaevans is offline   Reply With Quote Quick reply to this message
Old 09-05-2013, 10:38 PM   post #7 of 16
ctrobk
MTF Junior Poster
MTF Member # 134874
I want to seek more advice on this problem I have with the tractor. It is model #917.275282 with a Kohler CV740s-0018. I finally had some time to tinker with it the past few days.
I removed and cleaned the carb, and at the suggestion of my parts dealer swapped the see-thru larger fuel filter to a smaller one that is less prone to air bubbles.
I also determined the problem is not so much downhill as it is when the machine is tilted to the right.
My parts dealer also mentioned the low oil sensor but said that would shut the engine off.
After disassembling the carb, I thought it might be a problem with a diaphragm. Forgive me for not knowing the name, but I can not find an exploded view of the carb. This diaphragm was located on the right side of the bowl of the carb and accessed after removing 3 screws. There was also a large spring that applies pressure to the diaphragm. I thought it was in bad shape because it wasn't pliable. Parts guy said he has seen worse and should still work with the condition it was in. He didn't think that was the problem. He looked at the float and said it looked like it was in the right position.
He also mentioned the fuel pump but when I told him it wasn't mechanical and was vacuum actuated he didn't think that was the issue either.
I also removed the rocker cover on the right side and a decent amount of oil came out. Is this normal? I should have mentioned I think the head gasket on the right side probably needs to be replaced. When the carb was off, I noticed a lot of grime on the outside of the cylinder from what appears to be a small oil leak. The other side was fairly clean.
Engine runs great when level, uphill or tilted left.
Tilted right, the rpms bog down like it wants to stall.
Thanks for taking the time to read this post. Appreciate your suggestions.
Old 09-06-2013, 07:09 PM   post #8 of 16
ctrobk
MTF Junior Poster
MTF Member # 134874
update on the problem: the engine didn't stall when I kept it tilted to the right. In the past I always tried to level out before it stalled. So today, I let kept it on the tilt and it just bogs down. I lose about 1000+ rpm.
Please let me know your thoughts on what it could be
Old 09-08-2013, 07:51 AM   post #9 of 16
BobP
Senior MTF Member
BobP's Avatar
MTF Member # 71265
Have you checked and or cleaned the fuel tank? maybe there is something in there rolling around blocking the fuel inlet . If the fuel inlet is on the left side it would make sense .
__________________
The only bad question is the one not asked .
http://golfcoursemechanics.blogspot.ca/
BobP is offline   Reply With Quote Quick reply to this message
Old 09-08-2013, 08:46 AM   post #10 of 16
38racing
MTF Member # 25899
Could something be shifting and partially shorting the seat safety circuit .does it happen if blades pto is not engaged?
38racing is offline   Reply With Quote Quick reply to this message
Old 09-09-2013, 08:20 PM   post #11 of 16
ctrobk
MTF Junior Poster
MTF Member # 134874
Thank you for the responses and ideas. I was thinking the same thing about the fuel tank. However, I think I might have found the problem. I drove the tractor down to the part of the property where it always sputters without the engine cowl. While it was sputtering, I tried to remove the air filter, the suction from the engine was so strong, it took a huge effort to remove it. Once removed, engine fired right back up to 2500+ rpms.
I cleaned the air filter and pre filter with my compressor but it didn't fix the problem. I have new filters on order. I am assuming filter is clogged in some fashion.
I am baffled on why the tractor runs fine in all positions except tilted to the right. For some reason its not getting enough air in that position.
Once I get the new filter, I will report my results.
Old 09-10-2013, 10:56 AM   post #12 of 16
GT_80
Cranky Motorsports
GT_80's Avatar
MTF Member # 35886
Images: 32
Garage
Check the tank. I had acorn in my tank once that caused all kinds of problems... I think I remeber putting them in the tank when I was a kid. Surprised they stayed in there that lond. I should have thrown them in a fire to see what they would do
__________________
MTF Addict #35886
Hugh-SS/16 fan #0001
Tractors:
1968 Super12 "Miss Emma Lee"
1967 Suburban 12 "The 679"
1973 SS16/ 18/6 hybrid "Mighty Mongrel"
1976 SS18 "Trusty"
1978 GT18 with Hard cab - home again!
Attachments:As many as I can get
My YouTubeMy Ebay
Sears Manuals
GT_80 is offline   Reply With Quote Quick reply to this message
Old 09-13-2013, 10:10 PM   post #13 of 16
ctrobk
MTF Junior Poster
MTF Member # 134874
I thought I would update this post just in case someone has a similar problem. It turned out to be the air filter. I installed the new filter with a new foam pre filter. Tractor runs great now on slopes and angles.
I overlooked the air filter because it was running great with the exception of a slope.
Old 09-13-2013, 11:09 PM   post #14 of 16
Bill Kapaun
Circumflatulater
Bill Kapaun's Avatar
MTF Member # 6264
Isn't that EFI instead of carbureted?
__________________
Illegally Blind
Bill Kapaun is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 09-14-2013, 07:48 PM   post #15 of 16
ctrobk
MTF Junior Poster
MTF Member # 134874
I wish it was EFI, but it is carburated.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
